Old Nov 10, 2011, 02:04 AM
dualplover is offline
Find More Posts by dualplover
Joined Nov 2011
Question
infrared combat system
maybe off topic but couldn't find a suitable thread
looking for kits or stand alone units for infrared combat with RC vehicles
i know you can buy off the shelf battle tanks, helicopters and daleks that use infrared but i'm wondering if you can buy any system that can be attached to any RC vehicles to create a battle game?
dualplover is offline Find More Posts by dualplover
Old Nov 10, 2011, 05:13 PM
leccyflyer is offline
Find More Posts by leccyflyer
Sloping off....
leccyflyer's Avatar
United Kingdom, Aberdeen
Joined Sep 2000
Do a search on here for CSM Airwars - IR combat modules that were available maybe 8-10 years ago. There are definitely threads on here discussing the system. I still have a couple in the cupboard myself.
leccyflyer is offline Find More Posts by leccyflyer
Old Nov 11, 2011, 12:25 AM
Joined Nov 2011
yes i found those however they lead me to a dead end as they are no longer commercially available, what i was hoping to know is if any systems are available now?
Old Nov 11, 2011, 09:53 AM
learn2turn is offline
Find More Posts by learn2turn
United States, MA, Medfield
Joined Jul 2010
Maybe there is a toy system that could be hacked apart and retrofitted into a plane.
I remember playing with the Laser Tag systems that were sold in the mid-80s and they worked very well.
learn2turn is offline Find More Posts by learn2turn
Old Feb 01, 2012, 04:42 PM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
http://www.rcgroups.com/forums/showp...2&postcount=17
Charles
Old Feb 04, 2012, 06:53 PM
dlw151947 is offline
Find More Posts by dlw151947
Buzzsaw
Joined Mar 2007
http://www.advantagehobby.com/?cat=89&manufacturerid=36
Our group has used this unit for several years ago and are going to start using them again on our planes.We haven't had any problem with them.
DW
dlw151947 is offline Find More Posts by dlw151947
Old Feb 04, 2012, 06:59 PM
Buzzsaw
Joined Mar 2007
The CSM AIRWARS system is a revolutionary way to enhance the enjoyment of RC models by creating totally new ways to compete with your friends. Although primarily designed for aerial combat use in EPP foam slope soarers, with its high degree of programmability it can be applied in many ways to all types of R/C models.
Features of the AIRWARS system.
* Non-contact combat system fires Infra-red 'bullets'.
* Eye safe - does NOT use lasers.
* 'Bullets' coded to identify who hits whom.*
* All data logged on board - no secondary radio links used.
* Programmable optional servo response to hits.*
* LED indicator shows firing status and hits count.
* Two operating modes - Triggered and continuous firing.
* Automated PC based scoring system records combat results for up to 30 pilots per contest.*
* Scoring system uses pilot names (saved in AIRWARS unit) for simple contest organisation.*
* Scoring system keeps permanent detailed records of all combat.*
* Programmable fire burst length & ammunition limit.*
* Small (25mm x 50mm x 9mm) and light (approx. 25g).
* Simple, quick installation.
Each AIRWARS unit has an infra-red gun which emits coded 'bullets'. The unit is also equipped with a 'Target' sensor which detects when it has been hit by a coded bullet from another AIRWARS unit.
Each hit on the target is recorded in the AIRWARS non-volatile memory, and, if desired, the model can be made to respond to being hit with a programmable sequence of servo movements.
The number of hits on the target is shown by the flashing of the FIRE / HITS indicator LED and this can be used to score small informal battles.
name on them!
Old May 10, 2012, 11:15 PM
Joined Nov 2011
thanks but these airwars systems besides being over 13 years old don't seam to be available to buy
decided to design own system as i cant find anything currently available
Old May 11, 2012, 03:44 PM
ctrout is offline
Find More Posts by ctrout
Waiting for the paint to dry.
ctrout's Avatar
Pasadena Maryland
Joined Oct 2009
Without a plane design to use it with it may not be much good to you but I do have them
Available from Air2Air Combat LLc.
The program chip board for the newer bulbs are not built.
Trout
ctrout is offline Find More Posts by ctrout
Old Jun 12, 2012, 07:54 PM
moeplanes is offline
Find More Posts by moeplanes
Joined Jun 2012
Havoc heli
My idea was to have a seperate trigger to avoid complications with the transmitter and then just have a havoc heli laser battle pack. comes with two helis, just take out the receiver module in there and wire in the motor from your tx somehow, it would take tinkering and soldering skills, but it is small, lightweight and inexpensive if you purchase one from ebay, I'v seen as low as 40.00$ for one.
moeplanes is offline Find More Posts by moeplanes
Old Jun 13, 2012, 01:26 AM
ctrout is offline
ctrout's Avatar
Pasadena Maryland
Joined Oct 2009
Built a few flash bulb infrared system for line control Combat but never built planes for them.
Still to much for micro flights though.
Maybe one day~
Old Jul 16, 2012, 05:29 AM
sh4nce is offline
Find More Posts by sh4nce
sh4nce's Avatar
BelgiŽ, Brussel, Brussel
Joined Nov 2010
If you're willing to build one yourself using an arduino mini pro and some very basic electronics check http://redmine.hcpl.be/projects/tag-combat/wiki (I also opened a thread here about this project). Very few components and easy to make. Code is on the project website (can be adapted to your needs).
sh4nce is offline Find More Posts by sh4nce
Old Jul 20, 2012, 01:37 PM
ctrout is offline
ctrout's Avatar
Pasadena Maryland
Joined Oct 2009
Set your forums up. maybeI can help add to your work.
we mix radio release ribbons "refection tape" ,IR ground and air 2 air release to keep the parts falling off in the area of the field ect.
Planes set up fot night use will also help the IR / momentary FPV to aim ect.
Its a little more work but your one of the few in the ball park.
Trout
Old Jul 21, 2012, 05:02 AM
sh4nce is offline
sh4nce's Avatar
Joined Nov 2010
Trout
There is a general forum on the project website (if that is what you're asking for). If you want to contribute it's better to register and give me a notification by e-mail or private message here. Then I'll give your account the needed rights to edit wiki and others.
Discussion Near Infrared Camera? jtprouty FPV Talk 9 Oct 05, 2011 04:47 PM
Sold Infrared combat helis (apache and airwolf) $25 RC_Bob Aircraft - Electric - Helis (FS/W) 0 Apr 12, 2011 12:04 AM
2 axis infrared stability system!!?? morage_key_ring Beginner Training Area (Aircraft-Electric) 3 Nov 16, 2005 09:35 PM
2axis infrared stability system??!! morage_key_ring Scratchbuilt Indoor and Micro Models 2 Nov 16, 2005 04:59 AM
IRWars Infrared Combat System Mat Parkflyers 0 Aug 04, 2004 09:56 PM
