Old Nov 22, 2011, 01:03 PM
Sparky Paul is offline
Find More Posts by Sparky Paul
Ascended Master
Sparky Paul's Avatar
Palmdale, CA
Joined Oct 2000
Originally Posted by Taurus Flyer View Post
Of course you make pictures of that while the chopper is separate placed on floor, on his own legs and the plate on the scale! So you only measure the force as result of the dynamic pressure on that plate!
Fix that chopper on the floor so it cannot fly away!!
Cees
What the hell does that prove?
Sparky Paul is offline Find More Posts by Sparky Paul
Old Nov 22, 2011, 01:08 PM
Ascended Master
Palmdale, CA
Joined Oct 2000
Originally Posted by Sparky Paul View Post
Lemme put the thing on a scale and see what happens...
Dun!
On the scale, taped to the flat plate, the thing weighs 1.65 oz.
Turn the motor on to maximum power, the weight on the scale drops to 1.25 oz.
It can't take off.
Remove the plate, the weight drops to zero as the heli takes off..
Going through .9 oz on the way to zero...
Old Nov 22, 2011, 01:17 PM
Tim Green is online now
Find More Posts by Tim Green
Launch the drones ...
Ashtabula, OH USA
Joined May 1999
Originally Posted by slipstick View Post
Nope you're still confusing cause and effect. They generally demonstrate that when there is lift happening there is also some downward air flow happening. No causality proved or even indicated.
Steve
If this air wasn't lifting the chopper, redirecting the air wouldn't redirect the choppers lift vector.
Tim Green is online now Find More Posts by Tim Green
Old Nov 22, 2011, 01:28 PM
Ashtabula, OH USA
Joined May 1999
Dun!
It can't take off.
Neat!
A larger plate will reduce the weight drop more, as some air will get by the current plate.
Also, though difficult to do, moving the plate closer to the rotors will also be effective in reducing the weight drop.
IOW, there's some air still being used in lift - it's not all being redirected sideways by the plate - we could see that in the way the chopper bounced along the ground with the plate attached - obviously, it was lighter with the rotors on.
This would be more accurate using a ducted fan in a tube, as no air would escape. I'd take the tube, and redirect the air sideways, and make those same measurements you made today.
Steve Anderson is offline
Find More Posts by Steve Anderson
Joined Sep 2007
Steve Anderson is offline Find More Posts by Steve Anderson
Old Nov 22, 2011, 01:33 PM
Ascended Master
Palmdale, CA
Joined Oct 2000
Originally Posted by Steve Anderson View Post
Scale needs to be on grams for Bernoulli lift. Duh!
We fought that war to among things not use Frog yards!
Old Nov 22, 2011, 01:34 PM
Ascended Master
Palmdale, CA
Joined Oct 2000
Originally Posted by Tim Green View Post
Neat!
With the round rotor diameter plates, the helis don't hop at all!
The rectangular plates let some of the air get underneath the plate.
Old Nov 22, 2011, 01:55 PM
Joined Sep 2007
Old Nov 22, 2011, 01:59 PM
Taurus Flyer is offline
Find More Posts by Taurus Flyer
I bail out, anywhere, anytime
Taurus Flyer's Avatar
The Netherlands, OV, Almelo
Joined Nov 2010
Sparky, don't you understand?
I did explane in that earlier post I am only interested in the dynamic pressure of the airflow.
By measuring the force on the scale and knowing the surface dimensions we can calculate the pressure. And that is the same as the pressure that is shown with a pitot tube. Only the pitot tube does need a few square mm's and you a whole plate.
That's why I use a pitot tube on my plane an not a l.p.
Cees
Taurus Flyer is offline Find More Posts by Taurus Flyer
Old Nov 22, 2011, 02:53 PM
Ascended Master
Palmdale, CA
Joined Oct 2000
All I'm doing is answering the question can a heli with a large plate attached to the skids lift off.
It can't.
Why, is the downwash from the rotor impacts the plate.
That's all.
How much?
In this case, there's a 1.2 oz shortfall in lift.
No lift, no fly.
Any one pitot-static and total pressure sensors I worked with in L-1011 Flight Test weigh more than all my helis combined.
And I'm hardly going to overkill this trying to get some very low "dynamic pressure" readings from those things.
The helis can't take off with the plate.
Old Nov 22, 2011, 02:56 PM
Joined Nov 2010
A little research and you can learn a lot. Wikipedia says Daniel had a fear of plates. So, Newton=lift=Berneulli until you tape the plate on and it scares away Bernoulli.
Steve,
When you mount that plate under a rocket it will not lift off either.
Cees
Old Nov 22, 2011, 03:07 PM
Montag DP is offline
Find More Posts by Montag DP
Sink stinks
Montag DP's Avatar
Joined Apr 2005
Originally Posted by kcaldwel View Post
Actually, the pressure behind a building in a wind, or moving car or van, is not at a low pressure.
Kevin
These objects experience completely separated flows in the wake, which certainly does result in a low pressure. That's where the increase in drag comes from.
Montag DP is offline Find More Posts by Montag DP
Old Nov 22, 2011, 03:55 PM
ciurpita is offline
Find More Posts by ciurpita
greg
ciurpita's Avatar
somerset, nj
Joined Feb 2005
Yes, there is down wash behind a wing.
from post #132 with the video of the tuft behind the trailing edge
isn't this agreeing that the video demonstrates air is forced downward when lift is generated?
of course the angle is small. if the air moves downward in the vicinity of the airplane at only 0.5 fps and the plane is traveling at 10 fps, the angle is only 3 deg.
greg
ciurpita is offline Find More Posts by ciurpita
Old Nov 22, 2011, 04:24 PM
Victory Pete is offline
Find More Posts by Victory Pete
Rhode Island USA
Joined Aug 2010
The plate on the skids experiment is very interesting. if I was asked what would happen before I ever witnessed it I would say that it would not lift off. It would be my instinct. The force of the down thrust is simply pushing the heli back down, cancelling the thrust.
VP
(Like blowing your own sail!)
Victory Pete is offline Find More Posts by Victory Pete
Reply With Quote  (Disabled)
Old Nov 22, 2011, 04:26 PM
Joined Nov 2010
VP
VP
Cees
Discussion From whom can we rent a pool to run boats? LouScarlino Dock Talk 12 Nov 11, 2011 06:41 AM
Discussion loading down a T-28 Trojan, or Taking Pictures From the Air nemoskull Scratchbuilt Indoor and Micro Models 3 Sep 19, 2011 02:22 AM
Discussion Can we build something like this from scratch? mrexcel Foamies (Scratchbuilt) 6 Jul 07, 2011 01:55 PM
Discussion Can we move on from choo choo trains now? plowboy1966 Life, The Universe, and Politics 26 Mar 31, 2011 08:34 PM
Help! Can we get 1S power from 2S LiPo? Merog Batteries and Chargers 11 Mar 08, 2011 01:48 PM
