Old Jan 20, 2013, 01:03 PM
sredlin is online now
Find More Posts by sredlin
My dog ate my airplane
United States, CA, San Diego
Joined Dec 2008
The pod mount Pelican looks like a real hoot on the snow, I wonder if it could ROG off of wet grass, 'cause we don't get much snow here in San Diego?
sredlin is online now Find More Posts by sredlin
Old Jan 20, 2013, 01:09 PM
Jaynen is offline
Find More Posts by Jaynen
United States, CA, Oceanside
Joined Jan 2013
What part of SD Sredlin? I am up in Oceanside
Jaynen is offline Find More Posts by Jaynen
Old Jan 20, 2013, 01:35 PM
1fullbird is offline
Find More Posts by 1fullbird
1fullbird's Avatar
United States, NE, La Vista
Joined Nov 2011
The fuselage has a laminate covering--so it's fairly smooth. If you can get it moving it will pickup speed fairly quick, with a little up elevator and its off. I can't see why not. If you liked the snow video here is one I made. Yes, it's a real hoot!
Snow Skipping (4 min 8 sec)
1fullbird is offline Find More Posts by 1fullbird
Old Jan 20, 2013, 01:41 PM
elCapitan is offline
Find More Posts by elCapitan
wheeeeee!
elCapitan's Avatar
United States, UT, Provo
Joined Oct 2011
Agreed. I think the albatross is the perfect beginning plane, and a good platform for AP, later on. And the cool thing is, once you move on to an assassin, or a reaper, you're not going to want to get rid of the albatross. You'll find it's still enjoyable for experienced flyers, too.
elCapitan is offline Find More Posts by elCapitan
Old Jan 20, 2013, 01:59 PM
Joined Dec 2008
Jay, I live in Rancho Bernardo and mostly fly in a couple different local parks. My son and I just joined the SEFSD club so we can fly at their Alliant U. indoor events, and maybe occasionally at their South Shores field. I follow a lot of the CTH forums and have a lightweight slow-flying Scythe that my dog likes to chase and a couple other CTH kits I haven't found the time to build yet including a Pelican. The Scythe has been great and it seems like all their other kits are likely equally awesome, I just need to build more to confirm this.
Scott
Old Jan 27, 2013, 11:04 PM
Jaynen is offline
Joined Jan 2013
My kit should arrive tomorrow. Hopefully I won't be missing too much to get it together. How long does assembly usually take for a novice?
Old Jan 27, 2013, 11:08 PM
DJO is online now
DJO
Find More Posts by DJO
DJO
C'est la vie
DJO's Avatar
Joined Oct 2011
It took me a few hours as an intermediate/expert with foam... but that was with FPV gear installation as well. I doubt it'll take you more than an evening, but it depends.
Dan
DJO is online now Find More Posts by DJO
Old Jan 27, 2013, 11:18 PM
Jaynen is offline
Joined Jan 2013
Sounds like the goop on the wings needs to set for a while anyway.
I want to do the pod setup. What point in the instructions should I skip down to that. As It says to continue with radio install/laminate after doing the pod
Old Jan 27, 2013, 11:21 PM
DJO is online now
DJO
DJO
C'est la vie
DJO's Avatar
Joined Oct 2011
Are you talking about the Albatross? I'm talking about the Pelican LOL..
Dan
Old Jan 28, 2013, 01:17 PM
1fullbird's Avatar
Joined Nov 2011
Goop -- a couple hours at most. Please post pictures so we can see your build. I'll never turn down a better way.
Old Jan 28, 2013, 02:06 PM
Jaynen is offline
Joined Jan 2013
Oh I don't think a first timer will be finding a better way on purpose
Old Jan 28, 2013, 02:30 PM
Jaynen is offline
Joined Jan 2013
Is there an easy way to set my soldering iron to the 1/4inch depth?
Old Jan 28, 2013, 04:54 PM
1fullbird's Avatar
Joined Nov 2011
Home Depot, Set Screw Collar (other hardware stores may also have them)
http://www.homedepot.com/webapp/cata...gry=Search+All
Watch Lees' videos of him cutting groves--he's very smooth and doesn't let the iron linger in one spot. (If you go to slow it will melt more than you intended. Its easier to go shallow with the first pass, move smoothly--the foam actually springs back a little. If you need to go deeper make another pass. Use the fiberglass rod as a depth check.)
Old Jan 28, 2013, 05:51 PM
Jaynen is offline
Joined Jan 2013
Thanks. I figure I will need a trip to Walmart for the glue gun and goop, and home depot for the metal straight edge/square, wood dowel etc
Old Jan 28, 2013, 05:58 PM
DJO is online now
DJO
DJO
C'est la vie
DJO's Avatar
Joined Oct 2011
I didn't even use laminate on the fuselage and mine flew fine. As long as you put some extreme tape up in the front it'll be fine, but it's your choice of course
Dan
Found Sullivan/RnZ 36" and 48" foam float cores Comet1 Aircraft - Fuel - Airplanes (FS/W) 5 Oct 22, 2011 09:04 AM
Wanted Combat Wing 36 or 48 XE2 wbrannies Aircraft - Electric - Airplanes (FS/W) 1 Sep 18, 2011 04:17 PM
Sold WTT - 19" EPP Yaks - Great 3D indoor trainers. tonebone Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 13 Jun 01, 2011 08:40 PM
Off Site ITEMS END TODAY on Ebay..Gliders by XGDan EPP 36,48,60 inch Racer/DS slopepilot Aircraft - Sailplanes (FS/W) 5 Aug 17, 2010 01:55 AM
Sold EPP 1.3# Foam 36" wide x 48" long x 4" thick 2 sheets rakm Aircraft - General - Miscellaneous (FS/W) 3 Jan 24, 2007 08:49 PM
