Old Nov 11, 2011, 04:55 PM
Art Gallagher is offline
Find More Posts by Art Gallagher
Joined Aug 2008
Homemade silicone Marblehead bowbumpers
Hi all
Has anyone made these and can I have some instruction please?
I have access to silicone material at work ( Otoform) but looks too soft to last.
Or do I just keep making new ones from it?
Any help gratefully received .
Regards
Arhtur G
Art Gallagher is offline Find More Posts by Art Gallagher
Old Nov 11, 2011, 04:59 PM
martin richards is online now
Find More Posts by martin richards
Useful Idiot
Asturias, Spain
Joined Mar 2001
Foam flip flops can usually be cut to shape and one old pair should provide enough for many years of sailing.
martin richards is online now Find More Posts by martin richards
Old Nov 11, 2011, 05:06 PM
Joined Aug 2008
Tnx. That was quick. I'll give it a try!!
But to answer my question??
Regards
art.
Old Nov 11, 2011, 05:45 PM
Useful Idiot
Asturias, Spain
Joined Mar 2001
Silicone takes a fair bit of time to cure for something the thickness of a bumper. But go ahead and make a plaster mould from the current one and keep one or two in reserve. That Otoform seems a bit pricy compared with the normal caulking silicone that most use. However being two part, its curing time is much less, and unless your into naval warefare in your M, it's worth a try testing its durability. Usually most carve a bow block from balsa and use that to make the plaster of Paris mould
Old Nov 11, 2011, 09:21 PM
hew565 is offline
Find More Posts by hew565
USA, LA, Mandeville
Joined Feb 2005
I have used a 2 part silicone to mold an IOM bumper, and it works well. I made a plug that fit the hull, and poured a two part urethane moulding compound over it and let cure. Then pulled the plug out and poured 2 part silicone, with a colorant added, into it. A few hours later, pulled the bumper out. I used 3M 5200 to glue to bow.
I got both moulding compounds from http://smooth-on.com.
I even made a mold of the bow of one boat, with a bumper "plug" attached to it. Then removed the plug, slipped the mold back onto the hull, and poured 2 part silicone into an opening in the top. Once cured, I had a molded-in-place bow bumper!
You HAVE to use a non-silicone based material for the mold, or the new silicone will bond to the mold and you will have a disaster. Silicone will not stick to urethane and vice versa.
hew565 is offline Find More Posts by hew565
Old Nov 12, 2011, 10:06 AM
Guz is offline
Guz
Find More Posts by Guz
Guz
Gutless wonder
Guz's Avatar
Tempe, AZ
Joined Dec 2005
How I did it.
I used double sided tape and taped on a big piece of balsa to the bow. Then I shaped the balsa with a plane and sandpaper. Removed the balsa block and sealed it with epoxy, then painted it.
From there I mounted the balsa on a piece of plexiglass. Then I coated the balsa and plexiglass with Vaseline. Mixed up some plaster of paris (rather soup'y) and poured it a container. Then I pressed the balsa/plexi into the plaster and let cure over night. Popped out the balsa/plexi.
Then I coated the plaster mold with Vaseline, and then filled with black silicone from the hardware store. Using the plexiglass to scrape it smoth to the top of the plaster mold. Again, let cure overnight. I would just poke at the silicone with my finger to see if it was "solid'. You can tell because it feels 'squishy' if it's not. If it isn't, just wet a toothpick with water and poke it into the silicone a couple of times and wait another day. My silicone cures from the outside to inside.
When it's 'solid' pull out of mold. As time goes on, it gets harder.
My silicone bumper looks just like the plug
But the important thing is to use a liberal amount of Vaseline in the mold! If you don't, it's a pain getting the silicone out of the mold.
I hind sight, had I known about using old 'flip-flops', I would have gone down that route.
Guz is offline Find More Posts by Guz
Discussion Marblehead Help Needed.- Whirlwind Olympic Winch eurosystem0 Sailboats 21 Nov 03, 2015 12:09 PM
Sold Marblehead/10r/IOM etc Keel for Sale breakwater Boats (FS/W) 5 May 24, 2014 01:26 PM
For Sale RC Marblehead racingyacht cheddarcaveman Boats (FS/W) 0 Oct 02, 2011 01:52 AM
