This thread is privately moderated by scharck, who may elect to delete unwanted replies.
Old Nov 10, 2011, 05:43 PM
scharck is offline
Find More Posts by scharck
Trader Rating: 26
The Great White
USA, CA, El Cajon
Joined Feb 2005
Trader Rating: 26
Sold
Virtually NIB Hacker A50-16s motor
CHECK THIS OUT! This is the motor that is recommended for popular 50/60 size pattern and 3D planes up to 7 lbs; however it will work great in sport planes up to 10 lbs. I installed this motor into a 70" 3DHS AJ Slick and flew exactly three flights. It just didn't have the vertical power I wanted for this plane. I use the same motor in my 62", 7 lb. pattern plane and it has more than enough power for unlimited verticals.
Asking $100 shipped to you CONUS. Thanks for looking!
Here are the specifics for the motor:
The Hacker A50 Series motors are designed for the very popular .60 size models. Intended as a direct replacement to power your model with quiet and clean electric power. The powerful and efficient 14-pole "Outrunner" Brushless motor design creates massive torque, which will allow you to direct drive larger props without needing a gearbox. This motor features Oversized bearings, curved Neo-magnets, and uses High-efficiency stator design. Additionally you will find a special large concentric bearing located in the rotor to support the rotating mass during extreme 3D maneuvers. A cooling fan is mounted on the motor to provide proper motor cooling for closed cowling or helicopter applications. Features an integrated 8mm threaded shaft and prop adapter for superior reliability.
Technical Specifications for Hacker A50-16S
Motor Type: Brushless, Outrunner
Weight: 395g (13.93 oz)
Power: 1250 Watts
RPM/Volt (KV): 378
Continuous Current: 40A
Burst Current: 55A
Recommended Propeller: APC 14x7 to 17x10
Recommended Lithium Polymer Battery: 5-7 cell, 3700-5000 mAh
scharck is offline Find More Posts by scharck
Old Nov 10, 2011, 05:54 PM
dawhale is offline
Find More Posts by dawhale
Trader Rating: 81
USA, CA, Valencia
Joined Mar 2011
Trader Rating: 81
Version 1 or 2
dawhale is offline Find More Posts by dawhale
Old Nov 10, 2011, 08:51 PM
scharck is offline
Trader Rating: 26
The Great White
USA, CA, El Cajon
Joined Feb 2005
Trader Rating: 26
Version 1
Old Nov 11, 2011, 10:09 AM
nsg is offline
nsg
Find More Posts by nsg
Trader Rating: 62
nsg
Yardley, PA
Joined Sep 2006
Trader Rating: 62
Is it 50-16, or 50-12? I thought 50-16S has kV of 360 or so.
nsg is offline Find More Posts by nsg
Old Nov 11, 2011, 10:18 AM
scharck is offline
Trader Rating: 26
The Great White
USA, CA, El Cajon
Joined Feb 2005
Trader Rating: 26
Thanks for noticing this. It is an A-50 16S, but you are correct, I had the wrong kV posted. I have corrected the kV to read 378 as shown on Hacker Technical data that comes in the box. Thanks again.
Ron
Old Nov 14, 2011, 12:08 PM
scharck is offline
Trader Rating: 26
The Great White
USA, CA, El Cajon
Joined Feb 2005
Trader Rating: 26
Price reduced to $100 shipped to you CONUS.
Old Nov 19, 2011, 07:18 PM
Bob Kelly is offline
Find More Posts by Bob Kelly
Trader Rating: 1
United States, CA, La Quinta
Joined Oct 2011
Trader Rating: 1
Very intrested..would like to send you a e-mail Or a PM.. would you send me a pm.
Bob Kelly is offline Find More Posts by Bob Kelly
Old Nov 21, 2011, 08:53 PM
scharck is offline
Trader Rating: 26
The Great White
USA, CA, El Cajon
Joined Feb 2005
Trader Rating: 26
Bob,
Absolutely! Sorry for the delay in answering. I check for PM daily, but don't always check on the listing site that often.
Ron
Sold Hacker A50-16s (New) vienquach Aircraft - Electric - Power Systems (FS/W) 0 Oct 01, 2011 06:44 PM
Sold Hacker A50-16s V1 vienquach Aircraft - Electric - Power Systems (FS/W) 0 Sep 21, 2011 01:42 PM
Sold Hacker A50-16S 378kv NIB bdiesel3 Aircraft - Electric - Power Systems (FS/W) 2 Aug 10, 2011 10:34 AM
Sold Hacker A50-16s ($80.00 shipped) vienquach Aircraft - Electric - Power Systems (FS/W) 0 Jul 20, 2011 01:03 AM
For Sale Ebay: NIB Fliton Edge 540 Freestyle w/ Hacker A50:16S Motor BigjamG Aircraft - Electric - Airplanes (FS/W) 2 Feb 14, 2008 12:13 AM
