Old Apr 10, 2012, 08:12 AM
Downwardspiral is offline
Find More Posts by Downwardspiral
United States, MN, New Richland
Joined Jun 2010
Ok I have one of these otw and I figure I should ask for some expert advice as this is my first high power setup.
I plan to use;
Stock air retracts and struts
SM89 & HET 700-68-1125Kv
CC Ice2 120HV
700mah A123 reciever pack
First on EJF they recommend their HET-DS-002MG are these enough servo for a high power set up? Or I have have some HS-82MG that I had for another project would these work? Or should I get digitals like the HS-5085MG or the Hyperions listed earlier? Or?
Next from what I have read on 10s this setup should be pushing 4000w at around 108amps. Will the CC120HV be enough or should I go with a 160 for a little more headroom?
Lastly I have these battery setups available to play with any thoughts as to the best setup? It appears from earlier discussion that any of these combo's should fit.
8s-2x4S 5000 Nano Tech 45-90c=41.25oz
8S-2x4S 5800 Zippy 30c=40oz
10s-1x4S+1x6S 5000 Nano Tech 45-90c=49.3oz
10s-1x4S+1x6S 5800 Zippy 30c=49.5oz
Thanks in advance,
Casey
Downwardspiral is offline Find More Posts by Downwardspiral
Old Apr 10, 2012, 10:31 AM
BILLYDSRC is offline
Find More Posts by BILLYDSRC
BILLYDSRC's Avatar
OHIO
Joined Aug 2009
Hi, I can help with the SM89-45 setup If you use the ICE120 it works great with a 10s setup but you have to get air over the ESC. I put it into the inlet or the trust tube. Before i did that my ESC would get up to 170 degrees moved it and Never got over 110 P.S. Try to stay away from the ICE160 for now!!
I plan to use;
CC Ice2 120HV
Thanks in advance,
Casey
BILLYDSRC is offline Find More Posts by BILLYDSRC
Old Apr 10, 2012, 10:47 AM
alanjets is offline
Find More Posts by alanjets
alanjets's Avatar
Ripoff britain
Joined Jan 2011
That picture of the het retracts with the air piston going the other way are they for the sniper or something else as i want to order some but i dont want the piston that way round
alanjets is offline Find More Posts by alanjets
Old Apr 10, 2012, 12:36 PM
alanjets is offline
alanjets's Avatar
Ripoff britain
Joined Jan 2011
I no witch one I would rather have the sniper anyday but the habu fly's nice but deals alittle heavy
Old Apr 10, 2012, 02:44 PM
AceMigKiller is offline
Find More Posts by AceMigKiller
Team EJF >>>WHOOSH>>>
AceMigKiller's Avatar
Joined Jul 2004
Those were for the HET L-39.
The Sniper's retract set is conventional.
Vic
AceMigKiller is offline Find More Posts by AceMigKiller
Old Apr 11, 2012, 12:55 AM
capt soap is offline
Find More Posts by capt soap
capt soap's Avatar
dallas tx
Joined Jun 2003
Why stay away from the ice 160 for now??? I have a new one.
capt soap is offline Find More Posts by capt soap
Old Apr 11, 2012, 01:24 AM
BILLYDSRC's Avatar
OHIO
Joined Aug 2009
All i will say is i support CC 100% on all there ESC but for now the 160 ver 1,2,3,4,5,6,7 what everyone you have just be really careful.
Old Apr 11, 2012, 01:28 AM
BILLYDSRC's Avatar
OHIO
Joined Aug 2009
Ok back to the Sniper XL.. I real think the JTM retracts and struts will fit into the jet! If so i have a bunch in-stock that i will be giving a killer combo price on them
But i have to see if there going to fit 100%
Old Apr 11, 2012, 04:13 AM
Extreme_RC is offline
Find More Posts by Extreme_RC
Extreme CNC Alloy EDF
Extreme_RC's Avatar
Australia
Joined Mar 2006
The JTM struts are large and heavy, Dunno if they will even fit in the wells. Will try and have a look tonight as I need to measure the wheel wells anyway.
Extreme_RC is offline Find More Posts by Extreme_RC
Old Apr 11, 2012, 12:07 PM
alanjets is offline
alanjets's Avatar
Ripoff britain
Joined Jan 2011
I have the old crapy jtm retracts and they are just a little too deep to fit in has any one got stock of the het sniper retracts
Old Apr 11, 2012, 12:12 PM
Joined Jul 2004
Yeah... the retract bays are a little slim. Nothing taller than about 24mm will fit.
We are actively working on an all-electric solution guys... unfortunately, that's about all I can say for now. Sorry!
Vic
Old Apr 11, 2012, 12:52 PM
jcdfrd is offline
Find More Posts by jcdfrd
3DHOG
jcdfrd's Avatar
USA, CA, Aromas
Joined Sep 2010
I believe Tamjets aready has an all-electric retract and strut solution
jcdfrd is offline Find More Posts by jcdfrd
Old Apr 11, 2012, 12:59 PM
Joined Jul 2004
Yep. We'll have one too.
Vic
Old Apr 11, 2012, 01:12 PM
BILLYDSRC's Avatar
OHIO
Joined Aug 2009
The Tam struts were made for the JTM Hawk ans L-39. So if they fit so should the JTM struts. But it looks like the ver.2 JTM retracts are a bit big for it.
Old Apr 11, 2012, 06:04 PM
Extreme_RC's Avatar
Australia
Joined Mar 2006
Nope the JTM kits have big open wheel bays, the Sniper is molded glass bays and the JTM struts snag in a couple of spots. They are also heavier than the HET struts and use 4mm pins so cannot be used with the HET retracts.
@ HeliClown:
The HET struts have 2 inch wheels on them, but the wheel wells will take 2.25" wheels, I will swap mine out to this size for the mains and see if I can run one of the 2" on the front leg.
My Sniper is still largely in the box I have a Komet to finish for a customer, the vampire to do, then the Sniper. Just too many things on, need to do some painting round the house too LOL.
Cool New HET L-39 90mm by EJF.com AceMigKiller Electric Ducted Fan Jet Talk 706 Mar 09, 2015 07:37 PM
Sold Crazy Price Drop!! HET Super Sniper with 70mm Mega/HET power system and servos. airmcn_3 Aircraft - Electric - Jets (FS/W) 9 Nov 14, 2011 11:37 AM
Found HET Sniper 90mm, airframe and maybe servos Knife Liddle Aircraft - Electric - Jets (FS/W) 2 Oct 01, 2011 11:10 AM
Sold NIB HET Super Sniper 90 V3 with HET 90mm fan and HET 600-37 motor mcgoughman Aircraft - Electric - Jets (FS/W) 0 Aug 30, 2011 08:35 PM
Sold HET All Composite Super Sniper priscalex Aircraft - Electric - Jets (FS/W) 0 Jun 30, 2008 09:17 PM
