Old Nov 13, 2011, 03:20 PM
yodafm1e is offline
Find More Posts by yodafm1e
JediBiker
Tomah, Wisconsin, USA
1/18 Turnigy Racing Kart
I have one of the larger Turnigy Go-Karts, pics shown.
I see a lot of info and frustration on the 1/18 regarding motors and gears,. so I will tell you all what I will be doing,...I am going to use the motor and ESC off the Thunder Tiger KT8,...but the pinion in the 1/18 Kart kit..
The motor is an IBL 22/55-370C, 2mm shaft, 22.5mm diameter x 55.5mm length,..5500Kv. It has 2 sets of mounting holes, and one is 14mm. The bearing boss is 10mm diameter. So what I did was open the boss area just a little, to accommodate the motor.
Pitch is not an issue on these pinions they are the same.
The pinion having an I.D. of 2.3mm, and the motor shaft being 2mm in diameter, we have .3mm eccentricity.
This is really not at issue at this diametral pitch. It would be if the gearing was 64DP, but itís
48. Worst case scenario, the pinion spins eccentric at .012 of an inch, it is barely negligible.
Donít worry about it, make the best mesh you can, and tighten it done.
Also with the mildest loctite you have, do all screws that go into aluminum. Especially
the one that holds the idling gear assembly. Be extra careful on that one, not to over tighten, but, get it seated to the bearing races so it does not wobble, and let the loctite set.
If you are worried about the motor shaft and pinion not being concentric, dial the
difference in on your Calipers, you will see what I mean,Ö negligible!!
Enjoy the pics,
Michael,Ö
yodafm1e is offline Find More Posts by yodafm1e
Last edited by yodafm1e; Nov 18, 2011 at 01:21 PM. Reason: add pics with all 3 Karts
Old Nov 13, 2011, 05:06 PM
spikey-1 is offline
Find More Posts by spikey-1
Joined Oct 2008
Nice I'll have to come over and see them in person. Did you get your nitro kart running right yet?
Mike.
spikey-1 is offline Find More Posts by spikey-1
Question Team Edge RC indoor Kart racing? Team Edge RC Large Scale Cars 244 Mar 27, 2013 08:42 PM
Discussion Nitro Racing Kart, Live Axle, Chain Drive, Disc Brakes, Recoil Start CONDOR2 Nitro and Glow Power Cars 1 May 19, 2011 08:52 PM
For Sale Thunder Tiger - KT8 Racing Kart RTR 2.4Ghz 1:8 Scale duke714 Cars - Cars and Parts (FS/W) 3 Oct 08, 2010 11:41 AM
Discussion OT: Great video of the 1/10 scale Cross Fire Kart RC Kart Akura2 Motorcycles 12 Feb 18, 2010 12:17 AM
Discussion Indoor 1/18 & 1/16 Racing At Hobby Town USA fastmax Micro Cars 7 Oct 27, 2009 11:18 AM
