Old Jan 13, 2012, 12:57 PM
jsmith285 is offline
Find More Posts by jsmith285
jsmith285's Avatar
Fort Wayne
Joined Feb 2009
Originally Posted by nioa View Post
Joe is an excellent pilot.
I would be very interested in his thoughts about Haiyin batteries. How hot they come out of the plane after his flights. His impression of their power compared to other brands. How long he has been using these batteries, and how long he expects them to last. Has he had any battery related failures / problems?
Those are some of the questions I would ask Joe.
Nick
Not Joe, His Dad. Winter here right now, The 58" edge doesn't even have the cooling holes open in it yet. So not able to give a temp impression. But same as the others we are running. No Failures or problems. They seem to be really well made compared to all the other brands we have in the Battery box. Holds the voltage well through the flight. Good heavy leads on them. And they came well balanced.
jsmith285 is offline Find More Posts by jsmith285
Old Jan 25, 2012, 11:22 PM
TossinHoss is offline
Find More Posts by TossinHoss
Whirly Bird Fanatic
TossinHoss's Avatar
United States, GA, Atlanta
Joined May 2010
Heli
I fly with a bunch of Heli Pilots and we all use 6S 2650 to 5000 MAH packs. Most use Deans connectors. I have a lot of Turnigy batteries that work great but another brand would be good to try too. I find the lower C batteries are usually the ones that I have issues with. There are several other new brands out there, Spyder, Pulse, NRG, etc..that I have seen people getting lately. I have a couple of NRG's for Nitro power supply. My most problematic batteries have been 30C Thunderpower packs that have puffed.
There are a lot of heli guys I know that would switch to dependable, well made and good rated packs with higher charge rates.
May have to see some of the prices online and try out a couple of 6S 3000MAH and 5000MAH packs as well as a 3S 2200.
Is there a chance you might offer connector choices??
Thanks for the info.
TossinHoss is offline Find More Posts by TossinHoss
Old Jan 26, 2012, 05:10 AM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
Spyder is not what I would call a new brand as I tested them over two years ago.
http://www.rcgroups.com/forums/showthread.php?t=1123338
Charles
Old Jan 26, 2012, 08:43 AM
jsmith285's Avatar
Fort Wayne
Joined Feb 2009
ours came with really good Bullet connectors. But we switched em to Deans.
They seem to be really well built.
And that Haiyin actually makes the cells impressed us.
Old Jan 26, 2012, 11:48 AM
Whirly Bird Fanatic
TossinHoss's Avatar
Joined May 2010
Charles
They did, but you could hardly ever find they had them in stock and I never saw anyone with them in the SE area.. Just meant they were not like the bigger manufacturers...
I've had a few Venom batteries but they tended to puff badly although I know they have some newer higher C rated ones now.
Is there a coupon code for the Haiyin site, they have a place for one? I'm thinking about getting a couple.
Old Jan 26, 2012, 01:42 PM
jsmith285's Avatar
Fort Wayne
Joined Feb 2009
There is a coupon spot when you check out. But I Do not know of any coupons.
Old Jan 26, 2012, 06:54 PM
The Tug is online now
Find More Posts by The Tug
Barbados
Joined Jan 2011
Well i just bought 4 of these to try em out,based on what you guys are saying,i presently run Nano Tec.
The Tug is online now Find More Posts by The Tug
Old Feb 02, 2012, 07:20 AM
jsmith285's Avatar
Fort Wayne
Joined Feb 2009
Been doing some actual side by side testing(actual flying testing) of the Haiyin batteries against the batteries we had been buying(same cell count, size and c rating). But there is noticeable more pull out and lasting power from the Haiyins. Noticeable even enough for spectators to visually see a difference.
Not mentioning the other brand. And yes same plane, put battery in, fly, change battery, fly.
Old Feb 02, 2012, 10:23 AM
Barbados
Joined Jan 2011
Good to know,shipping was very expensive considering a small box with 200g of LiPo's $28 bucks to the caribbean.They say they dont mark up on shipping so be it.
Old Feb 02, 2012, 10:49 AM
Southern Pride
FWIW My 20C 3S 800 mAh which I bench tested for a total of 51 cycles is now being flown in a flying wing which I have tried many different props on, some pulling over
20A static.........25C .
Current favorite prop pulls 13A turns 16K and comes down after 5 min. at 3.7 per cell. with no noticeable heating and no signs of fading. Cycle count now at 57 ,----51 bench and 6 flights.
Charles
Old Feb 02, 2012, 11:00 AM
keithy4129 is offline
Find More Posts by keithy4129
United States, NJ, Clayton
Joined Aug 2010
Charles
not too shabby
keithy4129 is offline Find More Posts by keithy4129
Old Feb 02, 2012, 11:32 AM
jsmith285's Avatar
Fort Wayne
Joined Feb 2009
Charles
That's what we are seeing too. No fading during the flight.
Old Feb 06, 2012, 03:32 PM
nippaero is offline
Find More Posts by nippaero
nippaero's Avatar
United States, ID, Nampa
Joined Oct 2009
Charge Rate?
What's the maximum charge rate on these packs? I am looking at the 6S 5000 40C.
nippaero is offline Find More Posts by nippaero
Old Feb 06, 2012, 04:19 PM
Southern Pride
6S 5000 is 20 , 25 and 30c on thier website and max. charge rate is 1.5C (7.5A)
http://www.haiyinstore.com/compares....=225+&PID=226+
Old Feb 06, 2012, 05:13 PM
sailr is offline
Find More Posts by sailr
Land O' Lakes, FL
Joined Aug 2003
I think they are just going on the side of caution when they specify the charge rate. I wouldn't hesitate at all to charge them at 3C. Some of the other companies boast you can charge up to 5C but I would never do it. The pack might take it but it ain't gonna last long.
I charge everything I have at 2C. No harm, no foul. The only time I use 1C is if I'm trying to revive a sick pack.
BTW, the 6S 5000 40C has a published charge rate of 3C. I'm not sure why the 20, 25, and 30C packs would only be 1.5C
sailr is offline Find More Posts by sailr
Discussion Welcome to our official Venom Group International / RC Groups product support forum! Chris Nicastro Venom 84 Feb 06, 2012 11:15 PM
Discussion Haiyin LiPo Batteries ggroyal1117 Batteries and Chargers 7 Dec 14, 2011 04:01 PM
Discussion RC groups on a Smartphone Scottmac737 Site Chat 4 Sep 27, 2011 01:56 PM
Discussion Bought some Bad Batteries off a guy at RC Groups DaveBC Trader Talk 26 Mar 09, 2011 05:11 PM
