Old Jun 03, 2012, 04:03 AM
Robert Belluomini is offline
Find More Posts by Robert Belluomini
EDF Jet Jam 2016, June 16 -19
Robert Belluomini's Avatar
United States, KY, Crestview Hills
Joined Dec 2000
Fyingfoam.com could have cores cut inside a week
http://www.flyingfoam.com/QuickOrderEPS.html you can spec the demensions online.
Robert Belluomini is offline Find More Posts by Robert Belluomini
Old Jun 03, 2012, 04:45 AM
pavcon is offline
Find More Posts by pavcon
Κύπρος, Λευκωσία, Πέρα Χωριό
Joined Jan 2010
Hello ..
I'm new to tihs thread but I was around youtube watching vids of this plane for quite sometime
anyone built this jet with a stumax setup yet?
preferably a 700-68-1200 on 10s?
and I vebeen reading random posts for the past two hoursin this thread...
so HET havent come out with a new elevator design yet. correct?
pavcon is offline Find More Posts by pavcon
Old Jun 03, 2012, 05:30 AM
Knife Liddle is online now
Find More Posts by Knife Liddle
Lee Liddle
Knife Liddle's Avatar
Carrollton, Tx
Joined Dec 2006
Originally Posted by Robert Wagoner View Post
As we proceed were looking for some more constructive opinions at this point. 2 - 2Kg metal gear servos in the center with 3 spread out hinges on each side.
Stab 1 and 2 only require new control surfaces but Stab 3 would need a new front stab mold, not a problem if that's what's needed.
--RW
Robert, if making a new stab mold is not a problem, I`d like to suggest a 4th option. This would keep the elevator area basicly unchanged, keeps the outline close to the original, and will taper the cord of the elevators smaller toward the tip. One other minor change that I believe is important, the outer ends of the elevators run parallel to the line of flight.
Also I think that the elevator servos could be moved forward some with this design.
Here`s the best that I could do with Paint.
Knife Liddle is online now Find More Posts by Knife Liddle
Last edited by Knife Liddle; Jun 03, 2012 at 08:09 AM. Reason: Made note about elevator servos
Old Jun 03, 2012, 05:33 AM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
Originally Posted by pavcon View Post
Hello ..
Only a few of the new XL design have flown, and none have had a Stumax in them as far as I know. Corsair Nut is using a Jetfan on 8s with a 1500kv motor.
HET is now working on a new elevator design.
Old Jun 03, 2012, 06:55 AM
Brickyard is offline
Find More Posts by Brickyard
Callsign blocked
Brickyard's Avatar
United States, NY, New York
Joined Dec 2008
--RW
Isn't 3 what your trying to avoid? (controlling the elevator by its smallest point). 1 changes the profile to much (although it should work), that leaves "2". Or the absolute best option "4" which Knife Liddle suggested
Brickyard is offline Find More Posts by Brickyard
Old Jun 03, 2012, 07:42 AM
heychas is offline
Find More Posts by heychas
"My grandma wants to fly jets"
heychas's Avatar
Richmond, VA
Joined Feb 2008
I'm with Brickyard... I like 2 and 4. No way to #3.
heychas is offline Find More Posts by heychas
Old Jun 03, 2012, 08:13 AM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
To be clear, on #3 I think that Robert is suggesting a constant cord elevator (just the darker brown portion) not including the faded out brown part.
Mine is different in that the elevator cord gets smaller toward the tip and the outer end of the elevator is not angled outward. It runs in line with the line of flight (or the centerline of the airframe). Also I`ve reduced the amount of sweep in the curved leading edge at the tip. This matches the wing tip a little better and keeps the part of the stab just outboard of the elevator tip more of a constant width instead of getting wider at the trailing edge.
These are fine tuning points, but having lost $700 worth (total loss) of Original Sniper 90 due to elevator flutter, I think these minor changes are needed. Regardless of what HET decideds to do, this (pic on the right) is what my XL stab/elevator will look like when I get one.
Old Jun 03, 2012, 08:37 AM
gbmoore is offline
Find More Posts by gbmoore
Colorado Springs, Co
Joined May 2002
If we call Lee's version option # 4
My vote is 4, 3, 2, 1
Greg
gbmoore is offline Find More Posts by gbmoore
Old Jun 03, 2012, 09:02 AM
SCALEFAN is offline
Find More Posts by SCALEFAN
Done it all
United States, CA, Corona
Joined Feb 2006
I like Lee's version #4, but all versions as depicted in the drawings will not work well without minor redesign of the stab mounting to the tailcone.
It's not quite as easy as everyone thinks, the two servos will have to be mounted more forward on the stab, in front of the spar that runs lengthwise across the stab. If mounted toward the trailing edge, the tail cone strength will be compromised.
SCALEFAN is offline Find More Posts by SCALEFAN
pavcon is offline
Joined Jan 2010
Thanks forthe reply. I guess I will have to wait
Old Jun 03, 2012, 09:19 AM
pavcon is offline
Joined Jan 2010
Double post
Old Jun 03, 2012, 10:06 AM
Michael Paxton is offline
Find More Posts by Michael Paxton
Hey Ya'll!! Watch THIS!!
Michael Paxton's Avatar
Nashville TN.
Joined Mar 2006
I love the look of this. But if it had come like this, I would still have moved the servos out into the stab middle section for strength.
Michael Paxton is offline Find More Posts by Michael Paxton
Old Jun 03, 2012, 10:22 AM
pdawg is offline
Find More Posts by pdawg
Need 4 Speed!
pdawg's Avatar
United States, OH, Dayton
Joined Apr 2004
Robert,
I think option 3 is the best of the 3 options. The next question is whether the elevator still has enough surface area....probably so. Lee is correct that his option 4 is the best for form and function but I think option 3 will get the job done!
pdawg is offline Find More Posts by pdawg
Last edited by pdawg; Jun 03, 2012 at 11:10 AM. Reason: Jcdfdr pointed out the hingelines change in option 3
Old Jun 03, 2012, 10:24 AM
SCALEFAN is offline
Done it all
Joined Feb 2006
They won't fit that way, the servos need to be more forward, in front of the spar. It will work perfect that way. The fuse is actually cut out wider in that area so the servos can protrude into the tail cone.
The stab is marked with a cut out line right over the spar, the alternate drawings show the two servos mounted where the single servo is mounted, won't work very good in this position. They need to be as close to the leading edge of the stab, with a support that goes from the center of the spar to the leading edge of the stab, perpendicular.
Old Jun 03, 2012, 10:33 AM
jcdfrd is offline
Find More Posts by jcdfrd
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
pdawg
I think you may have misinterpreted #3, I also like Knife's the best with tapered elev and so if your going to go with #3 Robert, then you might as well do Knifes version #4
so my pref is 4,3,2,1
jcdfrd is offline Find More Posts by jcdfrd
Cool New HET L-39 90mm by EJF.com AceMigKiller Electric Ducted Fan Jet Talk 706 Mar 09, 2015 07:37 PM
Sold Crazy Price Drop!! HET Super Sniper with 70mm Mega/HET power system and servos. airmcn_3 Aircraft - Electric - Jets (FS/W) 9 Nov 14, 2011 11:37 AM
Found HET Sniper 90mm, airframe and maybe servos Knife Liddle Aircraft - Electric - Jets (FS/W) 2 Oct 01, 2011 11:10 AM
Sold NIB HET Super Sniper 90 V3 with HET 90mm fan and HET 600-37 motor mcgoughman Aircraft - Electric - Jets (FS/W) 0 Aug 30, 2011 08:35 PM
Sold HET All Composite Super Sniper priscalex Aircraft - Electric - Jets (FS/W) 0 Jun 30, 2008 09:17 PM
