Old Nov 10, 2011, 04:15 AM
Lancair is offline
Find More Posts by Lancair
Lancair's Avatar
near Byron Bay, Australia
Joined Sep 2002
Li-Po Versus traditonal power source for gliders ?
Ive been away from the hobby a few years and on my return I find everyone talking about using Li-Po's for glider power source.
Whats the advantage other than the potential for long flight times between charges ?
To my perhaps uneducated eye, it seems to be needing extra circuitry and more potential for accidental release of magic smoke from incorrect connection and for post impact damage to Li-Po ?
Ive been replacing my old NiCd flight packs for new NiMh. 800mah is more than enough for a 4 servo glider to fly for a few hours. Way more than Ill do in a typical day at the slope with that one model.
Lancair
Lancair is offline Find More Posts by Lancair
Old Nov 10, 2011, 07:12 AM
Mark Wood is offline
Find More Posts by Mark Wood
characters welcome!
Mark Wood's Avatar
United States, CA, Bear Valley Springs
Joined Feb 2000
The only advantage to me would be weight. That said, I use only quality Nimh or LiFe for my radio systems in gliders.
mw
Mark Wood is offline Find More Posts by Mark Wood
Old Nov 10, 2011, 07:58 AM
Woodstock 1 is offline
Find More Posts by Woodstock 1
Woodstock 1's Avatar
Ireland, County Kerry, Kerry
Joined Dec 2005
The advantages are mainly:
LOW SELF DISCHARGE!!
This makes for a huge, life-changing difference. Charged planes can be stored or left in the car for weeks or even months on end, and will still be instantly ready to fly. No more charging every plane the night before hassles. This is particularly important for me, as I travel with some gliders all the time, and I often don't know when I am or not going to fly. Whatever, my planes are ready to go!
I do not now have a single NiMh battery in a plane. I DO have a box full of NiMh's in very good nick. Mark, you wanna ?
Woodstock 1 is offline Find More Posts by Woodstock 1
Old Nov 10, 2011, 09:50 AM
dawsonh is offline
Find More Posts by dawsonh
Flagstaff, AZ
dawsonh's Avatar
USA, AZ, Flagstaff
Joined Mar 2003
Another advantage to LiPo and LiFe batteries is that they have tremendous "C" ratings and thus are very resistant to brown outs.
2.4 receivers are their cpu-based. If you have a low voltage situation (low pack, a stalled servo... or just big servo drain), the receiver stops working and may take several seconds to re-boot.
I am starting to convert to LiFe in my larger gliders (many servos) for this reason.
LiFe has the advantage over LiPo in that it is compatible with most 6 volt servos... and does not have the "fire" issues. Lipos are nice because they are very inexpensive and come in small sizes for light weight gliders. Most 2.4 receivers and some servos, like the Dymond 4.7 and 6.0, have no problems with the high (7.4 v) voltage.
dawsonh is offline Find More Posts by dawsonh
Old Nov 10, 2011, 11:26 AM
Dale Thompson is offline
Find More Posts by Dale Thompson
F3J-F3K-F3F- What to Fly??
Dale Thompson's Avatar
Cupertino CA
Joined Aug 2005
I only use Li-Po's in my DLG's for the weight advantage.
If you forget to turn off the plane and drain the Li-Po too far down then you must replace it. So far I've only had to replace 2 packs in 4 months.
I'm getting much better at remembering.
I perfer Eneloop's where ever possible. Costco is now selling 10 Eneloop AA's for $19.99. Good deal.
Dale Thompson is offline Find More Posts by Dale Thompson
Old Nov 10, 2011, 12:21 PM
chip.greely is offline
Find More Posts by chip.greely
chip.greely's Avatar
Carlsbad, Ca
Joined Mar 2007
Sanyo Eneloop AA & AAA's at Costco
chip.greely is offline Find More Posts by chip.greely
Old Nov 10, 2011, 01:34 PM
flyzwell is offline
Find More Posts by flyzwell
flyzwell's Avatar
So Cal
Joined May 2008
Eneloops and other off the shelf "pre charged" batts seem to have a low self discharge rate similar to Lipos.
flyzwell is offline Find More Posts by flyzwell
Old Nov 10, 2011, 02:24 PM
characters welcome!
Mark Wood's Avatar
Joined Feb 2000
True, but they don't do as well as Nimh or Li at high discharge rates in operation.
mw
Old Nov 10, 2011, 02:36 PM
Daemon is online now
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
But very few slope planes generate a high enough discharge rate for that to matter.
If I need to run 6 digital servos in a big plane, I'll just use a 5 cell Eneloop pack.
The heavier NiMH pack in a slope plane is rarely an issue since we're typically adding
lead to the nose anyway.
Over the years I've seen enough NiCAD and NiMH battery packs smashed on rocks
to take the risk of fire by smashing a Lipo pack very seriously. We highly
discourage their use on our local slopes, as the first fire started would likely
be the last time we ever get to fly there. Not always a popular decision
with the newer pilots.
ian
Daemon is online now Find More Posts by Daemon
Old Nov 10, 2011, 02:41 PM
Joined Dec 2005
Lets's put this fire risk thing into perspective: not everyone on this planet lives in a semi-desert or high fire risk zone, and last time I looked this was an international forum. If my LiPo - powered planes caught fire after crashing (and such a thing has NEVER happened to me - and I crash a LOT), we'd be glad of the spot of warmth !
Old Nov 10, 2011, 02:52 PM
Carlsbad, Ca
Joined Mar 2007
I'm closing my eyes and picturing lush rolling green hillsides,...
.....and not the 6month old dead dried weeds that make up the So Cal masses
Point taken
Old Nov 10, 2011, 03:04 PM
snakecrew is offline
Find More Posts by snakecrew
weisenflymanheimer
snakecrew's Avatar
Crested Butte, Colorado
Joined Dec 2007
what about these cr2 lithium(photo cell) for lightweight dlg types.
should I solder the unrechargebles then replace them when they go dead or get the rechargeble kind?
it is hard to get snow, dirt and ice, and rocks to catch fire up here.
snakecrew is offline Find More Posts by snakecrew
Old Nov 10, 2011, 03:26 PM
satinet is online now
Find More Posts by satinet
F3B
satinet's Avatar
Warwickshire, England
Joined Sep 2006
nimh, lipo and life are all workable.
each type has pros and cons that suit a particular plane or person, but they can all be used if they are, importantly, used correctly.
In terms of the "C" rating of lithium types, as most lipo types will be regulated, say to 5amps (AA nimh cells are about 7amps max discharge) they are not particularly special. A lot of LIFE (e.g hyperion) packs actually have a lower max discarge then nickel types. e.g a 1450 hyperion life has a max discharge of about 7 amps/hr whereas a 2/3a nimh pack could easily have a max discharge of 15mps.
nimh has a bit of self discharge and small cells are a bit weedy, lipo needs a regulator, LiFe is hard to measure the capacity (and might need a regulator).
Take your choice. Lipos have a potential fire risk as well.
satinet is online now Find More Posts by satinet
Old Nov 10, 2011, 06:41 PM
MATIN is offline
Find More Posts by MATIN
Just Toss It !!!
MATIN's Avatar
United States, CA, San Diego
Joined May 2004
I other words I guess you are saying (and far from me to put words your mouth!) that everyone should look out of the car window before deciding on battery type?.....Hell, I can live with that!
Matin
MATIN is offline Find More Posts by MATIN
Old Nov 10, 2011, 08:07 PM
Lancair is offline
Lancair's Avatar
Joined Sep 2002
Hey thanks guys for the answers. I think Ill stick to NiMh. I dont mind charging planes, it's all part of the sloping experience getting everything ready the night before, or that morning as I usually am doing.
Lancair
Sold Lightning Power Li-po 300mAh 3.7V 1S 35C RcHeli_Newb Aircraft - Electric - Helis (FS/W) 3 Nov 10, 2011 10:23 AM
Discussion Resettable Polyswitch/Fuse for Li-Po/Li-Ion - ORIENTATION (+/-) ??? Gyroguru Batteries and Chargers 3 Sep 26, 2011 08:54 AM
Discussion Resettable Polyswitch/Fuse for Li-Po/Li-Ion - ORIENTATION (+/-) ??? Gyroguru Radios 2 Sep 25, 2011 01:12 PM
Discussion Li-Po Power Board for Spektrum and JR 6102 Dirty Hans Radios 0 Apr 15, 2011 05:34 PM
For Sale Thunder Power Li-Po Cell Balancer TP-205 for 2 to 5 cell Li-Po Packs Highfly! Aircraft - Electric - Batteries & Chargers (FS/W) 1 Feb 24, 2010 01:42 AM
