Old May 28, 2012, 02:43 PM
jcdfrd is offline
Find More Posts by jcdfrd
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
well Nick followed the assembly instructions and had this thing assembled long before and elevator stab issued came to light and the only reason he had used nylon pinned hinges was because I told him to throw the ca hinges in the round file just because thats what I do with those. the problem is he had the stab and elev installed and epoxied on before I could have any input on servo installation. this is a hard lesson for Nick and I feel bad for not getting in front of it, I should have because I have built a Het F18 and it said the same thing, epoxy the elev servo's to the inside of the fuse and I would never do that and didn't on mine, I mean what do you do when your buddy says I think its ok that what the instructions said to do and so its glued in and clamped down and it seemed ok and now with hind sight its soo not ok. oh and by the way all the servo's in the wing are even weaker if you pot them like the instructions state as your bond is only as strong as the foam your gluing too and every one of the four servo's in the wing had separated in the crash at the foam to fiberglass skin........ just a little heads up for ya
if we were to do another one I would do them just like the Bu32, mounted to the hatches and hatches screwed down to hard points
John
jcdfrd is offline Find More Posts by jcdfrd
Old May 28, 2012, 02:58 PM
pdawg is offline
Find More Posts by pdawg
Need 4 Speed!
pdawg's Avatar
United States, OH, Dayton
Joined Apr 2004
Hey Cn.
Just curious, are you commenting as a consumer or as a EJf sponsored pilot?
pdawg is offline Find More Posts by pdawg
Old May 28, 2012, 02:59 PM
corsair nut is offline
Find More Posts by corsair nut
fly like an EAGLE ;)
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
well i never read the instructions lol. just built it the way i knew would work.
corsair nut is offline Find More Posts by corsair nut
Old May 28, 2012, 03:01 PM
tehachapi, CA
Joined Jan 2006
really bret? im commenting as somebody whos tired of people beating a dead horse. tam doesnt even own one and hes jumping all over ejf. they are working on it. but i think weve already proven if its built right...it works as is. optimal? by no means no. does it work? yes. it does.
Originally Posted by pdawg View Post
Hey CM.
Old May 28, 2012, 03:17 PM
jcdfrd is offline
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
Tam does have one I'm building it for him
Old May 28, 2012, 03:19 PM
Tamjets is offline
Find More Posts by Tamjets
Tamjets's Avatar
San Jose, CA
Joined Jun 2006
What are you talking about?
I got one of the kit had same issue with elevator
Now I know what to do...
Made the mod and fix the problem.
Tamjets is offline Find More Posts by Tamjets
Old May 28, 2012, 03:37 PM
Robert Wagoner is offline
Find More Posts by Robert Wagoner
Robert Wagoner's Avatar
Tucson, Arizona, USA
Joined Dec 1999
Not trying to be negative but didn't the same issue of a tail flutter come up several years ago with the original super sniper 90mm? Now with a "new" composite version with the same issue of flutter??? The single hingeline is a good idea for lower speed models but at a certain point you can't cut corners anymore. Instead of changing the stab design just make 2 hingelines (instead of 1) so the elevators taper towards the tips and use a servo for each surface. That would more than likely solve the problem.
Thanks for taking the time to comment and discuss. Yeah I saw the CN / EJF sponsored comment. Really this about making everyone happy and to clear up any future problems and concerns.
This stab design has carried on since the 70mm Sniper and it's seen 160+ during the speed craze days. (all wood) stab. The 90mm Sniper V1 had an (all wood) stab and worked fine. then the factory made a V2 composite version that the control surface layup was thought the problem and made the V3 that was stronger and has been that way.
The 90mm Sniper XL was done the same as V3 and the shape of all these has never changed. This elevator discussion is pointing out that the aerodynamics of the control surface shape is the culprit causing higher loads thus stressing the components. albeit beefing it up with hinges and servo mounting does show a fix and makes it flyable, the loading is higher than it should be and that can be fixed.
The center XL stab area has room for two servos and the shape can be changed along with adding two hinge line redundancy that also lowers the loading. I'm all for it to get this done once and for all.
Are we all on the same page?
Regards,
--RW
Robert Wagoner is offline Find More Posts by Robert Wagoner
Site Sponsor
Old May 28, 2012, 03:57 PM
vettster is offline
Find More Posts by vettster
"Take Off" eh!
vettster's Avatar
Canada, ON, Beeton
Joined Aug 2008
Originally Posted by SCALEFAN View Post
Well, as I assemble mine, I thought I would read the manual which is on a disk included with the kit. OMG guess what it said? Perhaps we all should read the manual more often.
HIGH PERFORMANCE TIP --- Testing of this airframe has demonstrated that the stock Cloth Hinges are sufficient for “Sport Flying” but suffer from fatigue when repeated fast passes and High-G manuevers are performed. If you intend to fly your Sniper XL90 aggressively, a stronger hinge-type (i.e. nylon pinned hinges) are strongly recommended
Im sorry... I just cant buy that. I have fiber hinges on my 25lb turbine that is moving well over 160mph in a dive, and with almost 200 flights they are still perfect. Blaming the hinge type is not valid. Not installing them into a block of wood is a serious problem.
vettster is offline Find More Posts by vettster
Old May 28, 2012, 03:58 PM
SCALEFAN is offline
Find More Posts by SCALEFAN
Done it all
United States, CA, Corona
Joined Feb 2006
CN,
What servo are you using on your elevator?
Al
SCALEFAN is offline Find More Posts by SCALEFAN
Old May 28, 2012, 04:02 PM
jcdfrd is offline
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
I dont think all CA hinges were created equal, are you using Het ca hinges?
Old May 28, 2012, 04:03 PM
vettster is offline
"Take Off" eh!
vettster's Avatar
Canada, ON, Beeton
Joined Aug 2008
Point taken
Old May 28, 2012, 04:12 PM
Kevin Greene is offline
Find More Posts by Kevin Greene
United States, TN, Jackson
Joined Mar 2007
Robert---The problem is with the outer part of the elevator being larger than the elevator is at the root...Seriously, I've seen this type of design flutter due to the way the air comes off of the tips of the stabs...If you do manage to get the stab in the wind tunnel---It doesn't matter that the tunnel won't blow fast enough to get the stab to flutter---With smoke you WILL see a couple VERY turbulent vortices coming from each tip..The votices will act upon the larger outer portion of the elevator, acting like a lever...Get them out of sinc with each other and you now have a twisting motion on the entire elevator...DEFINATELY---A straight across elevator will stop this...Testing will prove whether or not the reduced elevator area will need to be lengthened for adequate pitch control, especially during the landing flare...
When you get to the tunnel---I'm 99.9% positive you will see what I've described...Get a high speed camera to see the vortices..And make another stab of the same size but of weaker material to get the lower air flow tunnel to get enough airspeed to cause flutter/tip vortices..Again, I can just about guarantee what you will see...
Hoping to be helpful and not critical!!!
Kevin
Kevin Greene is offline Find More Posts by Kevin Greene
Old May 28, 2012, 04:18 PM
Joined Dec 1999
When you get to the tunnel---I'm 99.9% positive you will see what I've described...Get a high speed camera to see the vortices..And make another stab of the same size but of weaker material to get the lower air flow tunnel to get enough airspeed to cause flutter/tip vortices..IAgain, I can just about guarantee what you will see...
Kevin
Thanks for explaining.
--RW
Site Sponsor
Old May 28, 2012, 04:55 PM
pdawg is offline
Need 4 Speed!
pdawg's Avatar
Joined Apr 2004
CN,
My comment wasn't meant to be a passive aggressive attack. We've known each other for years and I know you will toss out the instructions and make things work simply based off previous experiences. So when your having success when others might be failing I believe its important to note that your coming from the perspective of a sponsored beta testor and not someone following the instruction manual.
Robert,
I believe we are are on the same page according to your description.
Old May 28, 2012, 05:45 PM
AIR SALLY is online now
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
Robert if you need help molding a new Stab let me know ,and i'll try and help.just build a balsa one flight test it and i could used the tested stab as a plug .i agree with kevin ,the load at the tips could cause a twisting ,the load may have broke Nicks servo loose too .Brent has VG's on the stab tips ...but Vic' did'nt so not sure if the vg's are helping ,but brents is flying well .it was the only plane up today ,and you could hear it well .i herd no flight control flutter.and it was moving out with 6000 8s set up .he used silicon to bond the elev to the fuse .
AIR SALLY is online now Find More Posts by AIR SALLY
Cool New HET L-39 90mm by EJF.com AceMigKiller Electric Ducted Fan Jet Talk 706 Mar 09, 2015 07:37 PM
Sold Crazy Price Drop!! HET Super Sniper with 70mm Mega/HET power system and servos. airmcn_3 Aircraft - Electric - Jets (FS/W) 9 Nov 14, 2011 11:37 AM
Found HET Sniper 90mm, airframe and maybe servos Knife Liddle Aircraft - Electric - Jets (FS/W) 2 Oct 01, 2011 11:10 AM
Sold NIB HET Super Sniper 90 V3 with HET 90mm fan and HET 600-37 motor mcgoughman Aircraft - Electric - Jets (FS/W) 0 Aug 30, 2011 08:35 PM
Sold HET All Composite Super Sniper priscalex Aircraft - Electric - Jets (FS/W) 0 Jun 30, 2008 09:17 PM
