Old Nov 13, 2011, 06:24 AM
bhavikshah is offline
Find More Posts by bhavikshah
United Kingdom, England, London
Joined Feb 2009
Simulator problems with turnigy9x (frsky DIY soldered) ER9x
Hi Guys.
I was hoping someone would help me.
I have a turnigy 9x with the frsky module soldered to board. It's runing er9x firmware.
I can't get the Tx to work with FMS or the phoenic demo. I have tried with the phono cable and ppjoy/SPP. I get a continuous audio output but FMS does not detect any stick movements. This is with a 4ch model selection with 4ch output in setup.
I have also bough a phono-USB cable. It states that it is compatible with most transmitters for use with FMS. But again no luck.
I have read the several threads and understand that with frsky I do not need to solder a resistor.
Could it be a driver issue?
thanks,
bhavik
bhavikshah is offline Find More Posts by bhavikshah
Old Nov 13, 2011, 06:29 AM
pmackenzie is online now
Find More Posts by pmackenzie
I don't want to "Switch Now"
pmackenzie's Avatar
Toronto (Don Mills), Canada
Joined Dec 2002
Try reducing the number of channels. Bottom of the second model setup page.
(First one after the model select page)
Pat MacKenzie
pmackenzie is online now Find More Posts by pmackenzie
Old Nov 13, 2011, 06:35 AM
Joined Feb 2009
Thanks for your reply Pat.
Its allready at 4 channels. I can't reduce it any further. (?Proto PPM)
One other thing ive noticed is that when I plug in the connector win7 automatically installs as USB input device and not a joystick or game controller. I wonder if that is how it is supposed to be.
Bhavik
Discussion low range with Frsky diy module cheshireflyer Radios 34 Aug 15, 2012 03:22 PM
Discussion Upgrading Futaba T6XHs To 2.4 GHz With Frsky DIY V8HT Module? FXG DIY Electronics 14 Aug 27, 2011 04:21 PM
Wanted FrSky 2.4Ghz DIY Kit with Telemetry purcilas Aircraft - General - Radio Equipment (FS/W) 5 May 04, 2011 04:10 PM
Sold ER9x Eurgle 9x tx w/Frsky ACCST and 4rx panzerdivision Aircraft - General - Radio Equipment (FS/W) 1 Mar 31, 2011 08:09 AM
Help! Problem with FrSky V8HT DIY module in Futaba tx RobEm Radios 5 Mar 30, 2011 11:21 PM
