Old Jan 19, 2012, 07:54 PM
minizoom is offline
Find More Posts by minizoom
minizoom's Avatar
United States, CA, Yorba Linda
Joined Sep 2011
wing flex
Any ideas on how to make the wing stiffer?
minizoom is offline Find More Posts by minizoom
Old Jan 19, 2012, 08:13 PM
poiyt is offline
Find More Posts by poiyt
United States, GA, Newnan
Joined Aug 2010
How about iso the fiberglass (I assume) wing spar, a CF one?
Anybody have a source for a CF tube that's 10mm od x 8mm id x 800mm long?
poiyt is offline Find More Posts by poiyt
Old Jan 19, 2012, 08:15 PM
poiyt is offline
Joined Aug 2010
SFG Performance
You guys who have flown both with & w/o the sfg's...are they worth putting on??
That thin foam seems pretty flimsy...hard to imaginge them having an effect one way or another?
Or are they just for looks?
Old Jan 19, 2012, 11:50 PM
erkq is online now
Find More Posts by erkq
United States, CA, Sebastopol
Joined Dec 2010
I embed CF strips vertically down the near the center of lift. Makes it very stiff.
erkq is online now Find More Posts by erkq
Old Jan 20, 2012, 03:40 AM
IFlyRCs is offline
Find More Posts by IFlyRCs
ICrashRCs
United States, TN, Memphis
Joined Jun 2011
Here are my carbon sources:
http://www.rcgroups.com/forums/showp...50&postcount=5
Can you CA an inner rod inside the stock one?
IFlyRCs is offline Find More Posts by IFlyRCs
Old Jan 20, 2012, 09:22 AM
poiyt is offline
Joined Aug 2010
How about an alum tube, 10mm x 800mm x .045"? Maybe like a heli boom?
Old Jan 20, 2012, 12:56 PM
minizoom is offline
minizoom's Avatar
Joined Sep 2011
That's what I was planning to do. I checked the inside diameter and it's 7.8mm. I don't think an 8mm will fit inside.
Old Jan 20, 2012, 01:11 PM
poiyt is offline
Joined Aug 2010
Ifly thx for the links, but no joy....
Old Jan 20, 2012, 05:50 PM
acesimmer is offline
Find More Posts by acesimmer
acesimmer's Avatar
United States, NV, Fernley
Joined Oct 2011
Mods Prior to Maiden Flight
After looking this thing over I decided no way was I going to maiden the plane on factory control linkages etc. So the pics show a few of the upgrades that I have done. For the elevator/rudder I'm trying those NewPower servos from EPbuddy. Cost around $7 each and are BB 17G with metal gears. So far I like them. Have also replaced the rudder/elevator with pinned hinges so they move nice and free without limit restrictions. Also balanced the prop which was way out. Static bench tested the setup at 100% power with max 35 amps. Idle current is 200 mah with motor off. Replaced aileron linkages with 2.5 mm pushrod and heavy duty clevices. Will pull the servos after a quick test flight and replace with NewPower along with adding pin hinges to ailerons. I could not believe how weak and flimsy the factory stock servo arms are. They are like paper thin and the servos have a lot of slop in the output shaft around center. The NewPower as no slop whatsoever.
Where are you guys is the best measurement for CG with either 1800 or 2200 packs.
acesimmer is offline Find More Posts by acesimmer
Old Jan 20, 2012, 06:48 PM
poiyt is offline
Joined Aug 2010
Whoa, ace!! Thx for that info on the NewPower servos....and here I thought epbuddy was only about ichargers & paraboards!!
I looked at the specs on that 9g digital for like $7 and my jaw dropped
42oz of torque at 5V?? From a 9g servo??? Man I had to read that twice...if these things center well and hold their positions under high loads, then SHEESH that's gotta be one of the better deals out there on servos! I might hafta grab a couple
Old Jan 20, 2012, 06:54 PM
acesimmer's Avatar
Joined Oct 2011
They look really good so far and center well with lots of power @ 6Volts. I have both digital and analog but installed the analog for less power draw.
Test flew the Sbach and landed on the club sun roof.... Or did I?
Sbach (0 min 10 sec)
Old Jan 20, 2012, 07:16 PM
ryanotown22 is offline
Find More Posts by ryanotown22
Currently flyin Crack Yak
United States, AZ, Gilbert
Joined Jul 2006
what were you doing on a roof?
ryanotown22 is offline Find More Posts by ryanotown22
Old Jan 20, 2012, 07:20 PM
Joined Jul 2006
Anyone try different prop combos yet so we can find the best prop for this?
Old Jan 20, 2012, 07:47 PM
erkq is online now
Joined Dec 2010
He wasn't.
Old Jan 20, 2012, 10:02 PM
acesimmer's Avatar
Joined Oct 2011
Originally Posted by erkq View Post
He wasn't.
Actually it was. Took about twenty attempts.
Build Log Sbach 342 flyhawk Sport Planes 281 Sep 27, 2014 08:39 AM
Cool Sbach 342 - The wait is over!! FINALLY RC! rcxmachines Giant Scale Airplanes 85 Jan 20, 2010 02:47 AM
Video Sbach 342 - The wait is over!! FINALLY RC! rcxmachines Fuel Plane Talk 0 Aug 21, 2009 01:29 AM
Discussion Two Seat Sbach 342 james-bai Fuel Plane Talk 1 Jul 21, 2009 12:05 AM
Discussion Sbach 342 power system? 150grams BpPilot Indoor Pattern/F3P 5 Apr 11, 2009 08:06 PM
