Espritmodel.com Heli Air
Old Nov 10, 2011, 10:16 PM
Sydney, Australia
Joined Dec 2004
Which 450 - Blade 450 or Trex 450 Sport V2
Finall getting around to buying a new heli to properly master. Had a HK 450 which I was learning reasonably well till crashed majorly.
So which would you get Blade 450 or the Align T-rex 450?
thanks
damiens75 is offline Find More Posts by damiens75
Old Nov 10, 2011, 11:02 PM
United States, CA, San Diego
Joined Nov 2011
align 450 pro v2
Izzie is offline Find More Posts by Izzie
Reply With Quote  (Disabled)
Old Nov 11, 2011, 12:23 AM
Sydney, Australia
Joined Dec 2004
Originally Posted by Izzie View Post
align 450 pro v2
Is that the FBL one?
Old Nov 11, 2011, 12:49 AM
San Diego, CA
Joined May 2004
since you're still new, go with a flybar T-Rex 450. I recommend the sport or the V2 because they are much more forgiving for beginners. You don't want to strip out the TT gears on every landing because it was a little rough. That is the usual for the Pro and beginners.
The V2 is the previous generation to the Pro and Sport that are out now. The Pro V2 has the FBL head and 3gx unit.
p51flyer is offline Find More Posts by p51flyer
Old Nov 11, 2011, 01:06 AM
Sydney, Australia
Joined Dec 2004
Ok thanks. I think something like this would be good then.
http://www.helihobby.com/product-p/kx015081.htm
Old Nov 11, 2011, 01:24 AM
Pittsburgh PA
Joined Dec 2004
why not get another HK 450 V2 all metal and use your current motor and esc? maybe upgrade whatever servos you were using and save a bundle? what radio do you have?
Cable Guy is offline Find More Posts by Cable Guy
Old Nov 11, 2011, 02:42 AM
Sydney, Australia
Joined Dec 2004
I think I would prefer to pay the extra this time and go genuine, those damn hex screws of the HK kept stripping even with light force.
Radio is a JR XG8. I fly plenty of fixed wing electric still.
Old Nov 11, 2011, 08:44 AM
DCT1's Avatar
Joined Oct 2008
Fool me once ,, shame on you...
Fool me twice,, shame on me...!!!
HK= JUNK..!
DCT1 is offline Find More Posts by DCT1
Old Nov 11, 2011, 09:34 AM
Joined Nov 2011
HK= JUNK..!
Looks like dct1 Is gearing up to start another thread derailer so he can sit back and watch and remain silent.
Old Nov 11, 2011, 11:51 AM
Pittsburgh PA
Joined Dec 2004
there is nothing wrong with buying genuine, but in reality the quality of the HK it up to PAR and the value surpasses many brand names.
As far as stripped screws,, i have recently built 2 HK helicopters and haven't had a single screw strip.
Old Nov 11, 2011, 12:19 PM
Ranandar's Avatar
Kentucky
Joined Dec 2008
Roll your own price comparison
TRex 450 Sport Super Combo: $500
Plus you still need to buy a receiver.
My 450 Sport Clone: $168 Including all shipping.
Including the receiver.
My clone flies very nice thank you.
Yes, those out-of-tolerance hex head screws are a problem.
I had to fabricate an out-of-tolerance hex driver to match them.
Ranandar is offline Find More Posts by Ranandar
Old Nov 11, 2011, 12:26 PM
Rocket Programmer
jasmine2501's Avatar
United States, CO, Golden
Joined Jul 2007
Yeah if you're stripping screws, getting a Trex isn't going to solve that issue, using a lighter touch and thread-locker will solve that issue. The torque you need on those little screws isn't very much - about as much as you can apply with thumb and forefinger on a skinny screwdriver handle. They just need to be snugged up, not whammed down hard. If you use thread-locker correctly, that will be sufficient. Then, when you need to take them out, don't even attempt to loosen them without applying some heat first.
jasmine2501 is offline Find More Posts by jasmine2501
Old Nov 11, 2011, 03:50 PM
Team Daedalus
Wolveslayr's Avatar
Joined Jun 2008
Great answer and one I am finally getting!
Over tightening certain screws can effect frame geometry, tail assembly and on. Just because a screw can be tightened another 1/4 turn doesn't mean it should be. Learn when to stop based on resistance. I'm not going to make a sweeping recommendation, but when it starts getting tight stop. Check other nearby screws and gently try them to see if it's the same resistance.
As soon as I patent my torque display hex driver I will let you know. Seriously people working on the real thing can't over torque a screw. Be sensitive to that!
To answer your question. I have neither heli but someone closer to the novice flyer might benefit from a Blade 450. Jasmine probably has a better idea on that.
Enjoy the journey.
Wolveslayr is offline Find More Posts by Wolveslayr
Old Nov 11, 2011, 04:26 PM
sirs69's Avatar
United States, MO, St Peters
Joined Apr 2011
b450. It flies and is adjusted out of the box. If you want to build, the align or similar brand..
sirs69 is offline Find More Posts by sirs69
Old Nov 11, 2011, 04:30 PM
sirs69's Avatar
Joined Apr 2011
Another comment to make, you will end up fixing your Blade 450, so there's plenty of time to learn the setup and mechanics ... don't worry
Wanted TREX 450 Sport or V2 tail DudeInMyrtleBch Aircraft - Electric - Helis (FS/W) 0 Jul 27, 2011 06:41 PM
Discussion Trex 450 SE V2 or Trex 450 Sport TokageWeasel Mini Helis 0 Jun 23, 2010 05:37 PM
Wanted WANTED: Trex 450 head, Air frame or both. Full or just the top hub V2 Sport or Pro PittJitsu Aircraft - Electric - Helis (FS/W) 0 Feb 15, 2010 02:47 AM
Discussion used trex 450 SE v2 OR new trex 450 sport Yen Beginner Training Area (Heli-Electric) 10 Aug 15, 2009 09:35 AM
