Old May 29, 2012, 11:55 PM
jackosmeister is online now
Find More Posts by jackosmeister
DroneWorlds - TEAM NEW ZEALAND
jackosmeister's Avatar
Auckland NZ
Joined Aug 2007
Thanks set the CG at 45mm,
Took 15grams of lead halfway down the tail boom to balance out the big mega in the nose. Highly recommend sticking some tape on the battery to help remove it, took half an hour to get the pack out with the tape
Stratair 2.4 shark fin installed and the Mini Monster is ready to maiden
jackosmeister is online now Find More Posts by jackosmeister
Old May 29, 2012, 11:58 PM
sykotic is offline
Find More Posts by sykotic
200mph +
sykotic's Avatar
New Zealand, Manawatu-Wanganui, Palmerston North
Joined Sep 2010
I do exactly the same thing on my radiant to get the 5s packs out. That fibre tape is amazing stuff
Looking forward to video of this thing. 210 easy
sykotic is offline Find More Posts by sykotic
Old May 30, 2012, 01:28 AM
Auckland NZ
Joined Aug 2007
Yeh I think so, 200mph is going to be smashed on the maiden (I hope haha!)
How fast a reading I can get off it is going to depend massively on how much of a straight line I can see it for!
Roll on Ampfest 2012.
Old May 30, 2012, 08:43 AM
magrinsi is online now
Find More Posts by magrinsi
magrinsi's Avatar
Florence Italy
Joined Dec 2009
I have put in my Lp1 the Mega 16-25-2 Grun F5d....
Do you know how many Amp with 5s and 5.2x5.2?
magrinsi is online now Find More Posts by magrinsi
Old May 31, 2012, 03:11 AM
magrinsi's Avatar
Florence Italy
Joined Dec 2009
Fly yesterday....96A to launch.. after stabilized to 75-80A.
Data log record 39000 rpm with 5.2x5.2" ..doppler 300 km/h.
Old May 31, 2012, 01:36 PM
sebbe is offline
Find More Posts by sebbe
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
Jacko, good luck, keeping my thumbs, go near mic when flyby, and you will get accurate readings..
magrinsi , how much weight on yours now with 5s? and how much throttle on launch ? does it torque roll much ?
good speed. 300km/h..
sebbe is offline Find More Posts by sebbe
Old May 31, 2012, 01:44 PM
magrinsi's Avatar
Florence Italy
Joined Dec 2009
The weight is 750-800gr...
When i launch it ..100% of throttle and little mix to right aileron on a switch after 1 sec i switch of mix...very good system for me.
I not think that 800gr this pylon fly very easy...cool landing and launch.
I must put a cover to the servo arm..are a brake!!!!
After i increse 10km h....
Old May 31, 2012, 02:03 PM
sebbe is offline
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
OK, thanks for the info magrinsi,,
How much mix, 2mm up aileron right side ?
Old Jun 01, 2012, 01:06 AM
magrinsi's Avatar
Florence Italy
Joined Dec 2009
Yes..2mm
Old Jun 01, 2012, 09:44 PM
Auckland NZ
Joined Aug 2007
Im thinking, depending on the altitude your fly at, you'd probably go faster with a 4.7x4.7. 5.2x5.2 is a pretty big load on 5S for it.
My ones AUW is 874g, will be bungee launched and I dunno how im gonna land it yet Will work that out when we come to it.
With 50k rpm and 5.5" of pitch, statically it makes a lot of noise and naff all thrust
Old Jun 02, 2012, 10:36 PM
Auckland NZ
Joined Aug 2007
Goes Fast
Old Jun 03, 2012, 12:29 AM
Auckland NZ
Joined Aug 2007
Flight report -
Bungee launch went fine (as all bungee launches do )
Its noticeably faster than the stiletto, and actually flies better too with this setup too, no nasty tip stall, didnt feel like it was going to bite at any point. VERY fast in a turn too. Landing was a non event, ran out of elevator throw though.
Poor neu 5S pack got a bit of a hammering, forgot to set the low voltage alarm on the A9. Going to need to get some more packs as this thing is going to kill lipos
In flight the throws were too big, was twitchy as . A throw tweak and dual rates for landing are needed. Had a small amount of up trim for level flight, but my CG is quite far forward too. Tracked power on/power off perfectly, not noticeable ballooning at speed either.
The dopler cam recorded 2 passes at 327 kmh and the passes were rubbish wobbly things with naff all run up! Recorded one pass with a nasty wind roar in the middle that was high 340's but its too messy to confirm
202mph on the maiden would count as succesful then Looking forward to pushing it harder once its dialled in a bit better, expect much higher numbers
Ill have a look and see if hat cam recorded anything veiwable
Old Jun 03, 2012, 12:47 AM
scorpion-fan is offline
Find More Posts by scorpion-fan
Joined Nov 2008
my congratulation for this result!
here you can find one more building report.
thisone will be powered by 10S 2650 with about 140Amps and a rewinded and in front mounted kontronik pyro 650 outrunner - the same type, as aliasjack used in his 450+ km/h flights with the bigger fluxcompensator
prop will be the 7x13 folder.
may be, it will be good enough for >400km/h also.
scorpion-fan is offline Find More Posts by scorpion-fan
Old Jun 03, 2012, 01:05 AM
QDRevenger is offline
Find More Posts by QDRevenger
QDRevenger's Avatar
New Zealand, Auckland
Joined Jun 2011
Goes Fast
Indeed, was good to see, awesome turn speeds, didn't seem to scrub off too much speed through the turns either. Congrats with the speed, was definately eating the sky up pretty quick.
QDRevenger.
QDRevenger is offline Find More Posts by QDRevenger
Old Jun 03, 2012, 01:28 AM
Auckland NZ
Joined Aug 2007
That looks nice, like new open weave version.
The Lp1.1 is the small one, 960mm wingspan. 5S 2100 is about the largest battery that fits
Wanted Wing Popwing or Swift or speedwing or tuffwing pilot1211 Aircraft - Electric - Airplanes (FS/W) 1 Nov 10, 2011 03:18 PM
Help! speedwing Mini Twin anyone have one? few ? about it CryHavocc Flying Wings 8 Sep 29, 2011 05:48 AM
Wanted Speedwing 250 MKII or Speedwing 400 MKII... papasmurf Aircraft - Electric - Airplanes (FS/W) 2 Sep 06, 2011 07:07 PM
Micro speedwing build schoey Foamies (Kits) 46 Aug 08, 2005 10:22 AM
Mini SpeedWing Build: w/Solite SlowRider Foamies (Kits) 84 Dec 26, 2004 06:07 PM
