Old Apr 25, 2012, 01:21 AM
WiseDuck is offline
Find More Posts by WiseDuck
Mmmmmmm!
WiseDuck's Avatar
Kingdom of Sweden, Dalarna County, Sater
Joined Oct 2011
Ughh, tried to clean up my Bambucopter last night but soldering these short motor wires is a major pain in the ass. I hate soldering magnet wire, and now that the wires are so short you only get one chance and the motors are now useless in any other configuration. You can't make these longer. Why aren't they using silicon wire which won't break if you tug on it a little?
I'm sure it'll fly, but even a minor crash would most likely break the wires clean off. Good thing I have a spare motor and another 4 on the way and only 3 is needed to complete the tricopter.
WiseDuck is offline Find More Posts by WiseDuck
Old Apr 25, 2012, 06:13 AM
TheNiceGuy is offline
Find More Posts by TheNiceGuy
Expat
Japan
Joined Apr 2010
Do you meant the copper wires out of the windings? After a lot of that nonsense I epoxy all my motor leads now.
TheNiceGuy is offline Find More Posts by TheNiceGuy
Old Apr 25, 2012, 06:46 AM
WiseDuck is offline
Mmmmmmm!
WiseDuck's Avatar
Joined Oct 2011
Copper wires out of the windings, yeah. I really don't like those stiff wires that come out of some motors. And these have how many strands? Two? Three? I could easily snap these off. I also find them real troublesome to solder, the solder just won't stick very well. I did manage to solder all the wires directly to the ESC wires. So it'll work... But these things are no longer re-usable. The motors aren't anyways.
Old Apr 25, 2012, 10:01 AM
skellator is offline
Find More Posts by skellator
9W2DLR
Malaysia, Pahang, Temerloh
Joined Nov 2011
something wrong with my MWC IOI it was working this morning just now I unplugged the ESC set the throttle range, now when the turnigy plush connected to my IO board it start beeping constantly not sure why from the GUI everything show up fine,
i found this:
http://www.fpvuk.org/forum/index.php?topic=4893.0
but not sure what to do, I have not encounter this kind of problem before with my others ESC
plus does the code correct? if yes why the orientation of my quad in GUI look wierd even after calibration
skellator is offline Find More Posts by skellator
Old Apr 25, 2012, 01:09 PM
Widelec is offline
Find More Posts by Widelec
Simple is the best
Joined May 2011
i found this:
I've had the same problem with turnigy plush ESC. This is independent of the Fligth Controller Board.
Many time I need change the controler boards for the tests. Same motor ESC , different fligth controller. often turnigy plus esc continus bep bep bep.
My solution ;
Reprogram all esc with program cart . everting is okay, after the reprogram .
Widelec is offline Find More Posts by Widelec
Old Apr 25, 2012, 01:19 PM
leprud is offline
Find More Posts by leprud
Trying to learn.
leprud's Avatar
Moscow, Russia
Joined Jun 2010
They beep because of wrong throttle range you did (carefully read MWC threads and faqs)
Your GUI looks good. Everything is fine - remember, that you have magnetometer
leprud is offline Find More Posts by leprud
Old Apr 25, 2012, 01:37 PM
Widelec is offline
Simple is the best
Joined May 2011
@leprud, you're right first must check throttle range,
but sometimes throttle range calibration does not work.
Happened to me several times, In this case reprogram is work fine.
Old Apr 25, 2012, 07:57 PM
9W2DLR
Joined Nov 2011
thanks for the input i willl try to reprogram my esc sse how it goes,
oh yeah i totaly forgot i have mag
Old Apr 26, 2012, 02:39 PM
daign is offline
Find More Posts by daign
My RC builds in my profile.
daign's Avatar
Joined Feb 2011
A1510 motor quality is horrible. I've got 6 dead motors here. They twitch, some just heat up, some don't do a thing.
All my working A1510s are horribly out of balance, I ordered high end prop adapters for them, still the props vibrate almost 5-10mm at full throttle. Its amazing these a1510s fly at all.
Next time you spool up your 1510s watch them. Some are perfect some are so out of balance its not even funny.
I'm done with this motor.
I've been eyeballing that C10 available at hobbypartz. I am going to be mounting my Sk3 2750s on my Hexa frame this week and using prop savers. I was unable to swap the shaft to use prop adapters sadly. Even though I have longer shafts I cannot get the shaft to seperate from the top bell. On 2s it should allow me to run almost a 2200mah 2s.
Those motors are expensive though, I'm looking for a US sourced motor for nano/mini quads. Any ideas?
daign is offline Find More Posts by daign
Old Apr 26, 2012, 03:31 PM
9W2DLR
Joined Nov 2011
C10 2100kv is no good you might want to try 2900kv i have 10 of these a1510 hopefully it is not that bad as you have but if that the case i might stop building these small bugger
Old Apr 26, 2012, 04:10 PM
WiseDuck is offline
Mmmmmmm!
WiseDuck's Avatar
Joined Oct 2011
I wanna see more of these in the air, so much talk, not enough quad videos. :P I've got four A1510 motors on the way with matching ESCs and whatnot, I'll try to post a build log or something once I get everything.
Old Apr 27, 2012, 01:23 AM
9W2DLR
Joined Nov 2011
true, I'm trying to finish my quad and tri but can't find enough time to do it so busy with works, new mission! finish the Quad and Tri during the weekend! I try my best not to go out flying my cloud fly
Old Apr 27, 2012, 09:20 AM
9W2DLR
Joined Nov 2011
i did a reset using my programing card and ro
e-do my throtle range setting my esc still fail to a
work arghh have no idea how to fix this
UPDATE!:
problem solve!
Code:
#define MINCOMMAND 900
I figure this out as I noticed in the GUI my min throttle was 986, in the config the MINCOMMAND was set to 1000, from the note it said I can decrease the value which I did and it finally working now!
Old Apr 27, 2012, 01:25 PM
Widelec is offline
Simple is the best
Joined May 2011
I know now ,
why your slogan is Expert Crasher
I will send to you new frame
Old Apr 27, 2012, 01:41 PM
9W2DLR
Joined Nov 2011
Originally Posted by Widelec View Post
I know now ,
Discussion BambuCopter *BlueBird QuadCopter, BlueBird TriCopter* SmallQuad 450 AirFrames Widelec Multirotor Talk 343 May 25, 2013 03:00 PM
Discussion HK has a new mini quad frame Pintac Multirotor Talk 20 Sep 28, 2011 10:04 AM
Sold Quad frame for sale!!! previously listed. as full quad. tc3wins Aircraft - Electric - Multirotor (FS/W) 3 Aug 25, 2011 08:56 AM
Sold Mini Quad with G10 frame RXR tc3wins Aircraft - Electric - Multirotor (FS/W) 4 Jul 21, 2011 11:05 PM
