Old Jan 30, 2013, 03:55 PM
Jaynen is offline
Find More Posts by Jaynen
United States, CA, Oceanside
Joined Jan 2013
I've done RC cars but never planes.
Battery goes to the receiver, receiver goes to servos and ESC, ESC goes to motor? What are the three blue wires on the ESC?
I am missing an XT60 connector for my charger and they are Hobbyking only I guess should I swap to deans or is there a way to get one more
Jaynen is offline Find More Posts by Jaynen
Old Jan 30, 2013, 03:56 PM
denial15 is offline
Find More Posts by denial15
swede
denial15's Avatar
United States, UT, Vineyard
Joined Aug 2005
Originally Posted by Jaynen View Post
Think I have almost everything, except I need an X60? or whatever adapter for my charger and I still have not found a wheel collar to use on my soldering iron. People at home depot had no idea what I was talking about.
Do you just need the XT60 plug? Or do you need an adapter to fit another connector? I have some XT60 to T-Style adapters I'm selling, along with some series and parallel plugs.
denial15 is offline Find More Posts by denial15
Old Jan 30, 2013, 04:44 PM
Jaynen is offline
Joined Jan 2013
My charger seems to have Deans and Tamiya style plugs. I have the XT60 plug for the battery it came with it on there and have one to put on the ESC or reciever whichever I am supposed to hook it too. So I need an XT60 plug or adapter to use on my lipo charger
Old Jan 30, 2013, 05:07 PM
DJO is offline
DJO
Find More Posts by DJO
DJO
C'est la vie
DJO's Avatar
Joined Oct 2011
Does your charger have bullet plug/banana plug outputs? They're gold and circular, sort of. You can just solder on an XT60 plug... remove the plug that came with it. Or get a Deans to XT60 adapter..
Dan
DJO is offline Find More Posts by DJO
Old Jan 30, 2013, 05:08 PM
nightfox7 is offline
Find More Posts by nightfox7
┌∩┐(⋟﹏⋞)┌∩┐ The FAA
nightfox7's Avatar
United States, GA, Cornelia
Joined Jan 2012
Hey, I put mine up for sale here: http://www.rcgroups.com/forums/showt...8#post23982613
$80 OBO + shipping
Great little plane, just having to make some space. It will probably be replaced by an assasian or DRXL
nightfox7 is offline Find More Posts by nightfox7
Old Jan 30, 2013, 05:11 PM
DJO is offline
DJO
DJO
C'est la vie
DJO's Avatar
Joined Oct 2011
Ummm it has over 32'' in wingspan, not sure where you're getting 26'' from
Dan
Old Jan 30, 2013, 05:28 PM
Jaynen is offline
Joined Jan 2013
$80 OBO + shipping
Nice that is a good deal if I hadn't already bought all the kit parts for the albatross and components
Old Jan 30, 2013, 05:29 PM
Jaynen is offline
Joined Jan 2013
Dan
Yes my charger has bullet plugs you can swap from tamiya to deans connector etc
Old Jan 30, 2013, 06:15 PM
┌∩┐(⋟﹏⋞)┌∩┐ The FAA
nightfox7's Avatar
Joined Jan 2012
Dan
Oop, typing error, it's 36"
Old Jan 30, 2013, 06:16 PM
DJO is offline
DJO
DJO
C'est la vie
DJO's Avatar
Joined Oct 2011
What kind of charger is it?
Old Jan 30, 2013, 07:34 PM
Jaynen is offline
Joined Jan 2013
It's this one
http://www.duratrax.com/chargers/onyx/dtxp4245.html
Old Jan 30, 2013, 07:38 PM
DJO is offline
DJO
DJO
C'est la vie
DJO's Avatar
Joined Oct 2011
Awesome! Yeah so all you'll need is an XT60 plug. Can you solder?
Oh and a LIPO SACK or other guard is highly recommended!!!
Dan
Old Jan 30, 2013, 07:40 PM
Jaynen is offline
Joined Jan 2013
I can solder yes. Was just trying to get it built before this weekend so did not want to have to order something else online. Although building it is a bit more challenging on my own than I expected.
I am on the step where I need to snip the fiberglass rod. Didn't have the right thing to do that suppose I could dremel it off flush
I went ahead and ordered some connectors
Old Feb 04, 2013, 10:18 AM
Jaynen is offline
Joined Jan 2013
When I do hook up the electronics what channels do I plug stuff into?
If I want throttle on left stick, and the rudder/elevator on right stick? Or should I get used to rudder on left even though I don't have ailerons?
I plan to likely go to a wing which I guess has elevaons? next
Old Feb 04, 2013, 11:39 AM
Jim Buzzeo is offline
Find More Posts by Jim Buzzeo
Jim Buzzeo's Avatar
Willmar, Minnesota, United States
Joined Sep 2004
from your earlier post as well:
the battery is plugged into the ESC, NOT directly into the receiver.
the 3 individual wires on the esc are connected to the motor.
the remaining plug on the esc is plugged into the throttle channel on the receiver.
THAT wire (from ESC to receiver) is what powers the receiver AND provides throttle control.
elevons are not appropriate for this airplane.
(elevons are combination elevator / ailerons. this airplane is set up for three channels: rudder, elevator and throttle)
you also can not (easily / typically) change the throttle stick specifically, (the stick physically has no spring centering... )
the typical 'Mode 2' setup (very common in the states) has throttle on the LEFT stick (again, that stick does not return to center (vertically) when released)
Elevator on the RIGHT stick. for a 4 channel airplane (with ailerons) the rudder is on the left stick (with the throttle) the Ailerons are on the RIGHT stick (with the elevators)
IF you'd like to have rudder and elevator on 'the same stick' then plug the rudder servo into the Aileron port (slot) on the receiver. plug the elevatior servo into the elevator port, and the throttle (ESC wire) into the throttle port.
ALWAYS CONNECT THE BATTERY LAST.
Jim Buzzeo is offline Find More Posts by Jim Buzzeo
Found Sullivan/RnZ 36" and 48" foam float cores Comet1 Aircraft - Fuel - Airplanes (FS/W) 5 Oct 22, 2011 09:04 AM
Wanted Combat Wing 36 or 48 XE2 wbrannies Aircraft - Electric - Airplanes (FS/W) 1 Sep 18, 2011 04:17 PM
Sold WTT - 19" EPP Yaks - Great 3D indoor trainers. tonebone Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 13 Jun 01, 2011 08:40 PM
Off Site ITEMS END TODAY on Ebay..Gliders by XGDan EPP 36,48,60 inch Racer/DS slopepilot Aircraft - Sailplanes (FS/W) 5 Aug 17, 2010 01:55 AM
Sold EPP 1.3# Foam 36" wide x 48" long x 4" thick 2 sheets rakm Aircraft - General - Miscellaneous (FS/W) 3 Jan 24, 2007 08:49 PM
