Old Jan 28, 2013, 05:49 PM
Jaynen is offline
Find More Posts by Jaynen
United States, CA, Oceanside
Joined Jan 2013
Where do I get "extreme" tape?
Jaynen is offline Find More Posts by Jaynen
Old Jan 28, 2013, 05:50 PM
DJO is offline
DJO
Find More Posts by DJO
DJO
Deriving Equations
DJO's Avatar
Joined Oct 2011
It's Scotch Extreme Tape. You can get it at Walmart, Staples, etc...
Dan
DJO is offline Find More Posts by DJO
Old Jan 28, 2013, 06:03 PM
1fullbird is offline
Find More Posts by 1fullbird
1fullbird's Avatar
United States, NE, La Vista
Joined Nov 2011
Home Depot has it in the paint department
1fullbird is offline Find More Posts by 1fullbird
Jaynen is offline
Joined Jan 2013
Ah ok cool another thing on the shopping list
Old Jan 28, 2013, 06:07 PM
1fullbird's Avatar
Joined Nov 2011
Laminate will give your fuselage added strength. Oh, the extreme needs to be cut--you can't tear it with your hands like duct tape.
http://www.homedepot.com/webapp/cata...gry=Search+All
Old Jan 28, 2013, 06:08 PM
DJO is offline
DJO
DJO
Deriving Equations
DJO's Avatar
Joined Oct 2011
Just get the roll of it that comes with the cutter portion on it... that way you can just rip it.
It's VERY strong BTW...
Dan
Old Jan 28, 2013, 06:53 PM
Jaynen is offline
Joined Jan 2013
Question on CG. How do I easily test it? just by balancing it on my finger? I need to adjust the battery location to best move it?
Because after I maiden it and get it ok I want to strap my gopro on it, or should I try to balance it with the Go pro when I am building it?
Old Jan 28, 2013, 07:18 PM
1fullbird's Avatar
Joined Nov 2011
Well this is just my opinion so; if most of my flying is without the Go Pro I would balance it without it on. Then, I would balance it with it on just to see how much weight and where it needs to be placed. That way you can switch it out when you want. I built a CG balancer with two pencils in a board. Mark the COG line place the CG line on the erasers, top of fuselage should be level (Albatross right?)
Old Jan 28, 2013, 07:51 PM
elCapitan is offline
Find More Posts by elCapitan
wheeeeee!
elCapitan's Avatar
United States, UT, Provo
Joined Oct 2011
Or, on newer packaging, you might see it as "Scotch Shipping Tape - Extreme"
Home Depot's usually the cheapest around here
elCapitan is offline Find More Posts by elCapitan
Old Jan 28, 2013, 07:55 PM
wheeeeee!
elCapitan's Avatar
Joined Oct 2011
Or stick some pins in the bottom of the wings, along the CG line, and balance the pins on your fingers.
You can move the battery around, but with the Pelican, Albatross, and Storm Chaser, your best bet is to place the battery in the location of the fuselage that gives it the most protection, and then move the wing forward or back on top of the fuselage to attain correct CG.
Just remember that CG is relative to the WING, not the FUSELAGE. In other words, if the entire plane is tail heavy, you need more weight forward, right? Well, that means moving the wing BACK on the fuselage. Think of it more like moving the fuselage forward underneath the wing. That puts more weight in front of the wing. Make sense?
Old Jan 28, 2013, 11:14 PM
Jaynen is offline
Joined Jan 2013
I think I will tend to fly with the gopro on at least until I have some sort of FPV setup that would be using a smaller camera. Even if I am practicing I don't mind much leaving it on there?
Old Jan 29, 2013, 11:20 PM
Jaynen is offline
Joined Jan 2013
Think I have almost everything, except I need an X60? or whatever adapter for my charger and I still have not found a wheel collar to use on my soldering iron. People at home depot had no idea what I was talking about.
Old Jan 29, 2013, 11:40 PM
wheeeeee!
elCapitan's Avatar
Joined Oct 2011
The wheel collar isn't a soldering iron-specific part. Just a piece of hardware that fits on. It might just be easier to buy a cheap soldering iron where the tip sits in, held in place by a set screw (instead of a tip that screws on). Then just set the tip as far down as you want. If it's too long, it's soft enough to cut down with a pair of snips. The wheel collar is not a necessary part
Old Jan 29, 2013, 11:50 PM
Jaynen is offline
Joined Jan 2013
I know it's not I just was not able to find one. (wheel collar) I figured they have to be somewhere maybe I just need to try another hardware store
Old Jan 30, 2013, 04:43 AM
hobie14 is offline
Find More Posts by hobie14
hobie14's Avatar
Western Europe 52.7 N 8.9 W
Joined Jul 2007
here's a link to show you what a Wheel collar looks like ..... you dont need an exact size as long as it's a bit bigger on the inside diameter than the dia of your soldering iron tip ...... they are available in a large rage of sizes but not from a regular hardware store .....
http://www.hobbyking.com/hobbyking/s...mm_10pcs_.html
You should be able to get this item from any RC store or anyone flying RC would be happy to give you one I'm sure ......
hobie14 is offline Find More Posts by hobie14
Found Sullivan/RnZ 36" and 48" foam float cores Comet1 Aircraft - Fuel - Airplanes (FS/W) 5 Oct 22, 2011 08:04 AM
Wanted Combat Wing 36 or 48 XE2 wbrannies Aircraft - Electric - Airplanes (FS/W) 1 Sep 18, 2011 03:17 PM
Sold WTT - 19" EPP Yaks - Great 3D indoor trainers. tonebone Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 13 Jun 01, 2011 07:40 PM
Off Site ITEMS END TODAY on Ebay..Gliders by XGDan EPP 36,48,60 inch Racer/DS slopepilot Aircraft - Sailplanes (FS/W) 5 Aug 17, 2010 12:55 AM
Sold EPP 1.3# Foam 36" wide x 48" long x 4" thick 2 sheets rakm Aircraft - General - Miscellaneous (FS/W) 3 Jan 24, 2007 07:49 PM
