Old Jan 06, 2013, 11:05 PM
fastfwd is offline
Find More Posts by fastfwd
United States, ID, Burley
Joined Mar 2012
Originally Posted by erkq View Post
Why would you want to keep the plane level in a turn? That makes for a sloppy, slidy turn with the "ball" way off to one side instead of centered. You want the right wing to drop in a right turn. Matter of fact, you begin a turn in an aileron ship by doing precisely that with the ailerons. Then you use the elevator to climb through the turn and rudder to keep the plane from climbing excessively.
The early pioneers of flight used to turn level and when Berloize (sic?) adopted banked turns it was a real breakthrough.
its called a flat turn and is used to teach control, jeez have a cow why dont you.Also when a guy is flying a powered glider and taking video,he wants to keep his turns level and smooth, its not all about crank and yank ..
fastfwd is offline Find More Posts by fastfwd
Old Jan 07, 2013, 05:29 PM
Gharddog03 is offline
Find More Posts by Gharddog03
Ground Pounder
Gharddog03's Avatar
United States, CA, Fresno
Joined Nov 2012
Just pulled the trigger on one of these puppies. It will be my first ARF and can't wait to get it up in the air. Does the ESC use 4.0 banana? Also can I run 3s 1300mah 30c safely and how long can I sport fly it?
Gharddog03 is offline Find More Posts by Gharddog03
Old Jan 07, 2013, 05:35 PM
flyandi is offline
Find More Posts by flyandi
United States, CA, Aliso Viejo
Joined Aug 2009
3S 1300mAh .. I am not quite sure if that will work ... Maybe you get 2min of flight time, but I believe that the weight of the battery will not meet the required CG.... People successfully reported that 3S works - but it's far from a sport flyer.
I highly suggest to get some Zippy Compact 4S 2700mAh 25C - they are cheap (about $18) and they give me about 10min of flight time with good performance including hovering.
flyandi is offline Find More Posts by flyandi
Old Jan 07, 2013, 05:50 PM
Ground Pounder
Gharddog03's Avatar
Joined Nov 2012
Thanks might have to put an order soon.
Old Jan 07, 2013, 09:20 PM
erkq is offline
Find More Posts by erkq
United States, CA, Sebastopol
Joined Dec 2010
Yeah, I don't "crank and yank" either. That refers to turning with just the aileron and elevator and results in messy un-coordinated turns also. Rudder use when necessary is part of good flying technique.
What you describe is usually how a plane responds to rudder-only turns. The outside wing starts going faster than the inside wing and generates more lift. If you want it to stay flat you almost always have to put some opposite aileron into it. But if you don't have enough speed, this can create a tip-stall on the inside wing and create an even bigger problem.
I have to say I never felt the need to slide in a flat turn to "learn control". I suppose a KE is a flat turn of sorts, only spun 90 degrees and turning against the force of gravity.
And, thank for the permission to "have a cow". This thread isn't about powered gliders, or taking video.
erkq is offline Find More Posts by erkq
Old Jan 07, 2013, 11:39 PM
fastfwd is offline
Joined Mar 2012
Nope its about you jumping down anyone's throat that has anything to say that you dont agree with, seems to be a whole bunch of you people on these forums, that know all there is to know,and use there knowledge to belittle and beat folks down. quite sick of it myself. so stuff it.
Old Jan 07, 2013, 11:46 PM
erkq is offline
Joined Dec 2010
I didn't mean to jump down your throat. I didn't mean to belittle you. I didn't mean to beat you down. I am really sorry.
Old Jan 07, 2013, 11:57 PM
fastfwd is offline
Joined Mar 2012
No im sorry, you really didnt jump on me, others have for no real reason, and you got the brunt of it. No worries. by the way i love this plane,it knife edges nice and is fast. again i apologize for loosing my marbles.
Old Jan 08, 2013, 12:01 AM
erkq is offline
Joined Dec 2010
"Loosing my marbles" hahah that's funny.
Yeah, it's a really great deal for $120 shipped to my door. I've just got to take the time to re-align the elevator. It's incidence is out of alignment with the wing and it makes it do weird things in some maneuvers. But landings... suh-weet!
Old Jan 08, 2013, 12:23 AM
Ground Pounder
Gharddog03's Avatar
Joined Nov 2012
6% off on NP if anyone interested.
Old Jan 08, 2013, 11:37 AM
whichwaysup is offline
Find More Posts by whichwaysup
when down=up, up=expensive
whichwaysup's Avatar
United States, NC, Greenville
Joined Apr 2012
Erkq - good to see you join the thead on this one. I love this thing. I saw your note about re-aligning the elevator and you may want to add "reinforce landing gear" to that list. Even with nice landings, it will likely collapse eventually. A little basswood, epoxy, and a few more screws and you'll be good to go. Watch your control horns too - I've had a couple break on me, one midflight. Could just be mine though.
Getting pretty decent at hovering this thing. I've had it since November and am *finally* getting to a point where I'm comfortable throwing it around. Unfortunately, I know what usually happens when I start getting comfortable with a plane. I might need that discount code soon enough!
Anybody else notice a *slight* tendancy for this thing to drop a wing when pulling out of a dive, or pulling hard elevator suddenly? I've seen it happen a few times when I wasn't expecting it, but can't seem to make happen when I try. It's just enough to cause a quick heart attack before it recovers.
whichwaysup is offline Find More Posts by whichwaysup
Old Jan 08, 2013, 12:30 PM
flyandi is offline
Joined Aug 2009
code is pricepickle and is always active ... has been for 2 years now!
pasantia is offline
Find More Posts by pasantia
United States, IA, Fort Madison
Joined Jan 2009
landing gear mods
will somebody show how to improve landing gear
pasantia is offline Find More Posts by pasantia
Old Jan 08, 2013, 01:55 PM
Joined Apr 2012
There are a few options. I didn't like having external support, so this is what I did.
http://www.rcgroups.com/forums/showp...postcount=1378
The only addition is that I ended up screwing the LG plate to the basswood after I epoxied the basswood in. Basicaly, here's the steps I'd recommend:
1) Cut the foam back about 2-3 inches back and forward of the current LG mounting hole (where that extra piece of foam goes to cover the LG bracket up once you mount it). Keep the foam, you'll use it to cover up your work.
2) Cut a piece of basswood to fit the area you just exposed. Drill holes for the existing LG bolts, and drill four additional pilot holes through the provided LG bracket (near the four corners) and into the basswood - use short wood screws for these four.
3) Epoxy a piece of Basswood (thickness is in the post below) - using longer drying epoxy will be less brittle and longer lasting).
3) I epoxied the bracket to the basswood AND screwed it in, but only because I got tired of it failing on me. You could PROBABLY get away with just screwing it in.
4) Replace the foam over the basswood and LG bracket. You may have to trim the foam a bit due to the thickness of the basswood.
5) I used Dap light spackle to fill in any gaps and then painted over it.
Old Jan 08, 2013, 02:56 PM
pasantia is offline
Joined Jan 2009
thanks
thanks a lot
Build Log Sbach 342 flyhawk Sport Planes 281 Sep 27, 2014 08:39 AM
Cool Sbach 342 - The wait is over!! FINALLY RC! rcxmachines Giant Scale Airplanes 85 Jan 20, 2010 02:47 AM
Video Sbach 342 - The wait is over!! FINALLY RC! rcxmachines Fuel Plane Talk 0 Aug 21, 2009 01:29 AM
Discussion Two Seat Sbach 342 james-bai Fuel Plane Talk 1 Jul 21, 2009 12:05 AM
Discussion Sbach 342 power system? 150grams BpPilot Indoor Pattern/F3P 5 Apr 11, 2009 08:06 PM
