Old Nov 13, 2011, 01:20 PM
hexa is offline
Find More Posts by hexa
hexa's Avatar
United Kingdom, Scotland, Edinburgh
Joined Nov 2010
Careful!
Dji wk-m flip of death crash
Yep this is my second crash.
The first one I thought was down to x2 x3 fault. But it shows it was not the caused.
As I changed radio to futaba fx30 s-bus turn off x2 x3 and unplug the cable. Update to new firmware
As before I flown for 10 mins with one lipo full throttle an full forward was ok. Then connect a new lipo different from the one in first crash.
Same scenario lift off in alti, flick gps one ( craft had full gps locked) full throttle and full forward. The craft flip on the right then regain balance then flipped again and crash. Stick movement had no control.
Broke 2 motor mount lost 3 props dent 2 arms.
Seems to have bug with full throttle and forward in gps mode.
I would like some input about this
hexa is offline Find More Posts by hexa
Old Nov 13, 2011, 01:29 PM
Tahoe Ed is online now
Find More Posts by Tahoe Ed
DJI Support
Tahoe Ed's Avatar
Las Vegas/Lake Tahoe
Joined Feb 2010
I guess my question is why use GPS mode to fly full throttle/full forward. I can understand ATTI but ATTI and GPS??? I have numerous flights on two different frames and never had the problems that you have experience. Sorry for the crash, I hope you get it figured out and let the rest of us know.
Tahoe Ed is online now Find More Posts by Tahoe Ed
Site Sponsor
Old Nov 13, 2011, 01:40 PM
hexa is offline
hexa's Avatar
Joined Nov 2010
I always fly in gps mode. This problem seems to pop up randomly.
I flew a couple of packs before full throttle in gps mode with out any problems
Old Nov 16, 2011, 05:51 AM
hexa is offline
hexa's Avatar
Joined Nov 2010
I now think the flip was down to the the gaui motors and esc. I did some new test and all is fine with hobby wing 20amp esc and Axi motors.
Old Nov 16, 2011, 06:01 AM
fajar is offline
Find More Posts by fajar
fajar's Avatar
Indonesia, Special Capital Region of Jakarta, Jakarta
Joined Jan 2011
Yeah, you'll be better off with hobbywing escs. Gaui's probably uses some proprietory firmware.
fajar is offline Find More Posts by fajar
Old Nov 16, 2011, 06:16 AM
sidneyw is offline
Find More Posts by sidneyw
United States, NC, Huntersville
10 amp Gaui ESC?
Assuming your motor is rated for at Watts, running on 3S will require 150/11.1 = 13.5 amp. I won't use anything less than 18A ESC (minimum).
sidneyw is offline Find More Posts by sidneyw
Site Sponsor
Old Nov 16, 2011, 07:57 AM
fajar is offline
fajar's Avatar
Joined Jan 2011
from the looks of the motors, he is using gaui's scorpions for 330xs and they do come with 10a Gaui escs and the props look like 10" gaui. These are the default setup in 330xs that works fine with 3s lipo assuming his AUW is still within reason.
Looks like esc related problem to me.
Old Nov 16, 2011, 08:02 AM
redridinghood is offline
Find More Posts by redridinghood
Joined Dec 2010
Stock Gaui 330 esc can only (barely) handle 8 inch props, not 10.
redridinghood is offline Find More Posts by redridinghood
Old Nov 16, 2011, 08:15 AM
fajar is offline
fajar's Avatar
Joined Jan 2011
The newer esc, which are the stock ones for 330XS can handle 10" props. Tried it myself with stock gaui setup in extended frame and 3s. Here's official gaui's video, jump to 35' onward. Again, I still think WKM doesn't like gaui's escs very much. And yeah, 10amp is not to be used for more serious application.
Old Nov 16, 2011, 08:41 AM
Z06 Tony is offline
Find More Posts by Z06 Tony
Z06 Tony's Avatar
United States, NY, Rochester
Joined Sep 2008
Since u have it figured out now you should considering closing this thread.
Z06 Tony is offline Find More Posts by Z06 Tony
Site Sponsor
Old Nov 16, 2011, 08:46 AM
Octo is offline
Find More Posts by Octo
Joined Dec 2010
Or at least change the name of the thread.
Octo is offline Find More Posts by Octo
Reply With Quote  (Disabled)
Old Nov 16, 2011, 01:53 PM
hexa is offline
hexa's Avatar
Joined Nov 2010
Hey Octo, nice user name.
I was running stock gaui 8.45 props
The gaui 10 amp esc works with the hobbywing programming card ( they could be some knock off hw esc)
Am now getting 15mins fly time using 10.45 props moved up from 10mins with the guai setup.
Ill leave the thread head line as it is, sooner or later there will be some one with the same scenario, by googleing and reading finds the solution.
After a year or so I think all none active threads auto locked on RCG.
Old Nov 17, 2011, 05:01 PM
sidneyw is offline
Because of the 10a ESC which is marginal to begin caused the DEATH crash; the title remains unchanged.
And, this is the reason .... while Gaui 10A being maxed out can be found here. Good logic.
Site Sponsor
New Product DJI WooKong-M Autopilot System for multirotors **Owners Thread** DJI INNOVATIONS Multirotor Electronics 20274 May 20, 2016 12:54 PM
Cool Karbonic-XXL 50CM DJI WooKong-M frame superdave42 Multirotor Talk 12 Mar 09, 2012 10:01 AM
Discussion DJI WK-M - Droidworx Hex Build Huddo Multirotor Talk 41 Dec 31, 2011 07:58 AM
Sold DJI WK-M For Sale windmania Aircraft - Electric - Multirotor (FS/W) 15 Nov 02, 2011 09:28 PM
Discussion DJI WK-M Feature Wish List furyphoto Multirotor Talk 19 Oct 09, 2011 01:31 AM
