Old Nov 13, 2011, 01:21 PM
ken_nj is offline
Find More Posts by ken_nj
GSMB Member
ken_nj's Avatar
United States, NJ, Howell
Joined Mar 2008
Build Log
USS Marlin from Subtech
Hey all. I'm typically a surface model builder and my current model is scratch built and still under construction, maybe 95% done. I'm getting the itch and since it is cooler here, I'm going to start a new project while I'm hopefully finishing up on the other model. Has anyone else started another one when the first was not done yet? I have a USS Marlin that has been sitting in my shop for years that I got from Skip. I've known Skip for 20+ years and I'm not going to bug him on this so I'm going to rely on you experts since a sub is new to me.
Looking at what others have done with all of the WTC's and sub drivers and other things for submarine's, those topics are beyond me at this point. I am building this kit as is out of the box the way it was. Nothing fancy and using pretty much the stock parts. Near the end I have some ideas on mods for the kit, but until I get that far this thread will probably be good for a novice in submarines with me being one of them.
ken_nj is offline Find More Posts by ken_nj
Old Nov 13, 2011, 05:47 PM
ken_nj is offline
GSMB Member
ken_nj's Avatar
Joined Mar 2008
Instructions page 4 & 5
I posted the instructions on post #20 if anyone wants to follow along on this build.
I am not one to keep a log or document my hours, but it looks like I'm going that way with this build log. Spent about 3 hours, mostly removing the excess plastic from the UPH and LPH. The upper one kept about 1/16" to hold the future gasket as per the instructions.
Two items of concern.
-Where the motor inserts into ballast tank base. Looks like it might split. I could add some silicone on the top of it to keep it sealed.
-And the UPH sort of sits on top of the mounting bracket screws of the LPH. Once the gasket is attached to the UPH it should elevate the UPH up away from the screws.
Thoughts on these two problems?
Old Nov 14, 2011, 09:59 AM
Jcopter is online now
Find More Posts by Jcopter
Jcopter's Avatar
United States, CA, Downey
Joined Jun 2005
I built one it makes for a nice model. got mine from skip too. it is a lot of work, much cutting, but worth it in the end. I did not use skips innerds, I had it in my albacore and built my own tube. I like my marlin it is a nice size and you can get lots of details
Enjoy!!!!
Jcopter
Jcopter is online now Find More Posts by Jcopter
Old Nov 14, 2011, 11:24 AM
Roedj is offline
Find More Posts by Roedj
Michigan, USA
Roedj's Avatar
Joined Apr 2008
Contact Mike's Subworks - his ad banner is frequently at the top of this page. I'm sure he can help.
Dan
Roedj is offline Find More Posts by Roedj
Old Nov 15, 2011, 03:07 AM
OhioMike is offline
Find More Posts by OhioMike
OhioMike's Avatar
Grafton, Ohio
Joined Sep 2003
I just recently got the albacore. Its basically the same for innards as you say. Watching you for what to do and what not to do! Good luck!
OhioMike is offline Find More Posts by OhioMike
Old Nov 15, 2011, 03:26 AM
Jcopter's Avatar
Joined Jun 2005
If I remember correctly that motor base & part that go to the tank are the most critical part and need to be assembled as per the instructions exactly as I had some problems with mine and skip was kind enough to help me fix it. so be exact!!!
Jcopter
Old Nov 17, 2011, 03:53 PM
ken_nj is offline
GSMB Member
ken_nj's Avatar
Joined Mar 2008
Instructions page 4
I will be ordering some things from Mike's Subworks soon. I'm going to use as many parts from the kit as I can. Near the end I will be customizing the deck and hull to my liking.
In the meantime I could not go on so I made a correction on the pressure hull mounts. I filled the holes with plugs, sanded smooth and redrilled the mounting holes so now the upper PH mounts between the nuts with no interference. I'm anal about certain things being right so I had to do it. Now back to the ballast pump assembly.
Old Nov 17, 2011, 04:04 PM
Jcopter's Avatar
Joined Jun 2005
Did you fit that upper seal in place Yet?
it needs to be to all the outside edges,
make sure it does not slide away any
Just remembering some of my assembly problems
And I did lots of scribing on the hull and used some evergreen
scribed plastic for my decking, Looks great
Jcopter
Old Nov 17, 2011, 04:13 PM
ken_nj is offline
GSMB Member
ken_nj's Avatar
Joined Mar 2008
Just a few minutes ago I cleaned the surface on the upper PH where the upper seal goes of any bumps of plastic so the seal will sit perfectly.
Old Nov 17, 2011, 05:56 PM
ken_nj is offline
GSMB Member
ken_nj's Avatar
Joined Mar 2008
Which one of these shaft seals goes on the motor shaft? The picture is not clear enough to tell the difference. I included the instruction page that I am working on. If you look at the lower set of pictures it looks like it might be the single one at the bottom of the picture, but I'm not entirely sure.
Old Nov 17, 2011, 06:11 PM
Jcopter's Avatar
Joined Jun 2005
It is the single one
check miles subworks page there is a pic of the motor & seal
I think it is listed under the seals
Jcopter
Old Nov 17, 2011, 06:15 PM
Jcopter's Avatar
Joined Jun 2005
Boy it has been a long time!!!
do what the inst.say the shaft should only stick out from the seal a little
just enough for the coupler put it together as per the inst. do the silicon
and let it set fully
Jcopter
Old Nov 17, 2011, 06:31 PM
ken_nj is offline
GSMB Member
ken_nj's Avatar
Joined Mar 2008
Ah yes, saw the pic on Subworks, thanks!
Old Nov 17, 2011, 07:01 PM
Jcopter's Avatar
Joined Jun 2005
The inst are somewhat difficult to understand. I had to read mine over &over & over till I thought I had it down and even then sometimes I was still confused.
Anyways if I can help I will However my albacore is long gone but my marlin is good to go but I have mu own WTC in it
Jcopter
Old Nov 17, 2011, 07:25 PM
Jcopter's Avatar
Joined Jun 2005
Hey Ken I was just looking thru my stuff and I found a bunch of fotos of skips MArlin
that Used for documentation/Guide if you would like I can scan them for YA
let me know if you need this as there are quite a bunch
Jcopter
Discussion Retrieving Data Logs from older sessions with ICE-160 rvincent Castle Creations 7 Jun 01, 2011 02:44 PM
Discussion New guy here with a question about older radio and converting to electric from nitro cfiiman Electric Plane Talk 22 May 11, 2011 02:03 AM
Build Log Subtech Marlin Jcopter Submarines 0 Oct 30, 2007 04:50 PM
Albacore by Subtech speleopower Submarines 7 Apr 16, 2005 08:30 AM
Subtech's Tee Valve himszy Submarines 4 Dec 21, 2004 11:37 AM
