Old Jun 01, 2012, 03:06 PM
AceMigKiller is offline
Find More Posts by AceMigKiller
Team EJF >>>WHOOSH>>>
AceMigKiller's Avatar
Joined Jul 2004
No prob!
Sometimes important stuff like that gets lost in useless thread chatter
Lemme know if you need any more tips or clarification.
Vic
AceMigKiller is offline Find More Posts by AceMigKiller
Old Jun 01, 2012, 03:54 PM
SCALEFAN is offline
Find More Posts by SCALEFAN
Done it all
United States, CA, Corona
Joined Feb 2006
Well, all was good and I was on the way to finishing this bird over the weekend, but then
I hooked up the servo, linkage, and all worked. Test fitted it, perfect, but then I noticed the elevator tips were not even, were they warped? Nope, one of the cloth hinges was not right. It showed too much and it had play.
Resolution, I cut the elevator off, used my fingernails to remove the tape and now I will make new slots and use pinned hinges.
PS: the 1/4 strip that runs inside the trailing edge of the stab is harder wood than balsa, hard to cut new hinge slots.
SCALEFAN is offline Find More Posts by SCALEFAN
Old Jun 01, 2012, 04:29 PM
jcdfrd is offline
Find More Posts by jcdfrd
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
it is becoming more apparent that the quality of wood in each kit/stab is all over the place.
after opening up Nicks stab and inspecting it, he had a pretty good one the spar and trailing blocks were all nice hard balsa pieces but in tams stab it is extremely soft balsa
jcdfrd is offline Find More Posts by jcdfrd
Old Jun 01, 2012, 05:30 PM
Joined Jul 2004
Use a Dremel. Makes quick work of cutting hinge slots.
Old Jun 01, 2012, 05:57 PM
Michael Paxton is offline
Find More Posts by Michael Paxton
Hey Ya'll!! Watch THIS!!
Michael Paxton's Avatar
Nashville TN.
Joined Mar 2006
Originally Posted by acemigkiller View Post
use a dremel. Makes quick work of cutting hinge slots.
+1
Michael Paxton is offline Find More Posts by Michael Paxton
Old Jun 01, 2012, 06:21 PM
SCALEFAN is offline
Done it all
Joined Feb 2006
Oh man, thanks. I never thought of that. So simple and easy.
Old Jun 02, 2012, 09:35 AM
SCALEFAN is offline
Done it all
Joined Feb 2006
All is well, new pin hinges installed, tape re-applied, it came out perfect. I filled in the excess hinge slots with Hysol, pressed it in with my fingers, then wiped the surface clean, so there is no bumps or restrictions to the elevator operation.
Thanks again for the simple solution to the problem. I am now excited about this project.
Al
Old Jun 02, 2012, 09:50 AM
Knife Liddle is offline
Find More Posts by Knife Liddle
Lee Liddle
Knife Liddle's Avatar
Carrollton, Tx
Joined Dec 2006
Which color do you have Al? My three Sniper 90`s all flew great, just needed reinforcement to go fast.
Knife Liddle is offline Find More Posts by Knife Liddle
Old Jun 02, 2012, 11:36 AM
SCALEFAN is offline
Done it all
Joined Feb 2006
White, Red, and Blue. I am slightly color blind, so the colors could be White, Orange and Purple. LOL
Old Jun 02, 2012, 01:20 PM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
So that`s the clasic Sniper scheme. Of those offered right now, I`d go with that one too, Good visability and good colors. I like the red and white High Viz too, but it`s not quite what I expected.
Good luck with yours.
Old Jun 02, 2012, 04:02 PM
Nashville TN.
Joined Mar 2006
Yea I'm with you. Not quite what I was hoping for. But should be easy to see.
Old Jun 02, 2012, 05:33 PM
SCALEFAN is offline
Done it all
Joined Feb 2006
I feel like I had to post these positive stuff about this plane.
I just cut out the servo covers and expected the wings to be the typical construction, cheap wood, covered by cheap shrink covering, boy was I surprised. The wings are composite and painted. I would love to know how they did it.
After inspecting the rest of the parts, not many, I find this plane to be one heck of a bargain. I really think that it is strong and could easily stand up to my abuse.The stab install was easy, so long as you know what has to be done. Just do it right the first time.
Thanks to the few guys that sacrificed their planes in the process of isolating some potential elevator issues, when flown at high speed. We are grand daughter sitting or I would finish it tonight and fly tomorrow. This is the first plane that I ever assembled and changed my mind from bad to good.
Maiden will have to be in two weeks, going to AZ next weekend.
Old Jun 02, 2012, 06:29 PM
CRCJA is offline
Find More Posts by CRCJA
wannabe Jet guy
CRCJA's Avatar
Green Valley, AZ
Joined Aug 2004
Az
Where in AZ? you bringing some planes to fly? I might have a Sniper to build by then.
Ralph
CRCJA is offline Find More Posts by CRCJA
Old Jun 02, 2012, 06:49 PM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
That`s all good and everything, but I have a question.
Who are you and what have you done with Al?
Old Jun 02, 2012, 07:05 PM
Madmax1965 is offline
Find More Posts by Madmax1965
Watt me worry?
Madmax1965's Avatar
Florida
Joined Mar 2006
Heh!...........^^^^^^^^^^^^^^^^^^^^^^^^^
Al-----ien abduction
Madmax1965 is offline Find More Posts by Madmax1965
Cool New HET L-39 90mm by EJF.com AceMigKiller Electric Ducted Fan Jet Talk 706 Mar 09, 2015 07:37 PM
Sold Crazy Price Drop!! HET Super Sniper with 70mm Mega/HET power system and servos. airmcn_3 Aircraft - Electric - Jets (FS/W) 9 Nov 14, 2011 11:37 AM
Found HET Sniper 90mm, airframe and maybe servos Knife Liddle Aircraft - Electric - Jets (FS/W) 2 Oct 01, 2011 11:10 AM
Sold NIB HET Super Sniper 90 V3 with HET 90mm fan and HET 600-37 motor mcgoughman Aircraft - Electric - Jets (FS/W) 0 Aug 30, 2011 08:35 PM
Sold HET All Composite Super Sniper priscalex Aircraft - Electric - Jets (FS/W) 0 Jun 30, 2008 09:17 PM
