Old Apr 04, 2012, 12:12 AM
Dbox is offline
Find More Posts by Dbox
One Idiot is plenty...
Dbox's Avatar
United States, OR, Portland
Joined Jun 2005
Amazing sound Chris.
Thanx for sharing.
Yuri
Dbox is offline Find More Posts by Dbox
Old Apr 05, 2012, 02:35 AM
magrinsi is online now
Find More Posts by magrinsi
magrinsi's Avatar
Florence Italy
Joined Dec 2009
Fin gluing.......
magrinsi is online now Find More Posts by magrinsi
Old Apr 06, 2012, 01:40 AM
magrinsi's Avatar
Florence Italy
Joined Dec 2009
Originally Posted by magrinsi View Post
Fin gluing.......
I'm not sure of this locking system of wing...
Old Apr 06, 2012, 02:10 AM
sebbe is offline
Find More Posts by sebbe
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
Look at post #123 and #124
sebbe is offline Find More Posts by sebbe
Old Apr 06, 2012, 03:10 AM
magrinsi's Avatar
Florence Italy
Joined Dec 2009
I see it..but i'm not sure of this modify....
Ho w much deep the hole for the 3mm shaft in the wing?
Old Apr 06, 2012, 05:14 AM
sebbe is offline
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
the deep is like 5-6mm only, its solid, so no problems drill there..
Old Apr 06, 2012, 05:42 AM
magrinsi's Avatar
Florence Italy
Joined Dec 2009
I ask myself... but now much cost to factory made it little better?
Old Apr 06, 2012, 06:49 AM
sykotic is offline
Find More Posts by sykotic
200mph +
sykotic's Avatar
New Zealand, Manawatu-Wanganui, Palmerston North
Joined Sep 2010
The mod Sebbe did is great, but I have to say that the factory setup isn't going to fall out...
The lip is solid carbon and isn't going anyway. What you may find if you don't do the mod is the wing will try to wiggle back and forward a few MM unless you crank up the rear bolt very tight.
I did it a slightly different way, and put a bit of balsa wood on each side of the tongue to stop it moving.
sykotic is offline Find More Posts by sykotic
Old Apr 06, 2012, 07:21 AM
magrinsi's Avatar
Florence Italy
Joined Dec 2009
I'm ready for the first Lp1 Fly.... in this light configuration the weight is 600gr...
Het 3w 3s 1300mah 6x4"
This only for trim the plane and know his nature...
Old Apr 06, 2012, 10:57 AM
sebbe is offline
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
Good luck....
Old Apr 17, 2012, 11:13 PM
jackosmeister is offline
Find More Posts by jackosmeister
DroneWorlds - TEAM NEW ZEALAND
jackosmeister's Avatar
Auckland NZ
Joined Aug 2007
Well after an extraodinarily long order ordeal, I now have a LP1.1, the new version (bit bigger, slightly updated). Its close to the same size as the Escape/Stiletto.
Theres a few differences to the LP1 Ive noticed, ie different forward wing mount.
Its nicely made, very rigid!, The whole wing is carbon, and then they have used a carbon sock spar! So the wing aint gonna break no matter what you throw at it!
The fuselage is very square (lots of lipo could be crammed into it), very light (single carbon layup with carbon tow at each edge of the fuse, very rigid )
Im impressed, with 2.5kW in it this thing is going to be totally insane. 200mph is going down!
Ill take some pics later tonight.
jackosmeister is offline Find More Posts by jackosmeister
Old Apr 18, 2012, 01:43 AM
Auckland NZ
Joined Aug 2007
Pics - same length as the Stiletto, slightly shorter wing, slightly higher aspect (and much thinner)
5S 2100 Neu pack fits nicely, Most 5S 2200 would fit. 6S 1600+ would require 2P. Everything smaller will fit easily.
The wing really is an impressive peice of work, very nicely done HJK
Old Apr 18, 2012, 02:23 AM
sykotic is offline
200mph +
sykotic's Avatar
Joined Sep 2010
Sweet pics!
Looking forward to seeing this in person.
Wing isn't much different than the 1.0?
Old Apr 18, 2012, 02:47 AM
Auckland NZ
Joined Aug 2007
Nah looks similar, the 1.1 has a higher aspect ratio though, Looks "slimmer" but chord is probably the same.
Old Apr 18, 2012, 03:15 AM
sebbe is offline
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
Jacko, crazy man,,, these one will look like 300mph in the air... You will get the kick of adrenaline for sure. keep going..
10 years ago if someone said they where putting a 2500 watt setup in a small pylon, they would just skaked their heads... I guess we live in a different time
Wanted Wing Popwing or Swift or speedwing or tuffwing pilot1211 Aircraft - Electric - Airplanes (FS/W) 1 Nov 10, 2011 03:18 PM
Help! speedwing Mini Twin anyone have one? few ? about it CryHavocc Flying Wings 8 Sep 29, 2011 05:48 AM
Wanted Speedwing 250 MKII or Speedwing 400 MKII... papasmurf Aircraft - Electric - Airplanes (FS/W) 2 Sep 06, 2011 07:07 PM
Micro speedwing build schoey Foamies (Kits) 46 Aug 08, 2005 10:22 AM
Mini SpeedWing Build: w/Solite SlowRider Foamies (Kits) 84 Dec 26, 2004 06:07 PM
