Old Nov 18, 2011, 10:59 AM
Tim Green is offline
Find More Posts by Tim Green
Launch the drones ...
Ashtabula, OH USA
Joined May 1999
I think too many of us, succumb to what we learned in school - Bernoulli - and it's hard to shake that off. It's in our blood. Even in the face of experiments, showing it's the air that's expelled by a system, that determines lift. I don't see any of you having a hard time with this, if you weren't first taught the wrong thing. I went throught it too. But the Bernoulli explanations just weren't clicking. Too many unexplained facts (such as choppers throw down tremendous amounts of air, such as when you redirect that air, you change the lift vector). So, I kept at it. Now I'm trying to convert others. It's been hard to do. So, I largely keep to experiments, as these are incontrovertible, whereas long verbal explanations, well, they're long verbal explanations, subject to interpretation, and not much fun. Experiments are fun though.
Tim Green is offline Find More Posts by Tim Green
Old Nov 18, 2011, 11:08 AM
ciurpita is offline
Find More Posts by ciurpita
greg
ciurpita's Avatar
somerset, nj
Joined Feb 2005
Originally Posted by Tim Green View Post
You said it both ways - and you cannot have it both ways. Either it's relevant, or it's not. And so far, experiments prove it's always relevant. Always - an object moves opposite the direction of any air it exhausts.
Someone took a box. Cut three holes in the front, and put the box on wheels. Then they took a fan, attached it to the middle hole in the box, such that the fan was blowing into the box. Bernoullists would claim that the box would move forward, pulled by the fan. But the experiment showed the box moving backward, propelled by the air it was expelling through the other two holes.
Block the two exhaust holes, and the box doesn't move at all. Bernoulli alone, cannot move the box.
This experiment, plus the chopper with the plate - prove Bernoulli ain't lifting nuttin.
No one on this forum, has come up with a chopper experiment, showing Bernoulli only lift, or any Bernoulli lift. But we can come up with an infinite number of experiments showing the following ...
A. No have lift without throwing air down.
B. The direction of an object's thrust vector is determined by the direction of the air leaving the object. (not the direction of any props, rotors, fans, etc., moving air into the object)
And rotors are wings - which is why fans and choppers make this work so easy - if you don't disregard the experimental data.
i thought i agreed with you
ciurpita is offline Find More Posts by ciurpita
Old Nov 18, 2011, 11:10 AM
Steve Anderson is offline
Find More Posts by Steve Anderson
Joined Sep 2007
Steve Anderson is offline Find More Posts by Steve Anderson
Old Nov 18, 2011, 11:15 AM
stardustertoo is offline
Find More Posts by stardustertoo
Canada, AB, Red Deer
Joined Apr 2010
Like the ones I have been asking you about and you have not answered for me (maybe you don't have an answer, I don't know) regarding the air pressure "sucking" the air causing the acceleration. I, like you, look at an explanation for something and see something missing, and want to know why.
Seems like you are wrong, your experiments have been interpreted 2 different ways, and have caused lots of "controversy" on this forum.
Well, as I can not get a straight answer out of you, and you refuse to actually discuss anything other than your idea....well, good luck, have fun.
I tried to understand your idea this time, you simply blocked out my attempts to see your point of view.
stardustertoo is offline Find More Posts by stardustertoo
Old Nov 18, 2011, 11:43 AM
DPATE is offline
Find More Posts by DPATE
Grad student in aeronautics
United States, GA, Atlanta
Joined Oct 2010
And in the other case, the chopper doesn't deflect the airflow, due to the plate being folded.
But the box blocks the flow in the same way as the plate....meaning the paths the air particles take is the same in both cases. If you can't agree to this then I can't reason with you.
DPATE is offline Find More Posts by DPATE
Old Nov 18, 2011, 02:35 PM
Victory Pete is offline
Find More Posts by Victory Pete
Rhode Island USA
Joined Aug 2010
Bernoulli in my Brain!
I did a Science Project in Middle School (1979) about "How a plane flys". Bernoulli has been in my mind ever since. However since I have been flying RC planes for the last 2 seasons, I kept wondering "How does that explain a plane flying upside down"? Not to mention symetrical airfoils! You have my attention!
VP
Victory Pete is offline Find More Posts by Victory Pete
Reply With Quote  (Disabled)
Old Nov 18, 2011, 02:40 PM
Jim Thomerson is offline
Find More Posts by Jim Thomerson
Newton tells us F=MA Translated for flying, Lift=mass of air x acceleration of that mass in a downward direction.
Jim Thomerson is offline Find More Posts by Jim Thomerson
Old Nov 18, 2011, 06:05 PM
ciurpita is offline
greg
ciurpita's Avatar
somerset, nj
Joined Feb 2005
in herks' box, does the box move due to the outflow of air (pressing against what?), or because there is increased pressure inside the box and there is less surface for the air to press against on the side with the openings (including the fan)? would the box move differently if the openings were bigger/smaller (than the area of the fan)?
hasn't someone already said you have to consider all the forces affecting (contacting) the system?
Old Nov 18, 2011, 06:41 PM
Windrider53 is offline
Find More Posts by Windrider53
United States, CA, Sacramento
Joined Mar 2006
WoW, I give up. I was going to draw some pretty pictures showing the air flow from the copter blades and how it bends when it reaches either the plate or the box (or the floor) but this (Censored) idiot is so ignorant and at the same time sure if his misinformation that there is no proving *anything* that differs with his illusions.
Windrider53 is offline Find More Posts by Windrider53
Old Nov 18, 2011, 08:19 PM
Ashtabula, OH USA
Joined May 1999
Whoops (oops).
Old Nov 18, 2011, 08:26 PM
Ashtabula, OH USA
Joined May 1999
If you put the exit holes somewhere else, the box moves opposite the side the holes are on.
Proving the box moves in response the the air it's expelling. Not the air it's taking in.
Old Nov 18, 2011, 08:29 PM
Ashtabula, OH USA
Joined May 1999
Box isn't attached - plate is.
Old Nov 18, 2011, 08:30 PM
Ashtabula, OH USA
Joined May 1999
Box is irrelevant - this experiment works the same if you run the experiment on a grating.
Old Nov 18, 2011, 08:32 PM
Ashtabula, OH USA
Joined May 1999
Oh well - some people cannot let go of Bernoulli - like an old friend.
Old Nov 18, 2011, 08:33 PM
Ashtabula, OH USA
Joined May 1999
Originally Posted by Steve Anderson View Post
Tim,
You need to re-read this thread from 2003 that you were involved in. Note post #24 by Mark Drela.
http://www.rcgroups.com/forums/showthread.php?t=135318
Don't see your point.
Discussion From whom can we rent a pool to run boats? LouScarlino Dock Talk 12 Nov 11, 2011 06:41 AM
Discussion loading down a T-28 Trojan, or Taking Pictures From the Air nemoskull Scratchbuilt Indoor and Micro Models 3 Sep 19, 2011 02:22 AM
Discussion Can we build something like this from scratch? mrexcel Foamies (Scratchbuilt) 6 Jul 07, 2011 01:55 PM
Discussion Can we move on from choo choo trains now? plowboy1966 Life, The Universe, and Politics 26 Mar 31, 2011 08:34 PM
Help! Can we get 1S power from 2S LiPo? Merog Batteries and Chargers 11 Mar 08, 2011 01:48 PM
