Old Nov 10, 2011, 07:44 AM
Kovit is offline
Find More Posts by Kovit
Fredericksburg, VA
Joined Aug 2008
trainer cord to hpp-22 adapter for aurora 9
as stated in the title, where do you buy a trainer cord to hpp-22 adapter when it is updated a firmware for the Aurora 9 transmitter itself, not module nor reciever?
Thanks.
Kovit is offline Find More Posts by Kovit
Old Nov 10, 2011, 02:34 PM
A.T. is offline
Find More Posts by A.T.
Joined Aug 2002
Hitec HPP-22 - Replacement Leads, Extensions & How To Update Optima buried in Models
Originally Posted by Kovit View Post
as stated in the title, where do you buy a trainer cord to hpp-22 adapter when it is updated a firmware for the Aurora 9 transmitter itself, not module nor reciever? Thanks.
The cable which connects an HPP-22 to the Aurora is supplied with the unit, not available as a separate lead.
(Not wired the same as a trainer lead)
. If original is lost or damaged, contact your service centre:
Hitec Warranty & Service
Note: Hitec USA only services North/South America and Canada. All other countries see appropriate distributor for service.
• If you are from a country that is outside North and South America, please contact the
Hitec distributor in your country for service.
Alternatively, DIY with a 3.2mm stereo plug and a servo lead wired as per attached picture.
(A "J" type servo plug with locating tab is recommended, ensures correct polarity at all times)
• Length overall should not exceed 30cm (12").
HPP-22 - Connector Leads
. How to extend length to model without loss of data.
. Provide access to Optima Transceivers buried in Models.
NB: If the data port can be accessed, built in transceivers do not need to be removed from a model,
see information regarding use of extensions:
Optima Transceiver - Update Firmware in situ
Extract:
Q. Can Optima be updated whilst still within model?
A. Yes - as per manual USB lead should not exceed 3' (1m) nor lead to HPP-22<>Optima exceed 12" (300mm). - quote:
. Tried upgrading several RX in large models with a extension lead ex HPP-22 but system would not recognise the transceiver.
. Changed USB lead to one with dual plugs to ports at rear of PC and system display would flash accepted then change to an error message.
. Connected a separately powered USB hub inline to HPP-22, the short lead as supplied with HPP-22 and
managed to update RX without removing them from models.
. If an extension lead is left attached to data port, suggest it be shortest possible and capped/labelled to
prevent other items, such as charging leads, being plugged in during a moments inattention.
The shortest possible copy of the original lead is best. One that has a similar S-01 servo plug at
the free end (to avoid bad connections & with protective cap,) so as to plug direct into HPP-22.
- Alan T. "
Alan Tong
Alan's Hobby, Model & RC FAQ Web Links (quick search = Ctrl+F)
A.T. is offline Find More Posts by A.T.
Sold Hitec Hpp-22 for aurora 9 $20 going4speed Aircraft - General - Radio Equipment (FS/W) 0 Nov 06, 2011 02:38 PM
Sold Hitec Aurora 9 w/Optima 9,Optima 6 and HPP-22 WestColoFlyer Aircraft - General - Radio Equipment (FS/W) 3 May 10, 2011 01:56 PM
For Sale Aurora 9 + 2 Optima 9's, HPP-22 too. Paul Naton Aircraft - General - Radio Equipment (FS/W) 2 Feb 23, 2011 08:20 PM
For Sale Aurora 9 + 2 Optima 9's, HPP-22 too. Paul Naton Aircraft - Sailplanes (FS/W) 4 Feb 18, 2011 11:53 PM
