Old Apr 23, 2012, 03:11 PM
Peper is offline
Find More Posts by Peper
London
Joined Sep 2010
I know its an old thread, but I would like to thank Gary for such nice build log!
surely better then the mpx manual that without pictures makes such a simple thing to put together a time wasting job.
thanks
Peper is offline Find More Posts by Peper
Old Apr 29, 2012, 09:41 PM
Gary Binnie is offline
Find More Posts by Gary Binnie
Late for work again!
Gary Binnie's Avatar
Northampton, England
Joined May 2004
Cheers!
I use it regularly, great bit of kit.
GB
Gary Binnie is offline Find More Posts by Gary Binnie
Old May 11, 2012, 03:20 AM
HxA is offline
HxA
Find More Posts by HxA
HxA
Joined Aug 2011
Why don't you align the scale with 30 mm gradation over the 45 mm mark? In this way it will be much easier and practical too to read the real distance between stopper and rotation point from outside of the stopper than from inside of it that is always covered by the wing!
Good luck!
HxA is offline Find More Posts by HxA
Old May 11, 2012, 04:03 PM
target is offline
Find More Posts by target
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Actually, on the MPX balancer, that is the way it is(reading the distance from the back of the stops), if you follow the directions properly on assembly.
R,
Target
target is offline Find More Posts by target
Old May 11, 2012, 04:07 PM
target is offline
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Originally Posted by JetMech2002 View Post
Does anyone have a source for these?
Mine was a gift, but a few folks got together and did a group buy and brought them all in at one time.
If I recall correctly, they were about $65 each at the time, but that was about 5 years back.
Probably more dependent on the dollar/Euro ratio than anything else, so no may be a good time to try getting one.
G/L,
Target
Old Aug 01, 2012, 09:50 AM
FlyerMika is offline
Find More Posts by FlyerMika
Joined Apr 2012
I'm just building mine, and intend to do it exactly as per the instructions (which are not that great, I have to say). Anyway, I'm a bit curious what the reason for the accurate balancing before sticking the ruler tapes. In any case, every time you move the stops to the position for the intended CoG, you balance the beams with the counterweights. There probably is some subtle detail I'm missing here, but somehow it feels like MPX could make the instructions more understandable and easier by just making the tapes long enough to start from the end of the beam and then instructing the user to attach the supports so that the scale begins at the edge, at the 3 cm mark.
Mika
FlyerMika is offline Find More Posts by FlyerMika
Old Nov 11, 2012, 06:34 PM
willmo is offline
Find More Posts by willmo
willmo's Avatar
United Kingdom
Joined Jan 2010
I've just assembled one of these and have to agree with HxA. Following the MPX instructions means that you set the CG on the inside face of the stopper which means of course that the scale is obscured once the model is on the balancer. It would be much better, as the stoppers are very prone to move on the bars, to put the 30mm scale position over the pencil mark and then you can read the CG easily on the outside of the stopper.
I wish I'd read HxA's post before I did mine as now I have to add 15mm (the width of the stopper) to the CG to be able to read the value on the outside of the stopper. Hope that makes sense.
willmo is offline Find More Posts by willmo
Old Nov 12, 2012, 05:47 PM
target is offline
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
I followed the instructions on my specifically, and the read IS from the outside of the stoppers....
I'm not sure if they changed the instructions between mine and yours, but I guess it could be.
I agree its much better to read from the forward end of the stoppers.
R,
Target
Old Feb 22, 2013, 11:16 AM
Esprit 88 is offline
Find More Posts by Esprit 88
Per Ardua ad Astra
Esprit 88's Avatar
United Kingdom, England, London
Joined Jan 2005
thanks
And thanks from me, I couldn't make any sense of the instructions. The pictures really help
Esprit 88 is offline Find More Posts by Esprit 88
Old Feb 22, 2013, 11:25 AM
Joined May 2004
No worries!
I use mine a lot. The graduated scale has lifted and needs gluing down and the balance weights often slide off on to the floor! A sliver of tape on the beam would probably fix that.
GB
Old Sep 27, 2013, 06:47 PM
Hoot is offline
Find More Posts by Hoot
United States, TX, Houston
Joined May 2003
Source for Multiplex CG machine
I ordered my Multiplex CG machine from Steve Webb models in England. http://www.stevewebb.co.uk/
Sent him funds via PayPal and it arrived in Houston two or three weeks later. USA Customs in Chicago was slow. The cost was 48 GB pounds. (about $75)
Hoot is offline Find More Posts by Hoot
Old Sep 27, 2013, 10:56 PM
target is offline
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
You will love that thing; I love mine!
R,
Target
Old Mar 08, 2014, 05:54 AM
saracen_knight is online now
Find More Posts by saracen_knight
Australia, WA, Perth
Joined Apr 2012
Greetings,
After having just purchased and built a MPX C of G apparatus, I realised that’s very important to follow the instructions accurately.
In particular, the equilibrium position of the scale rails must be determined with both the vertical posts and trim weights in position on the scale rails as explained in the manual as the two (vertical post and trim weight) are of different masses. The consequence of not doing this will be that your empirical C of G will be about 5 mm out.
As a general comment, it’s a good piece of kit and it minimises the error in determining the C of G. I have bought it to assist in the setting up a NAN glider and it’s made an easy job of it.
Regards & fly safe
saracen_knight is online now Find More Posts by saracen_knight
Old May 13, 2015, 02:16 AM
gmvcz is offline
Find More Posts by gmvcz
Ian
gmvcz's Avatar
United Kingdom, Lostock Hall
Joined Jan 2015
The worst set of instructions I have ever read
It may be a useful piece of equipment, but the instructions are dire. In fact, for the UK price charged (£30), it's unacceptable.
Reading this thread shows that there are other faults: counter-weights fall off, scale lifts off.
Think hard before buying this; or be prepared to do a good deal of work for yourself.
This is a bad piece of work done by a company whose focus is not the customer.
gmvcz is offline Find More Posts by gmvcz
Old May 13, 2015, 04:46 AM
target is offline
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Nice first post.
I worked hard at keeping the counter weights on mine as well. I used a single wrap of thin tape around the end of the arms the counterbalances are on. It took a lot of effort, but I managed.
Question question about center of gravity. moto mike Beginner Training Area (Fuel) 13 Oct 08, 2011 09:04 AM
Discussion Marauder weigth in the nose to center gravity juzu Sailplane Talk 2 Apr 27, 2011 05:09 AM
Discussion How to Calculate Center of Gravity smiley007 Foamies (Scratchbuilt) 10 Apr 18, 2011 07:22 PM
Multiplex Twin Star II Center of Gravity Problem foamboy Foamies (Kits) 13 Sep 09, 2005 09:38 AM
