Old Jun 01, 2012, 02:43 AM
kaz1104 is offline
Find More Posts by kaz1104
Dreamer
Australia, TAS, Memana
Joined Aug 2004
Originally Posted by WiseDuck View Post
I would love to have one of those too. I've seen that one of his frames is capable of carrying a gopro or similar camera. It has a tab for that. I would personally just put a small FPV camera there and not record anything. Something small and nimble that can get through places my 450-sized quad can't would be nice to have. Go go go!
Maybe even a "bolt" type design. Small but with powerful high kV motors capable of lifting some weight. Components well protected in the frame.
Maybe 6 of these http://www.hobbyking.com/hobbyking/s...idProduct=6634
kaz1104 is offline Find More Posts by kaz1104
Old Jun 01, 2012, 02:52 AM
WiseDuck is offline
Find More Posts by WiseDuck
Mmmmmmm!
WiseDuck's Avatar
Kingdom of Sweden, Dalarna County, Sater
Joined Oct 2011
There's one thing I'd like to see in many future frame designs. Tiny holes for receiver antennas. Preferably in the protection plate that sits on top of the electronics, right next to the nylons spacers so I can use a cable tie to hold the antenna and just feed the receiving part through the tiny hole or something. I use FrSky and they usually come with diversity antennas. It's a bit of a pain to route these around small frames when only a tiny part of the antenna is actually used.
I actually use drinking straws on all my quads to keep the antennas perfectly straight. I just hot glue these to the frame, feed the antenna through and only the receiving part of the antenna pokes out the end of the drinking straw. Works very well for me.
WiseDuck is offline Find More Posts by WiseDuck
Old Jun 01, 2012, 05:13 AM
Kris... is offline
Find More Posts by Kris...
Registered Addict
Kris...'s Avatar
United Kingdom, Stoke-on-Trent
Joined Jul 2010
Don't know. Cut off that part?
I flew the tricopter a bit yesterday, I replaced the Crius SE board with a KK Blackboard and let me tell you, the KK board is ****. Handles poorly, gyros drift ALL the time and requires constant trim. I need to get myself more Multiwii boards later because this board was almost unusable. (Minsoo Kims 2.5 fw was used).
Cant cut it off ! its all the exposed top part of the motor shaft so that wouldnt work as there would be no shaft left for the prop
Regarding the KKBlackboard i have it in my classic bambu same setup as yours Minsoo Kims 2.5 and it flys just great WiseDuck.
Kris... is offline Find More Posts by Kris...
Old Jun 01, 2012, 05:40 AM
WiseDuck is offline
Mmmmmmm!
WiseDuck's Avatar
Joined Oct 2011
Maybe mine's crap or it's my settings. But there's nothing unusual about this setup. I'll just use something else instead, I like Multiwii boards more anyways!
Old Jun 01, 2012, 06:00 AM
Freakazoid is offline
Find More Posts by Freakazoid
Freakazoid's Avatar
Roosendaal, Netherlands
Joined Dec 2004
I was wondering what was going on with your KKboard as well.
Performance wise I even prefer the KKboards, its nearly impossible to set up wrong.
I assume you are using counter rotating props on your tri?
They can fly with 3 of the same direction, though that indeed causes yaw drifting a lot.
The smaller they get, the easier it is to get the settings wrong though,
bigger ones are more forgiving because their weight dampens things.
These small buggers can easily start fidgeting.
How did you go about setting your tri up?
I just tune up the roll gyro so far it starts to show the typical waddling during forward flight,
then dial it down VERY slowly until it fades out enough for me to fly comfortably.
For pitch I just do the same, only I observe what it does when transitioning out of forward flight.
If it starts pumping its tail rapidly (and loudly) its too tight.
As for yaw.. well as long as the tail tracks straight in banked cornering, that's where it needs to be.
Yaw is easiest of all I think, anywhere between 40 and 70% is fine.
Id like some multiwii boards, but frankly the ACC/MAG/all that noise be damned.
Gimme a gyro only multiwii for 30 bucks and im sold.
Freakazoid is offline Find More Posts by Freakazoid
Old Jun 01, 2012, 06:18 AM
WiseDuck is offline
Mmmmmmm!
WiseDuck's Avatar
Joined Oct 2011
I use one counter rotating prop. That's another thing, it kept yawing left or right, I had to trim that a lot too. With the Crius MWC board it was rock solid with default settings, altho I needed to tune it a bit to make it more agile.
I'll try a Multiwii board again, I'll just give this board to a friend of mine, I have another KK board here that I got from HK because I thought this one was dead. So yeah, he can have it.
Old Jun 01, 2012, 06:25 AM
Freakazoid's Avatar
Joined Dec 2004
If it drifts, crank up the pot?
And heh, wish I was your friend.
Old Jun 01, 2012, 06:33 AM
WiseDuck is offline
Mmmmmmm!
WiseDuck's Avatar
Joined Oct 2011
I do believe I tried that, but it's already at the point where it will oscillate if a bit of wind drops by. :P Well, it's just a 15 dollar board, so who cares? I ordered a frame from GLB a month ago, still hasn't shipped, if it arrives he can have that too. I want more multirotor users in this club here, I'm the only one right now!
Old Jun 01, 2012, 06:49 AM
Freakazoid's Avatar
Joined Dec 2004
Hahah, careful what you wish for!
They already call me the quad doctor at my club,
Ive had to tweak and test 5 "sick" multicopters for them already.
The sound of 3 multicopters whizzing around is VERY rewarding though.
Old Jun 02, 2012, 03:23 PM
Widelec is offline
Find More Posts by Widelec
Simple is the best
Joined May 2011
MiniQuad & IOI Miniwii Compact Build
Compact build is in my mind for a while,
I tried today an compact MiniQuad build.
I used MiniQuad frame ( two main, upper and lower plate )
IOI Mini Multiwii FC, Suppo A1510 BL, Suppo 10A ESC, 5030 Gemfan Propeller set. All electronic parts and power harnes fits between two main plate. Two main plate space is 15mm. Need (hard to find) rigth angle triple pin header for rx and esc connect.
Widelec is offline Find More Posts by Widelec
Old Jun 02, 2012, 03:33 PM
FlyinGizm0 is offline
Find More Posts by FlyinGizm0
FlyinGizm0
FlyinGizm0's Avatar
Austria, Ktn., Villach
Joined Mar 2012
here I got mine!!!
http://www.ebay.de/itm/170842981586
takes 10 days and they are perfect for the IOI mini :-)
greetings
Gerald
PS: You can add them to your shop and ship a set with all IOI Mini! :-)
FlyinGizm0 is offline Find More Posts by FlyinGizm0
Old Jun 02, 2012, 03:43 PM
Widelec is offline
Simple is the best
Joined May 2011
Originally Posted by gzebedin View Post
here I got mine!!!
greetings
Gerald
Hmm.. looks good
one board need 9 pin.
40 pin for 4 board .
Old Jun 02, 2012, 03:52 PM
FlyinGizm0
FlyinGizm0's Avatar
Joined Mar 2012
and one spare for sum signal :-)
the also offer a big pack of 50 or so.
http://www.ebay.de/itm/170850555242
Gerald
Hmm.. looks good
Old Jun 02, 2012, 04:18 PM
Widelec is offline
Simple is the best
Joined May 2011
Gerald
I bought 5x40 pack now.
Old Jun 02, 2012, 04:25 PM
Widelec is offline
Simple is the best
Joined May 2011
Compact build photos here,
Description: Name: 02.jpg
Description: Name: 03.jpg
Description: Name: 04.jpg
Description:
Description: Name: 06.jpg
Description: Name: 08.jpg
Description: Name: 09.jpg
Description:
Description: Name: 16.jpg
Description: Name: 17.jpg
Description: Name: 18.jpg
Description:
Description: Name: 20.jpg
Description: Name: 21.jpg
Description: Name: 22.jpg
Description:
Discussion BambuCopter *BlueBird QuadCopter, BlueBird TriCopter* SmallQuad 450 AirFrames Widelec Multirotor Talk 343 May 25, 2013 03:00 PM
Discussion HK has a new mini quad frame Pintac Multirotor Talk 20 Sep 28, 2011 10:04 AM
Sold Quad frame for sale!!! previously listed. as full quad. tc3wins Aircraft - Electric - Multirotor (FS/W) 3 Aug 25, 2011 08:56 AM
Sold Mini Quad with G10 frame RXR tc3wins Aircraft - Electric - Multirotor (FS/W) 4 Jul 21, 2011 11:05 PM
