Old May 27, 2012, 04:49 PM
AceMigKiller is online now
Find More Posts by AceMigKiller
Team EJF >>>WHOOSH>>>
AceMigKiller's Avatar
Joined Jul 2004
Originally Posted by jcdfrd View Post
no disrespect Vic just trying to help us get to a proper resolution and hopefully a low cost easy one
John
None taken.
Each one of your "theories" is correct via textbook.
We can go round and round and round... I'll I'm saying at the end of the day is that we're actively working solutions on several fronts.
Right here, right now, as long as your hinges are adhered properly and anchored into wood, you're going to be just fine. There is no aerodynamic flutter present up to and including 150mph. (We're working on a video to prove it.)
Looking ahead, there's talk of a Split-Elevator design and HET has been contacted about the immediate QA issue of assuring that the Trailing Edge of each Control Surface gets a solid, properly adhered anchor (wood).
Vic
AceMigKiller is online now Find More Posts by AceMigKiller
Old May 27, 2012, 04:58 PM
corsair nut is offline
Find More Posts by corsair nut
fly like an EAGLE ;)
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
mounting a keychain cam on the fuse looking at the stab and doing so high speed dives on film would put this to rest.
corsair nut is offline Find More Posts by corsair nut
Old May 27, 2012, 05:05 PM
Brickyard is offline
Find More Posts by Brickyard
Callsign blocked
Brickyard's Avatar
United States, NY, New York
Joined Dec 2008
Originally Posted by Kevin Greene View Post
Of all of those planes mentioned none have the elevators larger at the tips than at the root...They, for the most part, look like Extremes example..
Kevin
No, Extreme changed the entire shape of the stab utilizing L-39 type elevators (big root, small tip)... I'm saying to keep the stab/airfoil exactly the same, but make the elevators the same width throughout like every plane I mentioned.
Brickyard is offline Find More Posts by Brickyard
Old May 27, 2012, 05:07 PM
Robert Wagoner is offline
Find More Posts by Robert Wagoner
Robert Wagoner's Avatar
Tucson, Arizona, USA
Joined Dec 1999
I think that's what the guys will be doing ASAP and maybe they can mount a smoke streamer and get some views of the flow.
--RW
Robert Wagoner is offline Find More Posts by Robert Wagoner
Site Sponsor
Old May 27, 2012, 05:08 PM
Kevin Greene is offline
Find More Posts by Kevin Greene
United States, TN, Jackson
Joined Mar 2007
Gotcha---I was just looking at and making reference to the shape of the elevators themselves, not the entire stab...Again---Great to see Robert being an active participant.....
Kevin
Kevin Greene is offline Find More Posts by Kevin Greene
Old May 27, 2012, 05:17 PM
pdawg is online now
Find More Posts by pdawg
Need 4 Speed!
pdawg's Avatar
United States, OH, Dayton
Joined Apr 2004
Originally Posted by Robert Wagoner View Post
I'm going to arrange at the local UofA Aerospace lab for us to bring over a functional elevator assembly to be run in the wind tunnel. Then we can get this figured out once and for all on the existing details of dynamics and potential redesign of control surface design and shape.
--RW
Spent a lot of time in that wind tunnel! I don't believe this test is worth of the electricity cost of running that tunnel...its abundantly obvious that the construction shortcuts compromise the aerodynamics of this elevator leading to increased likelihood of flutter. No need to test it out in a wind tunnel.
pdawg is online now Find More Posts by pdawg
Latest blog entry: Visiting Edwards AFB
Old May 27, 2012, 05:20 PM
Joined Jul 2004
We're probably going Contour HD
Old May 27, 2012, 05:26 PM
Joined Dec 1999
I'm all ears. here is a stab we were going to take over. we pinned all the hinges and secured the servo tray in.
--RW
Site Sponsor
Old May 27, 2012, 09:39 PM
evo101 is offline
Find More Posts by evo101
evo101's Avatar
Australia, QLD, Brisbane
Joined Jun 2009
will the eflight Habu 32 15 - 25 retracts fit this baby using differant struts ?
evo101 is offline Find More Posts by evo101
Old May 27, 2012, 09:44 PM
tehachapi, CA
Joined Jan 2006
taped and glued servos are for foamies. i dont think flutter caused the servo to let go...it was simple force that broke the servo loose. het should have known better than to suggest simply taping and gluing the servo in.
Old May 27, 2012, 09:53 PM
jcdfrd is offline
Find More Posts by jcdfrd
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
they fit perfect, Tam is making struts for this just like the habu32, they will be more than adequate and lite
I had to mod the nosewheel mount to get the right height, I think tam posted some pics a few pages back of the mod and fit
jcdfrd is offline Find More Posts by jcdfrd
Old May 27, 2012, 09:57 PM
evo101 is offline
evo101's Avatar
Joined Jun 2009
great news as i have 3 sets of these lying around now
Old May 27, 2012, 10:16 PM
vettster is offline
Find More Posts by vettster
"Take Off" eh!
vettster's Avatar
Canada, ON, Beeton
Joined Aug 2008
--RW
I think the test should be done with the H stab attached to the plane as well as off the plane. The air coming off the wings and hitting the stab could have an overall effect that might not be noticed with the stab alone.
vettster is offline Find More Posts by vettster
Old May 27, 2012, 10:48 PM
Callsign blocked
Brickyard's Avatar
Joined Dec 2008
Why does the Bandit have anhedral on it horizontal stabs? Maybe to keep them out of the wings disrupted air. Not sure how big the wind tunnel is, but perhaps the entire assembled aircraft should be put in.
Old May 27, 2012, 11:05 PM
Knife Liddle is offline
Find More Posts by Knife Liddle
Lee Liddle
Knife Liddle's Avatar
Carrollton, Tx
Joined Dec 2006
Originally Posted by brickyard View Post
why does the bandit have anhedral on it horizontal stabs? Maybe to keep them out of the wings disrupted air. Not sure how big the wind tunnel is, but perhaps the entire assembled aircraft should be put in.
+ 1
Knife Liddle is offline Find More Posts by Knife Liddle
Cool New HET L-39 90mm by EJF.com AceMigKiller Electric Ducted Fan Jet Talk 706 Mar 09, 2015 08:37 PM
Sold Crazy Price Drop!! HET Super Sniper with 70mm Mega/HET power system and servos. airmcn_3 Aircraft - Electric - Jets (FS/W) 9 Nov 14, 2011 12:37 PM
Found HET Sniper 90mm, airframe and maybe servos Knife Liddle Aircraft - Electric - Jets (FS/W) 2 Oct 01, 2011 12:10 PM
Sold NIB HET Super Sniper 90 V3 with HET 90mm fan and HET 600-37 motor mcgoughman Aircraft - Electric - Jets (FS/W) 0 Aug 30, 2011 09:35 PM
Sold HET All Composite Super Sniper priscalex Aircraft - Electric - Jets (FS/W) 0 Jun 30, 2008 10:17 PM
