Old Apr 26, 2012, 12:36 AM
Spitfire1954 is offline
Find More Posts by Spitfire1954
Spitfire1954's Avatar
United Kingdom, England, East Riding of Yorkshire
Joined Jan 2011
Hi Joe
Thanks for your input and for taking the time to research it, much appreciated (made me feel a lot better) – I'm covering with Solite so should be able to keep the weight to something like that figure.
Regards
Charles
Spitfire1954 is offline Find More Posts by Spitfire1954
Old Apr 26, 2012, 07:05 AM
Bill Smudge is offline
Find More Posts by Bill Smudge
Bill Smudge's Avatar
United States, KY, Bowling Green
Joined Jul 2011
Wonderful job your doing there Charles!!
How many hours to do the planking? It looks GREAT...
Hope your weight works out OK, seems like every plane I build ALWAYS ends up at least 10 to 20% heavier than I thought it would be.... they have all flown though never had one so portly it wouldn't get off the ground
Enjoying your thread.
Bill
Bill Smudge is offline Find More Posts by Bill Smudge
Old Apr 26, 2012, 10:38 AM
Joined Jan 2011
Hi Bill
It took about 12 hrs in total to get the fuse to the state as you see it – keeps me out of the pub!
Very satisfying when you get the right result!
Charles
Old Apr 30, 2012, 07:20 AM
Parkk is online now
Find More Posts by Parkk
Parkk's Avatar
Near Austin, TX
Joined Dec 2008
The 17's looking great! About "glueing" the wings into place. I was building my GB-17 when someone I know crashed theirs on takeoff, they had glued the wings into place and was a pain to repair. So on mine after sliding the spars into the slots in the fus. I drilled two holes per spar and held them into place with dows. That way if I ever have bad damage I can just detach the wing(s).
Parkk is online now Find More Posts by Parkk
Old Apr 30, 2012, 10:37 AM
Joined Jan 2011
Hi Parkk that's a good idea I will have to give it some thought
Charles
Old Apr 30, 2012, 10:12 PM
Sherman68 is offline
Find More Posts by Sherman68
Sherman68's Avatar
United States, NE, Bellevue
Joined Mar 2012
This is impressive, gives me hope for my project!
Sherman68 is offline Find More Posts by Sherman68
Old May 17, 2012, 01:39 AM
Joined Jan 2011
Hi Everyone
Some images showing the installation of the wiring amazingly everything worked first time with no problems plus two images taken by a photographer friend of mine at RAF Binbrook in Lincolnshire during the filming of Memphis Belle in the late eighties William Wyler directed the original film back in 1943, his daughter, who appears in one of the attached images alongside David Putnam also directed during the making of the second movie Robert Morgan and other crew members were also present for the shoot that's inspiration!
Old May 18, 2012, 01:13 AM
Joined Jan 2011
Some images showing the completion of the wing sheeting, tidying up of the electrics installation, rudder and elevator glued in place and rudder/tail wheel connected to the servo via Dubro cable
Old May 19, 2012, 05:22 PM
Smokin' Beaver is offline
Find More Posts by Smokin' Beaver
Registerd Beaver
Smokin' Beaver's Avatar
Australia, WA, Warwick
Joined Jul 2003
Looking fantatsic '54
Phil
Smokin' Beaver is offline Find More Posts by Smokin' Beaver
Old May 27, 2012, 10:48 PM
kzart is offline
Find More Posts by kzart
United States, IN, Elberfeld
Joined Feb 2011
hey
Im On to this one too...
I ordered some hk retracts and on hold for $ for motors considering cf2812... The hk1811 2900 kv didnt work so well for me (think its cause I used 3 cells...only worked on the p-47) Also, considering micro servo for bomb doors... My weight right now is 450 grams w 4 servos installed and 4 channel receiver for test purposses (will switch to 6 channel when it arrives. The wing tip in one image is an hk sbach vry similar flight surfaces at 1100 grams and running on 425 watts of pwr so I figure I need 400 watts for this project and similar weight restriction. Found one called the golden hind with image of women in golden knickers on tail w yellow tail control surfaces (think its from the 5th bomber group.
kzart is offline Find More Posts by kzart
Old May 28, 2012, 08:27 PM
kzart is offline
Joined Feb 2011
re
I built 1/2 and added the 2nd sides ribs to it. I don't think my way is the right way to do it, but in the past I had trouble withe the plastic parts not fitting correctly. Since I sheet it with the thin balsa, everything gets a little bigger than if it was coated with paper or a monocoat type material Everything is very fragile before I sheet it But, the sheeting adds strength (and some weight) Honestly, its all 1 big experiment for me I would assume if you are going to coat it with paper or monocoat, You will want the strength of the extra ribs.
Old Jun 15, 2012, 01:26 AM
Joined Jan 2011
Hi Everyone update on this build have managed to get the nacelles and cowlings fitted, not as daunting as first thought. Almost ready to start covering with silver Solite I am going to use black Solite cut to shape for the windows etc.
Old Jun 15, 2012, 08:02 AM
Steve85 is online now
Find More Posts by Steve85
The "pro" in procrastination
Steve85's Avatar
Canada, ON, Kingston
Joined Mar 2004
Charles,
Looking really nice! As one who started this model several years ago only to bog down in its complexity, I admire your perseverance, especially given the beautiful job you've done on the insert planking. Perhaps once I finish my Lancaster I'll dust off my Fort and see what can be done...
Steve
Steve85 is online now Find More Posts by Steve85
Discussion Guillows Bf-109 Kit 505 Conversion admiral_adonis Scratchbuilt Indoor and Micro Models 31 Aug 17, 2014 08:08 AM
Build Log Guillows #905 P-51 Mustang RC conversion jah00 Scale Kit/Scratch Built 63 Oct 29, 2013 06:05 AM
Build Log Guillows Cessna 172 Conversion usa1045 Scale Kit/Scratch Built 41 Dec 08, 2011 11:46 PM
For Sale B-17 Guillows RC Conversion Flight Tested. Tuctronics Aircraft - Electric - Airplanes (FS/W) 7 Aug 04, 2011 11:57 PM
