Old Nov 11, 2011, 10:08 PM
mclarkson is offline
Find More Posts by mclarkson
Must not buy more planes!
mclarkson's Avatar
USA, KS, Wichita
Joined Jul 2010
Scratch-built 28" FFF Tiger Moth biplane (first scratch build)
I've been flying RC for about a year and a half and have never attempted a scratch build before but, a couple of weeks ago, I felt the urge building up.
I love my GWS Tiger Moth 400 and really wanted a smaller version so I decided to make it my first attempt at a scratch build.
I grabbed some blue fan-fold foam from Lowe's.
I didn't have any plans, per se, but decided to kinda wing it. I found some color plans for a paper, fold-and-tape plane on the int0rwebs and decided to use it as the basis for my model.
I modified it a bit, blew it up to a 29" wingspan, and had it printed out at OfficeMax. I glued the plans to a sheet of FFF and started cutting.
A quick test assembly.
Laying out the components to get an idea of their placement.
mclarkson is offline Find More Posts by mclarkson
Old Nov 11, 2011, 10:11 PM
mclarkson's Avatar
USA, KS, Wichita
Joined Jul 2010
Not sure how best to approach the problem of building in a battery compartment, ESC compartment, motor mount, etc. I decided to build it into the plane in a sort of mono-block (a la the Blu Baby). I designed 3 different shapes and cut out 2 of each of them. When sandwiched together, they form a 3D puzzle with cavities for the motor mount stick, motor, etc. etc.
Old Nov 11, 2011, 10:14 PM
mclarkson's Avatar
USA, KS, Wichita
Joined Jul 2010
I decided to hold on the lower wing with rubber bands, so I glued in a couple of basswood sticks to support them.
The fuse glued together with the paper plans removed.
The servo bay. The Rx is actually jammed way back into the tail, hidden by the blue pushrod guides.
Old Nov 11, 2011, 10:18 PM
mclarkson's Avatar
USA, KS, Wichita
Joined Jul 2010
I made cabane struts from some coffee stirs and toothpicks.
The wings are sanded into an airfoil shape.
Bamboo skewer wing struts.
Cabanes attached to the fuse.
A piece of balsa wood between the cabanes to add extra support.
Ailerons cut out of lower wing.
Old Nov 11, 2011, 10:20 PM
mclarkson's Avatar
USA, KS, Wichita
Joined Jul 2010
The aileron servo pockets are cut all the way through the wing. I super-glued a square of plastic from a container over the bottom of the pocket.
Old Nov 11, 2011, 10:23 PM
mclarkson's Avatar
USA, KS, Wichita
Joined Jul 2010
Gluing on the horizontal stab.
Gluing on the vertical stab.
Getting there!
I screwed up the very end of the fuse, making it too bendy, so I added a couple of coffee stirs to protect the foam and to add lateral strength.
Installing the wing struts.
Old Nov 11, 2011, 10:24 PM
mclarkson's Avatar
USA, KS, Wichita
Joined Jul 2010
Maiden flight today!
26" scratch built FFF biplane - maiden flight (3 min 57 sec)
Need to install some kind of landing gear and figure out a color/paint/tape scheme.
Old Nov 12, 2011, 03:11 AM
gjalbert is offline
Find More Posts by gjalbert
gjalbert's Avatar
Tualatin, OR
Joined Oct 2009
Very nice. Excellent first scratchbuild. One of my favorite subjects, too.
Gary
gjalbert is offline Find More Posts by gjalbert
Old Nov 12, 2011, 02:25 PM
mclarkson's Avatar
USA, KS, Wichita
Joined Jul 2010
Thank you, Sir.
Old Nov 12, 2011, 04:57 PM
springer is offline
Find More Posts by springer
treefinder
springer's Avatar
SE MI
Great job! I can see the foam addiction has caught you hard! Enjoy this one for a bit while the urge to build regrows!
springer is offline Find More Posts by springer
Old Nov 12, 2011, 05:27 PM
mclarkson's Avatar
USA, KS, Wichita
Joined Jul 2010
I'm already thinking about how I should have built it.
Old Nov 12, 2011, 05:50 PM
springer is offline
treefinder
springer's Avatar
SE MI
not surprised, yup, your hooked!
Old Nov 12, 2011, 06:14 PM
mclarkson's Avatar
USA, KS, Wichita
Joined Jul 2010
I decided some HZ Mini Super Cub landing gear would be just about right (and cheap, to boot.)
I made a LG mount from a thin piece of plywood with a slot cut in it and carved out a little place to glue it to the bottom of the fuse. I cut the slot up into the foam as well.
Old Nov 12, 2011, 06:50 PM
springer is offline
treefinder
springer's Avatar
SE MI
It'll definitely be fun doing rog's and touch and goes!
Old Nov 12, 2011, 09:18 PM
mclarkson's Avatar
USA, KS, Wichita
Joined Jul 2010
Landing skid == bent finishing nail.
For Sale 36" Newly Built Spad XIII & GWS Tiger Moth 400 (both receiver ready) LPU mtdoramike Aircraft - Electric - Airplanes (FS/W) 0 Apr 23, 2011 08:30 AM
Discussion Scratch built Slow Fly Tiger Moth FLOEY Foamies (Scratchbuilt) 2 Jul 21, 2008 03:34 PM
Trying to build my first wing... built up FFF? Newberry Parkflyers 3 Jul 16, 2004 04:53 PM
Scratch built Tiger Moth flies! fbret Scale Kit/Scratch Built 3 Nov 09, 2003 11:27 AM
