Old Apr 11, 2012, 08:02 PM
Jetsom is offline
Find More Posts by Jetsom
Formerly "Heli Copter"
Jetsom's Avatar
United States, CA, Watsonville
Joined Apr 2009
Build Tip
I was having trouble cutting out the servo covers and getting a tight fit. I warmed them up to 140F and my xacto blade went through them like butter. Super clean and tight and no chipping. The plywood frames for the covers in the kit work great.
The stock air retracts bolt right in. I am loving this kit!
Jetsom is offline Find More Posts by Jetsom
Old Apr 11, 2012, 08:24 PM
AceMigKiller is offline
Find More Posts by AceMigKiller
Team EJF >>>WHOOSH>>>
AceMigKiller's Avatar
Joined Jul 2004
Thanks for sharing!
Just be sure not to keep them warm for too long; they are epoxy-glass and could warp if you inadvertently bend them while cutting... but yes, the plywood frames do help stiffen them back up!
Vic
AceMigKiller is offline Find More Posts by AceMigKiller
Old Apr 11, 2012, 09:35 PM
foss1997 is offline
Find More Posts by foss1997
toledo, oh, usa
Joined Nov 1999
Just got mine. Pretty much what I expected. Not bad for what you get, but not 10/10 quality either (top hinged ailerons, center hinged flaps???, flimsy rudder, inadequate rudder mount, nose gear hatch not precut and no spare once you dremel the one out, control horns dont reach to center of hinge line ect). HOWEVER, its a perfect size though, pretty light, and since it looks like a Bandit, should fly like a Bandit which is all I care about!
Im no fan of air retracts and started the night off looking at how some various makes I have laying around fit. The nose gear former needs a whack to get any electric retract in so far, but not bad. All it needs a mounting plate set to the correct depth and it should work ok. Shown are with some Shulman Etracts. Need some work, but I think theyll be ok.
Im going with a light, "low" power setup. JetFan 90, ARC motor, 6s 5000 65c TP's.
Scott
foss1997 is offline Find More Posts by foss1997
Old Apr 12, 2012, 04:13 AM
heliclown is offline
Find More Posts by heliclown
Australia, NSW, Hillsborough
Joined Feb 2008
extreme rc
Thanks Mark, for the info, appreciate it.
Steve
heliclown is offline Find More Posts by heliclown
Old Apr 14, 2012, 01:46 AM
alanjets is offline
Find More Posts by alanjets
alanjets's Avatar
Ripoff britain
Joined Jan 2011
Its all ready now except retracts just don't no witch ones to use the plane weight is 6.3lb without battery it has a cs12 fan with a het 1400Kv motor
alanjets is offline Find More Posts by alanjets
Old Apr 14, 2012, 04:01 AM
sykotic is offline
Find More Posts by sykotic
200mph +
sykotic's Avatar
New Zealand, Manawatu-Wanganui, Palmerston North
Joined Sep 2010
I'm just waiting for a new RX and a quick disconnect for the air line to the wings to arrive and mine is ready to go aswell.
Took it for a taxi in the driveway today
Will sort the main gear door after the madian.
sykotic is offline Find More Posts by sykotic
Old Apr 14, 2012, 07:21 AM
scatsob is offline
Find More Posts by scatsob
Bypass Ratio = Infinity
scatsob's Avatar
United States, NC, Jacksonville
Joined Apr 2006
Beautiful. What is the weight ready to fly?
scatsob is offline Find More Posts by scatsob
Old Apr 14, 2012, 11:22 AM
alanjets is offline
alanjets's Avatar
Ripoff britain
Joined Jan 2011
What retracts do u get carnt make my mind up
Old Apr 17, 2012, 09:39 AM
alanjets is offline
alanjets's Avatar
Ripoff britain
Joined Jan 2011
Do u think they will be a quick as this
Fast jet Turbine powered RC composite arf flash jet (6 min 33 sec)
Old Apr 17, 2012, 03:42 PM
sykotic is offline
200mph +
sykotic's Avatar
Joined Sep 2010
Missed that question some how...
I'll get it weighed asap and let you know.
I have a problem with one of the retracts in the wing.
It seems to be sticking, holding pressure some how. It will go up fine, but then when I release the pressure it sticks up, and I can't even pull it down. It's like it's locked up there. After 30seconds or so i guess the pressure drops enough for me to pull it down.
Any ideas? They are the spring down/air up HET retracts.
Old Apr 17, 2012, 04:48 PM
jcdfrd is offline
Find More Posts by jcdfrd
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
check for interference, loosen the screws that mount the retract and see if it starts working, nothing can be interference with the strut or wheel. also check to make sure the retract mount flanges sit level on the mount surface
jcdfrd is offline Find More Posts by jcdfrd
Old Apr 17, 2012, 06:08 PM
CRCJA is offline
Find More Posts by CRCJA
wannabe Jet guy
CRCJA's Avatar
Green Valley, AZ
Joined Aug 2004
squeeze?
To add to that suggestion, remove it from the wing without unplugging the air hose and test it, most times I had that problem, the side frames where squeezing the trunion, so I would say, check for that.
Ralph
CRCJA is offline Find More Posts by CRCJA
Old Apr 17, 2012, 06:19 PM
sykotic is offline
200mph +
sykotic's Avatar
Joined Sep 2010
Great, thanks guys.
I'll check that out tonight.
Old Apr 17, 2012, 10:51 PM
Jetsom is offline
Jetsom's Avatar
Joined Apr 2009
Oops!
Old Apr 17, 2012, 10:53 PM
Jetsom is offline
Jetsom's Avatar
Joined Apr 2009
I had the same problem and it turned out that the mount surface for the retract was uneven and tightening down the retract actually tweaked the retract frame enough to bind up. A big flat wheel on my dremel got the mounting surface nice and flat so I was able to tighten down the retract with no binding.
Cool New HET L-39 90mm by EJF.com AceMigKiller Electric Ducted Fan Jet Talk 706 Mar 09, 2015 07:37 PM
Sold Crazy Price Drop!! HET Super Sniper with 70mm Mega/HET power system and servos. airmcn_3 Aircraft - Electric - Jets (FS/W) 9 Nov 14, 2011 11:37 AM
Found HET Sniper 90mm, airframe and maybe servos Knife Liddle Aircraft - Electric - Jets (FS/W) 2 Oct 01, 2011 11:10 AM
Sold NIB HET Super Sniper 90 V3 with HET 90mm fan and HET 600-37 motor mcgoughman Aircraft - Electric - Jets (FS/W) 0 Aug 30, 2011 08:35 PM
Sold HET All Composite Super Sniper priscalex Aircraft - Electric - Jets (FS/W) 0 Jun 30, 2008 09:17 PM
