Old May 27, 2012, 01:55 AM
Michael Paxton is offline
Find More Posts by Michael Paxton
Hey Ya'll!! Watch THIS!!
Michael Paxton's Avatar
Nashville TN.
Joined Mar 2006
Originally Posted by Extreme_RC View Post
Artistic licence its just a guide, we could make it as big as is needed for sure.
Ah! Understood.
Michael Paxton is offline Find More Posts by Michael Paxton
Old May 27, 2012, 02:06 AM
Extreme_RC is offline
Find More Posts by Extreme_RC
Extreme CNC Alloy EDF
Extreme_RC's Avatar
Australia
Joined Mar 2006
Here, a cleaned up "van gough" version seeing as it just got lost on the last page.
Extreme_RC is offline Find More Posts by Extreme_RC
Old May 27, 2012, 02:08 AM
Nashville TN.
Joined Mar 2006
Wow. Hope it works. Cause it sure is ugly!!
Old May 27, 2012, 02:14 AM
Extreme_RC's Avatar
Australia
Joined Mar 2006
Personally I think the original sniper tail was an ugly pos, dunno why they stuck with the shape even in the first 90mm version. swept tail with even elevators would be nice, I am just trying to work with the original setup with servo in the centre.
Old May 27, 2012, 02:25 AM
Nashville TN.
Joined Mar 2006
I agree it's not pretty. But any way I change it only seems to make it worse.
Old May 27, 2012, 02:40 AM
Extreme_RC's Avatar
Australia
Joined Mar 2006
Could cut the stab tips right off, block them in, and then extend the elevators to each end, with their ends angled back in a little, that would make it look neater. This would also make it much easier to rework the stab and not upset its finish or look, no tips to deal with.
Old May 27, 2012, 02:56 AM
Knife Liddle is offline
Find More Posts by Knife Liddle
Lee Liddle
Knife Liddle's Avatar
Carrollton, Tx
Joined Dec 2006
Well there`s no way to keep the original stab, and keep the overall original shape, and have the elevators taper smaller from root to tip. Mods will have to be made to the stab to get it right.
Knife Liddle is offline Find More Posts by Knife Liddle
Old May 27, 2012, 02:59 AM
Extreme_RC's Avatar
Australia
Joined Mar 2006
The above pic only requires slicing the stab tips off, then filling the gap with wood, done neatly it would not even affect the paint finish. The elevator I was thinking about cutting it from one sheet of 3mm ply, then laminating it either side with balsa, tapering and shaping, wire rod to stiffen, and then cover in white film.
Old May 27, 2012, 03:10 AM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
Low freqency howl
This is Vics first XL demo video. Listen carefuly to the pass at 2:05, you can hear a low freq vibe that sounds like it is resonating through the fuselage causing what I would describe as a low howl. It`s my opinion that this is very likely the elevator trying to flutter. It`s being controled by a tight linkage, a good servo and properly installed ca hinges. Still, it sounds like the elevator is buzzing. You can hear it the best after the jet passes the camera.
If so, that would explain the eventual failure of the elevator hinges on this particular airframe. The sound is there on all of the fast passes, but is easiest to hear at 2:05 because the anouncer isn`t gabbing.
This is a lot of speculation, but given the rate of failure, it is very probable that Vic`s first XL was lost to the same basic problem.
Sometimes a camera mic can pick up things that you don`t hear when you are there in person.
Sniper XL90 HD.wmv (3 min 21 sec)
Old May 27, 2012, 03:22 AM
AIR SALLY is offline
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
Knife i believe that is the HET inlet duct noise ...herd that on some of there planes ...i think Brent F-20 has that howl too.
AIR SALLY is offline Find More Posts by AIR SALLY
Old May 27, 2012, 03:24 AM
michel49 is online now
Find More Posts by michel49
Joined Jul 2011
I made the same mod as Xtreme but with two servos in the centre of the stab; hope it will work...
michel49 is online now Find More Posts by michel49
Old May 27, 2012, 03:26 AM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
Yep it could be. I remember the L-39 had it bad.
Old May 27, 2012, 03:49 AM
Tamjets is offline
Find More Posts by Tamjets
Tamjets's Avatar
San Jose, CA
Joined Jun 2006
The elevator should be done as Mark, Brian, Lee and few other had suggested.
Even with one servo is not any issue. The dump elevator design to save cost from HET is constant flutter at the tip. Even how beefy you had that elevator rig up. At some point it will fail.
Did I repeat this again?
Vic,
You should listen and learn from expert that had much more experience and been this much longer and built over 100 of high performance jets.
I never wrong and know what goes to happen with this design and just most other had the experience like I do.
Tamjets is offline Find More Posts by Tamjets
Old May 27, 2012, 09:04 AM
Brickyard is online now
Find More Posts by Brickyard
Callsign blocked
Brickyard's Avatar
United States, NY, New York
Joined Dec 2008
I really don't like the look of this mod (Extreme_RC's).. I think it changes the outline too much. Lets be honest, it's a mini Bandit replica, & the swept design is all part of the look/success. I'll repost this drawing I did many pages back, & I remember seeing another like it. Het could make it longer at the root if desired, airfoil won't change.
1. maintains current look/profile
2. utilizes the existing stab/elevator
3. existing airfoil profile will remain 100% the same
4. flight characteristics unchanged
5. HET can utilize existing plugs/pieces to form the new one
6. easy to do at home if you don't feel like waiting on HET
7. Same BASIC design utilized by the (super successful) BVM Bandit.
"NOT TO SCALE"
Brickyard is online now Find More Posts by Brickyard
Old May 27, 2012, 11:05 AM
Nashville TN.
Joined Mar 2006
"NOT TO SCALE"
I like the look of this one the best. A bit more work than the others....But comes out looking like it is supposed to. Good job Brickyard!
Cool New HET L-39 90mm by EJF.com AceMigKiller Electric Ducted Fan Jet Talk 706 Mar 09, 2015 08:37 PM
Sold Crazy Price Drop!! HET Super Sniper with 70mm Mega/HET power system and servos. airmcn_3 Aircraft - Electric - Jets (FS/W) 9 Nov 14, 2011 12:37 PM
Found HET Sniper 90mm, airframe and maybe servos Knife Liddle Aircraft - Electric - Jets (FS/W) 2 Oct 01, 2011 12:10 PM
Sold NIB HET Super Sniper 90 V3 with HET 90mm fan and HET 600-37 motor mcgoughman Aircraft - Electric - Jets (FS/W) 0 Aug 30, 2011 09:35 PM
Sold HET All Composite Super Sniper priscalex Aircraft - Electric - Jets (FS/W) 0 Jun 30, 2008 10:17 PM
