In actual practice the rig is accurate for the results I want. low speed thrust Speed on indoor aerobats is not required - any speeds over 5 meters per second are excessive. I guess I may setup a wattmeter with connectors for the really little stuff but . I now have a feel for combos which work- and the motors which are available set the stage for weights which are practical Do you fly this stuff? It's quite interesting |
No, but it sounds interesting.
Static thrust measurements are not distinguishing. What you really need is Watts input to the motor and motor torque. With that you can calculate motor efficiency. I suspect that very small motors take an efficiency hit. Perhaps, I will buy one and do some measurements. Tom |
Joined Sep 2007
I'm glad I thought to ask your elevation. I was at 170'. That explain a lot! Just as a rough estimate you had 12-14% less power. It has been over 30 years since I have flown control line and I don't recall what the chord length was or what the speeds were, so who knows what our Reynolds number would have been compared to yours. A true airfoil was the fastest at 170'.
you look at watts and oz thrust - then just compare . believe it or not the prop really does not matter for this testing the result is simply watt to thrust -good enough. eficiencies run about 90% at best now - the little super cheap brushed motors I use for one ounce models are less. calculating prop efficiences is a waste of time- actual results are the only meaningful method |
The Willamette Valley, Oregon
Joined Dec 2008
pressure distributions around airfoils
* Lots of readers on this forum with a wide range of modelling interests-- I suppose you are meaning slow-flying RC or freeflight indoor planes or park flyers? * Would be interested to hear more about what you are basing your conclusions on. Tried spoilers on the top of the wing and they didn't work? Or is it purely a gut feeling? * After all, even a flat plate could, hypothetically, generate a larger low-pressure surface on top than a high-pressure surface on the bottom. I don't know if this is true or not, or if the answer is strongly dependent on Reynolds number, I'm just saying it could be true. Surely someone can dig up a plot for the pressure distribution around a flat-plate airfoil at various Reynolds numbers? Hang on, here we go http://www.windsofkansas.com/atoz2.html The author is writing about dragonfly wings. In developing the theory, he includes figs 5 and 7-- pressure distribution around flat plate, and pressure distribution around flat plate bent into a cambered airfoil shape (zero thickness)-- in both cases the low-pressure area above the wing appears to make a greater contribution to lift than the high-pressure area below the wing. An even better picture is given in Figure 1 http://www.windsofkansas.com/Fig1AtoZ3.jpg of the following link by the same author: http://www.windsofkansas.com/atoz3.html Last week I posted this link: http://wind.nrel.gov/public/library/3387.pdf See pp 19-21 Especially airfoil 3 in diagram 14-- pressure plot of top and bottom surfaces-- Airfoil optimized for low-speed low-Re -- airfoil is thin (but also cambered) (because airfoil is thin, bottom surface ends up being undercambered.) The supporting text (pp. 20-21) says that "Airfoil 3 produces lift from high pressure on the lower surface." However I can't see that the pressure plot supports this conclusion. Looks to me like if we draw a horizontal line at "1" on the pressure plot, and assume that this line represents the free-stream velocity or pressure, then there is roughly equal or maybe even more force generated by low pressure (high velocity) on the top surface, than there is force generated by high pressure (low velocity) on the bottom surface. Just comparing the area "trapped" above the horizontal line and below the top-surface pressure curve , versus the area "trapped" below the horizontal line and above the bottom-surface pressure curve-- these two areas look about the same to me on the graph. What am I missing? * On another note, here is some interesting reading re an airfoil that uses flat plates rather than curved surfaces for most of the outline of the airfoil (but not particularly relevant to slow flight, also not spectacularly different from a more standard airfoil, just kind of interesting reading http://www.eaa1000.av.org/technicl/onedesaf/1desaf.htm Steve |
However for what I am after -which is thrust in excess of the model weight - the test is valid Simple comparison data is all I need - The argument that static thrust is is meaningless is familar I could use calibrated prop and check rpm against a scale and compensate for altitude temp etc.. I simply don't need more info than the power in vs thrust (the load ) I like to keep things simple |
New York
Joined Oct 2008
naturally we tend to think everyone flies the same type wings we do but in fact there is a most common one. hint: it aint pylon racing, edf, or dlg. for example just now i went to the most active rcgroups forum (scratch foamies) and looked at the largest thread on page one (blu baby). 18,000 posts with most others only a few dozen or hundred. guess what type wing i found? ![]() this exemplifies wing type found on most rc models, be it scratchbuilt, horizon parkflyer, bnf, um, indoor rtf, silverlit toy, lrf, ect etc.. there is a reason we gravitate to the undercambered single surface and it aint necessarily economy. some of those models cost hundreds of dollars. so we can go on and on about dragonflies, 747s, hummingbirds and rogallo hang gliders but my comments generally refer to the kind of wings most rc hobbyists are concerned with. Quote:
as ive said from the beginning theres obviously low pressure forces at work on the top. but so far i see little evidence this results in lions share of lift. edge effects, flow efficiency, vortex separation, blabitty bloobitty blah blah blah. notice, again, im no longer referring to those top forces as bernoulli because bernoulli is an over-used word and since bernoulli may not be the only principle in effect here i will refrain from saying bernoulli too often. note that another reason to avoid the term bernoulli is because the old school equal transit guys used bernoulli a lot and we dont want to be associated with them. you wont hear me saying bernoulli, at least not very often. ps i also agree with rh that thrust/watt is most useful info when trying to develop efficient power sytems. not so much for trying to look smart on forums or endlessly arguing about aerodynamic theories to ward off the lonliness. |
A lot of info can be gathered by using a simple model -the VAPOR- andthen spending a few hours in a gym ,flying the model at all speeds and workable angles of attack.
Any plate which produces a pressure difference top to bottom is a wing it can be flat or curved or painstakingly shaped to an exact shape as dictated by load/speed n size ALL of the othe r info , Bernoulli ,Coanda Newton etc., describe some of what is going on and is necessary if one likes to calculate stuff. Bottom line- lift is simple a result of pressure differential at work trying to decide wether the top does more than bottom seems to me to be a waste of time Monday I was doing trimmed ,hands off flight and the model was ever so slightly climbing. I added a touch of down trim - the climb rate increased |
Joined Dec 2008
Curving relative wind, maneuvering point, pitch stability
For more, (or to discuss/ comment), please see the new thread "Curving relative wind, maneuvering point, pitch stability" http://www.rcgroups.com/forums/showthread.php?t=1617808 Steve |
| Thread Tools | |
| Discussion From whom can we rent a pool to run boats? | LouScarlino | Dock Talk | 12 | Nov 11, 2011 06:41 AM |
| Discussion loading down a T-28 Trojan, or Taking Pictures From the Air | nemoskull | Indoor and Micro Models | 3 | Sep 19, 2011 02:22 AM |
| Discussion Can we build something like this from scratch? | mrexcel | Foamies (Scratchbuilt) | 6 | Jul 07, 2011 01:55 PM |
| Discussion Can we move on from choo choo trains now? | plowboy1966 | Life, The Universe, and Politics | 26 | Mar 31, 2011 08:34 PM |
| Help! Can we get 1S power from 2S LiPo? | Merog | Batteries and Chargers | 11 | Mar 08, 2011 01:48 PM |
