Old Nov 11, 2011, 01:09 AM
sykotic is offline
Find More Posts by sykotic
200mph +
sykotic's Avatar
New Zealand, Manawatu-Wanganui, Palmerston North
Joined Sep 2010
HJK Speedwing LP1 Build
Hey,
Since my Stiletto didn't like life any more I needed a new s400 pylon machine.
A (incredibly well wrapped and protected box) arrived today with a shiny carbon machine inside.
Pictures below, alot are compared it size wise to my stiletto.
Its a beautiful plane, you can tell its been made by people that care. It's got the same kind of finish and attention as Yuri's xplane if you are lucky enough to have held one of those.
Wing is thin, i measure 11mm at the thickest point and it quickly gets smaller. Very stiff. Nothing on it bends or compresses when pushed. The main spar looks like a end grain balsa with carbon top and bottom. Ill take pictures when I open it up for servos.
Going to power it with 3 and 4s 2200's with a HET 2w + gm 4.75x4.75 folder to start with. Once that dies I will get a mega to carry on.
I can easily fit the 5s neu energy 2100 packs! The body is MASSIVE for the size of the plane. This plane could pack some scary power!
I'll update as I go
sykotic is offline Find More Posts by sykotic
Old Nov 11, 2011, 02:38 AM
Flyextreme is offline
Find More Posts by Flyextreme
Sure it'll work
Flyextreme's Avatar
United States, CA, Redondo Beach
Joined Nov 2005
Very nice
Flyextreme is offline Find More Posts by Flyextreme
Old Nov 11, 2011, 03:54 AM
jackosmeister is offline
Find More Posts by jackosmeister
DroneWorlds - TEAM NEW ZEALAND
jackosmeister's Avatar
Auckland NZ
Joined Aug 2007
^ +1
Want.
It seems to be lacking something... I dunno... Maybe it needs more carbon
jackosmeister is offline Find More Posts by jackosmeister
Old Nov 11, 2011, 11:03 AM
sebbe is offline
Find More Posts by sebbe
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
VERY nice plane, this one I will follow for sure..
sebbe is offline Find More Posts by sebbe
Old Nov 11, 2011, 11:10 AM
la528it is offline
Find More Posts by la528it
la528it's Avatar
United States, UT, Salt Lake City
Joined Dec 2007
Just posted in other thread... If you don't mind 9/10, then click here link
la528it is offline Find More Posts by la528it
Old Nov 11, 2011, 12:06 PM
Auckland NZ
Joined Aug 2007
I gotta get me one
The 2.2kW stiletto is going to break at some point!
Sykotic - 16/35/1 doooo it
Old Nov 11, 2011, 01:29 PM
Jabberwocky_ is offline
Find More Posts by Jabberwocky_
Jabberwocky_'s Avatar
Montreal
Joined Aug 2009
I'm salivating uncontrollably!
It's fantastic to see that someone finally got one of these beauties from HJK. I think this will inspire others to do the same. I found their website last spring and was in awe. I'll bet countless others have come across their site and said wooooooooooowwwww, but just didn't plunk down cash yet, waiting to see who would buy first and report back. Thanks for being the first on RCGroups to post about this highly desirable model from the new German builder HJK.
What a plane! This could be the holy grail of pylon racers. Time will tell. I'm sure I'm not alone when I say that I'm very eager to hear your flight report and general commentary after you've worked with it after a few flights. I already know it flies well because I've seen the vid on Youtube. Obviously, it's not going to be a dud. But the guys in the video don't offer any comments on the flight. You however, might be more inclined to do so. Hopefully
Cheers!
Jabberwocky
Jabberwocky_ is offline Find More Posts by Jabberwocky_
Old Nov 11, 2011, 01:31 PM
Montreal
Joined Aug 2009
What is the wing bolt setup? Does it come already drilled out, wing and fuse? And what about the motor mount? Do they include one? I know it's not already installed, according to your fuse interior picture. Is there any hardware provided with the model (pushrod, screws, horns)? They don't mention anything on their website.
thanks!
J
Old Nov 11, 2011, 03:36 PM
sykotic is offline
200mph +
sykotic's Avatar
Joined Sep 2010
No hardware, no motor mount, no wing attachment bolt
It's not a ARF for sure.
Im going to copy Jacko's stiletto hold down for the wing. Basically a alloy plate under the lip in the fuse, and a washer/bolt through the back. It is not drilled at all. The front of the wing hold down is a solid "lip" of carbon. Much better than the pin of the stiletto.
I hope to have that part done shortly before I start on the tail so I will take pics as I go.
For the tail I will do the setup on wasps/mini hawks I think. Small bolts up through the body, through the tail into the fin to hold it all in position, and epoxy on the joins.
Old Nov 11, 2011, 03:38 PM
sykotic is offline
200mph +
sykotic's Avatar
Joined Sep 2010
That weighs more than the entire plane! (it looks good/scary sitting in it though.....)
Test on HET, then I'll look at that... I guess I need to do something with it
I need to buy some scales and check the weights of things. I see in the past day they have changed their website to say their LP1 has gone on a diet down to 200grams, wonder if mine is one of those or if its heavier. Tail/fuse weigh stuff all, and the wing isnt very heavy
Old Nov 11, 2011, 03:40 PM
harlem68 is online now
Find More Posts by harlem68
Joined Oct 2003
Originally Posted by sykotic View Post
Hey,
I'll update as I go
Great..!!
harlem68 is online now Find More Posts by harlem68
Old Nov 11, 2011, 04:21 PM
KRProton is online now
Find More Posts by KRProton
Tim Lampe; Hobbico R&D
KRProton's Avatar
Champaign, IL
Joined Dec 2009
I still have my heart set on a Viper, but this one interests me too for sure.
Tell me sykotic, did you get this from HJK direct, or is there a distributor (are you in the States?)?
Did you pay US dollars? If so, how much did you pay?
I'll be watching the build!
Thanks!
Tim
KRProton is online now Find More Posts by KRProton
Old Nov 11, 2011, 05:09 PM
sykotic is offline
200mph +
sykotic's Avatar
Joined Sep 2010
Im in New Zealand, brought straight from HJK.
I paid their price on the website, minus VAT. I think it was 200 - 19% then 40 shipping (and the shipping was worth it imo, big box packed REALLY well). Total of about 200 euros.
Took about 10 days to get here.
Old Nov 11, 2011, 06:27 PM
sykotic is offline
200mph +
sykotic's Avatar
Joined Sep 2010
tail is 23g
fin is 6g
fuse is 56g
wing is 182
267g
Very interesting that the new ones are now 200g according to their website!
For comparison the stiletto's wing is 185g with two ds09 servos in it.
Old Nov 11, 2011, 08:07 PM
Piece is offline
Find More Posts by Piece
Wake up, feel pulse, be happy!
Piece's Avatar
Joined Aug 2009
I don't have the cash (or the airspace) for one of these critters, but I'll be watching this thread. We need a drooling smiley...
I've often wondered why more Speed 400 class racers don't have huge power-packing fuses like this one. Seems like if you want to go stupid-fast, that's the way to do it. Still, 5S sounds... downright psycho
What sort of speed range are you expecting for it? A 2W on four cells with a 4.75x4.75 has to be smoking, perhaps in more ways than one
Piece is offline Find More Posts by Piece
Wanted Wing Popwing or Swift or speedwing or tuffwing pilot1211 Aircraft - Electric - Airplanes (FS/W) 1 Nov 10, 2011 03:18 PM
Help! speedwing Mini Twin anyone have one? few ? about it CryHavocc Flying Wings 8 Sep 29, 2011 05:48 AM
Wanted Speedwing 250 MKII or Speedwing 400 MKII... papasmurf Aircraft - Electric - Airplanes (FS/W) 2 Sep 06, 2011 07:07 PM
Micro speedwing build schoey Foamies (Kits) 46 Aug 08, 2005 10:22 AM
Mini SpeedWing Build: w/Solite SlowRider Foamies (Kits) 84 Dec 26, 2004 06:07 PM
