Old Nov 10, 2011, 01:47 PM
RECORDCAP is offline
Find More Posts by RECORDCAP
United States, OH, Cincinnati
Joined Oct 2009
Builds money can't buy - share what The Dollarmodeler don't have :o)
Hi all i want to start this thread to share extraordinary modelers work in respect to building technology on rc modelplanes not availabe at kennedy composits, hobbyking.
Build not buy. Show what you have.
RECORDCAP is offline Find More Posts by RECORDCAP
Old Nov 10, 2011, 06:13 PM
invertmast is online now
Find More Posts by invertmast
United States, FL, North Port
Joined Mar 2004
invertmast is online now Find More Posts by invertmast
Old Nov 10, 2011, 06:49 PM
Joined Oct 2009
WOW. True Here my parts starting to upload.
The size of the rudder is about 20" high. Weight is 65g 2 servos included.
Old Nov 10, 2011, 08:11 PM
Ward Hagaman is offline
Find More Posts by Ward Hagaman
Ward Hagaman's Avatar
San Diego
Joined Mar 2003
Wow, Recordcap! More details please?
Ward Hagaman is offline Find More Posts by Ward Hagaman
Old Nov 10, 2011, 08:22 PM
Joined Mar 2004
That is impressive. I hope for your sake it was designed in CAD, as that would be a nightmare to try and figure out the size and shape of all those parts otherwise
Old Nov 10, 2011, 08:37 PM
BMatthews is offline
Find More Posts by BMatthews
B for Bruce
BMatthews's Avatar
The 'Wack, BC, Canada
Joined Oct 2002
There's ways around that if you plan it out right and don't mind doing much of the shaping after the basic "flat" structure is put together.
BMatthews is offline Find More Posts by BMatthews
Old Nov 11, 2011, 12:22 AM
Joined Mar 2004
I figured that was one way of doing it as well. I still wouldn't want to have to do it
Old Nov 11, 2011, 06:28 AM
TomCrump is offline
Find More Posts by TomCrump
ARFs Are Me
TomCrump's Avatar
Traverse City, Michigan
Joined Dec 2005
I'm a firm supporter of building, and not buying. Here are a few of mine.
TomCrump is offline Find More Posts by TomCrump
Old Nov 14, 2011, 11:01 AM
Joined Oct 2009
As requested here more details..
Here some more pictures.
USing Pinkfoam balsa and CF and transparent ultracote light.
Old Nov 14, 2011, 06:01 PM
Cheesehead is offline
Find More Posts by Cheesehead
Ego varius quis.
Cheesehead's Avatar
Wisconsin
Joined Nov 2003
That is very impressive.
Are those carbon laminate, or just painted black? The color is very striking.
Cheesehead is offline Find More Posts by Cheesehead
Old Nov 15, 2011, 05:35 AM
Mode One is offline
Find More Posts by Mode One
Closed Account
Joined Dec 2006
Wow Thermaler, does that ever bring back memories! Have any of those shown, actually even come from kits? What is the wing span of the Aquila. My stock one was 100 inches.
Mode One is offline Find More Posts by Mode One
Old Nov 15, 2011, 07:40 AM
Joined Oct 2009
Hi Cheesehead,
assume this is because of the packers()). The construction is a mix of Balsa, Pink foam and carbon fiber laminate, extruded profile trailing edge and stripes (all ribs are capped). At the end I "painted" it with black permanent marker adding zero weight. Final coating is done with Oracover light. Carbon fiber most towards the surface where stress occurs.
I found this article very helpful and learned from:
http://themmmclub.com/pdf/structure.pdf
Old Nov 15, 2011, 11:09 AM
Thermaler is offline
Find More Posts by Thermaler
Balsa breaks better
Thermaler's Avatar
Buchanan Mi
Joined Apr 2005
They are sort of from kits. I use the parts as patterns so when I oops I can rebuild.
The Aquila XL is a 150" version, they also did a 123" version called the Aquila Grande'.
Joe
Thermaler is offline Find More Posts by Thermaler
Build Log If You Have !New!,Different,Interesting Plane Models In Your Head You Can Share Here RcLento Foamies (Scratchbuilt) 19 Nov 25, 2011 03:57 PM
Found Anyone local have a t-pro mg90 servo I can come buy this weekend??? ddrummer508 Aircraft - Electric - Helis (FS/W) 0 Sep 24, 2011 11:49 AM
Discussion Don't forget us with money & lack of knowledge gabber865 Multirotor Talk 13 Apr 03, 2011 02:02 AM
Discussion Just Starting Out??? Don't Have Much Money??? No Problem!!!! flystoolow Beginner Training Area (Aircraft-Electric) 12 Jan 14, 2008 06:39 AM
Crawlers don't have to cost lots of money! MUD4FUN Off-road Cars 1 Sep 07, 2004 02:46 PM
