Charles |
I opted for the insert planking method as I think it adds strength to the finished job and also keeps the original profile, shape and size of the prototype and to be honest I enjoy that building method. Charles |
Hi Everyone – some updated images – spent hours sanding the fuselage which is almost there (the filler used is a lightweight two part which is very easy to sand), have the underside of the wings sheeted but not yet sanded, the ailerons are fabricated and the tail feathers fit ok – am almost ready to start the electrics in the wings so that the top surfaces can be sheeted. I was considering having the tail wheel as a castoring unit not connected to the rudder – anyone have thoughts on that?
Wow! I admire the patients it took to cut and fit all those insert pieces. That is very nice work. What does it weigh?
Mine flew ok at 20oz but was underpowered with the brushed IPS motors. It actually had the power but the pitch speed was too low and I was already using the lowest gear ratio. It flew at just above the stall speed and if turned too tight it would spin in. You are using 10 gram motors? Glenn |
Oh yeah, about the tail wheel.
I tried a castoring tail wheel, once. With no brakes to control direction it is nearly impossible to steer using rudder alone. I've found it is much easier to steer with the tailwheel in a fixed position. On my B-17 I linked the tail wheel to the rudder. The rudder pushrod is connected to the rudder horn and a short link from the horn to the tail wheel horn. Glenn |
| Thread Tools | |
| Build Log Guillows #905 P-51 Mustang RC conversion | jah00 | Scale Electric Planes | 40 | Jan 18, 2013 01:13 PM |
| Build Log Guillows Cessna 172 Conversion | usa1045 | Scale Electric Planes | 41 | Dec 08, 2011 11:46 PM |
| Discussion Guillows Bf-109 Kit 505 Conversion | admiral_adonis | Indoor and Micro Models | 28 | Sep 28, 2011 05:32 AM |
| For Sale B-17 Guillows RC Conversion Flight Tested. | Tuctronics | Aircraft - Electric - Airplanes (FS/W) | 7 | Aug 04, 2011 11:57 PM |
