Old Mar 01, 2013, 03:10 AM
785boats is offline
Find More Posts by 785boats
RELAX. You'll live longer
785boats's Avatar
Brisbane- Australia
Joined Jul 2007
I've got to agree with Jim on the cycling of packs.
I charge new packs, note down all the cell voltages & IR's, Then run it in a boat that I know has a lowish amp draw (around 60-80A) & only take it down to around 40% left in the pack. I do this a couple of times. Then I run it in a race boat down to around 30% a couple of times. The IR of the cells usually drops a bit over those runs.
I think that all of my race packs are Haiyin now because when an old HK pack fails I only buy Haiyin packs. Always 4s or 6s 5000mah 40c.
They win me races (when I drive properly) so I'm happy.
Cheers.
Paul.
785boats is offline Find More Posts by 785boats
Old Mar 01, 2013, 08:12 AM
sailr is offline
Find More Posts by sailr
Land O' Lakes, FL
Joined Aug 2003
Here is the correct link to the plastic caps I use on the 5.5mm male bullet connector:
http://www.stockcap.com/store/0.250-...p-100-Bag.html
sailr is offline Find More Posts by sailr
Old Mar 02, 2013, 08:18 AM
timmyt101 is offline
Find More Posts by timmyt101
Joined Feb 2013
Now that I've got the connectors figured out, I still would appreciate some suggestions on setting the low voltage cutoff. I've seen a lot of posts ranging from 3.25v to 3.8v and everything in between.
Eric sent me a great email regarding lipos and it indicates that the "suggested voltage range for Lithium Polymer cell is 3.0V-4.2V". I know that the resting/storage/discharge level should be 3.85v and I would never go to 3.0v, but what is a safe "low-end" so I can set my LVC alarm?
timmyt101 is offline Find More Posts by timmyt101
Old Mar 02, 2013, 09:14 AM
doug47 is offline
Find More Posts by doug47
United States, OH, Ashland
Joined Dec 2009
It's actually a lot of hair splitting. As long as you have it set for something in that range you will be fine,and if someone else is using a different number than you are you won't be missing out on any service life or performance.
I bought 4 5000mah 40c Haiyans over a year ago that go in a 12 cell heli set-up, they have somewhere around a hundred cycles in them and they are still A-1.
I have my LVC set at 3.3, though it's rare that I fly long enough to trigger the LVC.
Doug
doug47 is offline Find More Posts by doug47
Old Mar 02, 2013, 09:44 AM
RedOctobyr is online now
Find More Posts by RedOctobyr
United States, MA
Joined Jan 2011
Mine is at 3.2V. Find out what your ESC does when you hit LVC. If it just kills the motor, and this is an aircraft, be extra mindful of never triggering LVC.
It is really there as a last resort (you put on a discharged pack, forget to start your timer, etc). In an ideal world, you should never hit it. But set it too high (e.g. 3.6V) and you will hit it.
RedOctobyr is online now Find More Posts by RedOctobyr
Old Mar 02, 2013, 10:14 AM
Joined Feb 2013
doug47 & RedOctobyr...
Thank you very much for the input. My son & I are using the batteries in our 1/8th scale trucks, so no falling out of the sky. However, I like the idea of the LVC for those times when we are racing around the desert and lose track of time. The Castle Creations controller is programmable and I want to set it high enough to not hurt the lipos, but not so high that we are cut off too quickly - it's really easy to be racing around and not realize how much time has gone by. I think we will start at 3.5v, see how the run times are, and go from there.
Old Mar 02, 2013, 11:10 AM
sailr is offline
Land O' Lakes, FL
Joined Aug 2003
I prefer to sent my LVC a little higher, around 3.6V. At that point, you are on the rapidly declining end of the power curve anyway. I also always set my ESC for soft or slow cutoff. This means the motor will slow down rather than cutting off suddenly.
If you use 3.2V cutoff and then try advancing the throttle again to 'make it to the field', you risk taking the cells down too low and inducing possible 'puffing' of the cells and a hot battery.
Old Mar 02, 2013, 11:12 AM
brushless55 is offline
Find More Posts by brushless55
big ignore list
brushless55's Avatar
United States, CO, Longmont
Joined Nov 2011
if you set your LVC so that your resting volts show 20% or more left in the packs you are good to go..
it all really depends just how much amps your systems pulls vs LVC settings...
brushless55 is offline Find More Posts by brushless55
Old Mar 02, 2013, 11:40 AM
Wayne Giles is offline
Find More Posts by Wayne Giles
Rugby, UK
Joined Feb 2007
Sailr,
Not wanting to start an argument but I really think that 3.6V is too high. The unknown is the load which will determine the point at which the Esc starts to close it down, but if you are using the lipos at any where near their current delivery capacity, then 3.6v is too high.
I have recently posted a load test on the Haiyin 3S2200 20c pack discharged at 20C and you can see from the discharge plot that at 3.6V. (10.8V for a 3S pack) the pack is only about 25% discharged.
http://static.rcgroups.net/forums/at...0%40%2020C.jpg
The best way is to time the run as we generally fly or drive in a consistent fashion, and aim for the 80% discharge rule, using the Esc cutoff as a safety valve, but set to about 3.3V
Wayne
Wayne Giles is offline Find More Posts by Wayne Giles
Old Mar 02, 2013, 06:14 PM
big ignore list
Joined Nov 2011
Originally Posted by Wayne Giles View Post
Sailr,
Wayne
better packs need a higher LVC set... to low and the pack may be drained to much
Old Mar 02, 2013, 06:53 PM
United States, MA
Joined Jan 2011
It also probably varies by the application. I've only used LiPos (and a logging ESC) in a helicopter.
Helis have to use comparatively small batteries (too large and you couldn't get off the ground), and can have pretty high current drains. I've hit peaks of around 30C with my current setup (which admittedly isn't terribly aggressive). Let's say 10C average, to pick a number.
Small packs and fairly high intermittent loads are more likely to have deeper voltage sags (so if I used a 3.5V or 3.6V LVC, I'd probably hit it fairly often). After hitting a 3.2V LVC, the cells might be at 3.6V after resting (hypothetical numbers).
Something like a car/truck model might be different? I presume larger capacity packs can be used, since weight is less critical. I don't know what kind of currents they pull, and what those are in terms of C.
If a car pulled a consistent 3C, for discussion, it wouldn't have voltage sags as deep. As a result, you'd want a higher LVC number. If a car hit a 3.2V LVC, maybe the cells would be at 3.3V after resting (again, hypothetical).
Old Mar 02, 2013, 08:38 PM
scott page is offline
Find More Posts by scott page
ຮັກລູກຊາຍຫລາຍ
scott page's Avatar
United States, WA, Richland
Joined May 2009
Get a bag of red and a bag of another color -- use them to ID charged and discharged batteries. Just saying....
scott page is offline Find More Posts by scott page
Old Mar 21, 2013, 06:08 AM
MikeCr is offline
Find More Posts by MikeCr
United States, WI, Slinger
Joined Mar 2006
I need some new batteries and have been trying to decide who to go with. Finally pulled the trigger and ordered some Haiyin's, a couple of 3S 25C 2200mAH and a 6S 25C 5000mAH pack for my Swift heli and the Astrohog I'm building. Can't wait to see how they do.
MikeCr is offline Find More Posts by MikeCr
Old Mar 21, 2013, 06:15 AM
mattox is offline
Find More Posts by mattox
mattox's Avatar
peoria,az
Joined Sep 2009
Please tell us how they perform when you receive them!! All my 6s 5000 packs are still going strong!
mattox is offline Find More Posts by mattox
Old Mar 21, 2013, 06:51 AM
FlyinCowboy is offline
Find More Posts by FlyinCowboy
Life Is Good.
FlyinCowboy's Avatar
Texas
Joined Jan 2011
I'll be running these just as soon as I get the plugs changed over to EC3's.
FlyinCowboy is offline Find More Posts by FlyinCowboy
Discussion Welcome to our official Venom Group International / RC Groups product support forum! Chris Nicastro Venom 84 Feb 06, 2012 11:15 PM
Discussion Haiyin LiPo Batteries ggroyal1117 Batteries and Chargers 7 Dec 14, 2011 04:01 PM
Discussion RC groups on a Smartphone Scottmac737 Site Chat 4 Sep 27, 2011 01:56 PM
Discussion Bought some Bad Batteries off a guy at RC Groups DaveBC Trader Talk 26 Mar 09, 2011 05:11 PM
