This thread is privately moderated by Donaldsneffe, who may elect to delete unwanted replies.
Old Nov 14, 2011, 02:06 AM
Donaldsneffe is offline
Find More Posts by Donaldsneffe
Vienna calling...
Donaldsneffe's Avatar
Österreich, Wien
Joined Aug 2010
Nine Eagles Solo Pro 100 3D (3G)
Only some pics - will update with more info and mods.
Main gear is a PITA. Fixed with a screw, damaged easily. It is 0.5 mm larger in diameter than Blade mCP x main gear (20 mm : 19.5 mm), so mCP x gears wont fit to the Nine Eagles Solo Pro 100 3D.
Donaldsneffe is offline Find More Posts by Donaldsneffe
Old Dec 18, 2011, 07:26 AM
Alindur is offline
Find More Posts by Alindur
Joined Dec 2011
you said mcpx gear cna be used cause it is smaller but if i move with motor it can fit.Only thing i dont know if gear fit on shaft.I dont want order it if i dont know if it fit.So is diameter of shafts same?
Thanks for reply
Alindur is offline Find More Posts by Alindur
Old Dec 18, 2011, 11:03 AM
Vienna calling...
Österreich, Wien
Joined Aug 2010
Hi,
yes - shaft diameter is the same (3 mm).
I said, mCP x spare main gear (after market) from AEO will work - it's little larger diameter than original mCP x gear and Xtreme gear.
Those ones:
http://www.modellbau-lenz.at/onlines...100d4c4f2d0ac6
http://www.hawk-rc.com/index.php?rou...product_id=594
Bought mine at AstroidDesigns - but they do not have them anymore (cause not good for mCP x).
Walter
Old Dec 18, 2011, 02:34 PM
Alindur is offline
Joined Dec 2011
Great, it is sad they have expensive shipping .Will look for them or wait for original solo pro.
Thanks for help
Old Feb 10, 2012, 10:23 AM
rcfr is offline
Find More Posts by rcfr
Joined Jan 2012
Thanks for help
Hi,
Replying on this old discussion: just to make sure I understand - the 2 links above are for main gear from mcpx that DO FIT to the 100D, right?
Alindur, did you find any other place to buy those gears from?
Thanks.
rcfr is offline Find More Posts by rcfr
Old Feb 10, 2012, 12:11 PM
Vienna calling...
Österreich, Wien
Joined Aug 2010
Year, they fit.
But meanwhile SP 100 spares are available in numerous shops - so it is not necessary anymore to use mCP x gears.
Walter
Old Feb 11, 2012, 01:55 PM
rcfr is offline
Joined Jan 2012
Originally Posted by Donaldsneffe View Post
Year, they fit.
Walter
Price-wise, you might want to...
Old Feb 17, 2012, 07:51 AM
madmito is offline
Find More Posts by madmito
my precious Corter
madmito's Avatar
Joined Jan 2012
so the gear has to be at least 19,75mm if I'm getting this correctly ?
madmito is offline Find More Posts by madmito
New Product Nine Eagles Solo Pro 100D / Solo Maxx 3D Frank_fjs Micro Helis 1873 Jan 17, 2016 01:29 AM
New Product Nine Eagles Solo Pro 328 (Nine Eagles' answer to the Blade 120 SR?) SoloProFan Micro Helis 1758 Feb 27, 2015 04:24 PM
New Product Nine Eagles Solo Pro 180 3D SoloProFan Micro Helis 826 Feb 24, 2014 09:19 AM
Discussion Nine Eagles Solo Pro 180 3D RTF @OOMODEL oomodel.com Mini Helis 0 Sep 13, 2011 09:41 PM
