Please note also how far back the stagnation point is at high angles of attack, and how on a portion of the airfoil the air actually travels in the opposite direction of the wind tunnel airstream, so strong is the pressure difference between the two surfaces of the profile
Tim,
As already pointed out, NASA did not say lift is the result of "shoving air down".. They said it's the result of "turning air", not the same thing at all. Fact is that the air in front of a wing is turned upward then as it passes the wing it's turned downward, and then (in 2D flow) it turns again to level out to the same height as it was before being disturbed by the wing in the first place, no net downwash. You can quite clearly see this if you follow the streamlines in NASA's 'Foilsim' 2D flow simulation program (taken from the same site where you got your miss-quote): http://www.grc.nasa.gov/WWW/k-12/airplane/foil2.html (also see attached screen shot) 3D flow would look a little different, you would have some downwash in the wake of the wing, the amount of downwash being dependant on Cl and aspect ratio. This downwash would be matched by upwash around the tips (again no net downwash) |
Ashtabula, OH USA
Joined May 1999
This clearly proves that the plate is different from the ground. Until you admit what the experiment shows, you are blowing in the wind. |
Ashtabula, OH USA
Joined May 1999
Fort St. John, BC
Joined Apr 2010
So, that does raise another question though. With this theory in mind, can you explain how a Laminar flow airfoil is working?? If it is one of the true laminar flow foils, it should not have said "vacuum", especially if it is...say...in a slow descent to a lower altitude (reduced angle of attack). Actually, while I am thinking of it, a Clark Y has a zero lift angle of something like NEGATIVE 4-5 degrees AoA (from a NASA paper on testing the Clark Y), so anything greater than that it will lift, which doesn't really fit well with your theory, can you explain that for me?? |
Fort St. John, BC
Joined Apr 2010
Hey, just thought of one other thing that I am curious about in regards to your vacuum behind the wing idea Tim. Wind tunnel testing has shown that the low pressure area also extends some way ahead of the leading edge. To me this would shoot your idea down in flames, but maybe you have a reason for that.
Like I said, I really am truly curious about this theory. Never heard it before so I want to hear more about it. |
| Thread Tools | |
| Discussion From whom can we rent a pool to run boats? | LouScarlino | Dock Talk | 12 | Nov 11, 2011 06:41 AM |
| Discussion loading down a T-28 Trojan, or Taking Pictures From the Air | nemoskull | Indoor and Micro Models | 3 | Sep 19, 2011 02:22 AM |
| Discussion Can we build something like this from scratch? | mrexcel | Foamies (Scratchbuilt) | 6 | Jul 07, 2011 01:55 PM |
| Discussion Can we move on from choo choo trains now? | plowboy1966 | Life, The Universe, and Politics | 26 | Mar 31, 2011 08:34 PM |
| Help! Can we get 1S power from 2S LiPo? | Merog | Batteries and Chargers | 11 | Mar 08, 2011 01:48 PM |
