Old Mar 29, 2012, 08:24 PM
AceMigKiller is online now
Find More Posts by AceMigKiller
Team EJF >>>WHOOSH>>>
AceMigKiller's Avatar
Joined Jul 2004
Originally Posted by gbmoore View Post
NICE!
Greg
Thanks!
AceMigKiller is online now Find More Posts by AceMigKiller
Old Mar 29, 2012, 08:30 PM
sykotic is offline
Find More Posts by sykotic
200mph +
sykotic's Avatar
New Zealand, Manawatu-Wanganui, Palmerston North
Joined Sep 2010
Awesome stuff!
Looking forward to getting started on mine.
Do you think the magnet idea on the front gear door (tiny mag with a washer on the door) would cause the problem with the stock HET air struts? I'm assuming they are strong enough to push open a tiny bit of resistance like that?
sykotic is offline Find More Posts by sykotic
Old Mar 29, 2012, 08:37 PM
Joined Jul 2004
Yes.
I specifically did not use the Air on the nose because it *might* have enough power to actuate the door, but it probably wouldn't lock into place 100% of the time.
If you're going to do this gear door mod, I highly suggest a big Electric Retract like the E-Flite 60-120. The upside to the E-Flite retract is that the stock Trailing Link Suspension strut plugs right into the Nose Retract
Vic
Old Mar 29, 2012, 11:41 PM
Tamjets is offline
Find More Posts by Tamjets
Tamjets's Avatar
San Jose, CA
Joined Jun 2006
Originally Posted by AceMigKiller View Post
Yes.
Vic
60-120 E-flite retract are using same motor as 25-46 size.
If you do that. Do it with 25-46 size. At least I had upgrade trunion for replace if stock one broke.
Tamjets is offline Find More Posts by Tamjets
Old Mar 30, 2012, 12:18 AM
Joined Jul 2004
Pick your poison, as long as they can take the Strut.
25-46 Strut is too small to fit the Stock Super Sniper Sniper Strut.
Besides, the trunions hold up just fine if you run them within they're rated range.
My HET L-39 (~10lbs.) flew countless flights off dirt and pavement with no trunion trouble
Old Mar 30, 2012, 01:04 AM
Tamjets is offline
Tamjets's Avatar
San Jose, CA
Joined Jun 2006
You mean the pin for steering to small?
I had both gear in my hand and I don't see any problem with clearence with the struts.
Beside 25-46 is 4mm pin and 60-120 are 5mm pin.
The problem with nose trunion is too thin with the material.
I can stress them apart just by pulling on the struts. If you land nose first. Say good by to the trunion.
Even 8 lbs aircraft.
Old Mar 30, 2012, 12:16 PM
Joined Jul 2004
I was talking about the pin going into the trunion (4mm vs. 5mm).
Yes Tam, everybody who buys your stuff will have a good plug'n play system.
Everybody else who buys other stuff need not worry, it works well too
Free day today!!!
I'm going flying.
Vic
Old Mar 30, 2012, 11:20 PM
sykotic is offline
200mph +
sykotic's Avatar
Joined Sep 2010
Help please...
I've either gone stupid (more than before!) or something isn't right....
The pics below are the 3 struts I have for my sniper... Its the factory set and they came in a bag with "sniper XL" written on them in black vivid.
How are they meant to fit??? All 3 appear to be exactly the same except the air outlet which is swapped on one. But they seem to rotate/swing the wrong way to fit into the wing cutouts.
Old Mar 30, 2012, 11:52 PM
Extreme_RC is offline
Find More Posts by Extreme_RC
Extreme CNC Alloy EDF
Extreme_RC's Avatar
Australia
Joined Mar 2006
Those are not HET retracts, they are something else. HET ones are conventional, leg folds down onto piston, also just been looking at the HET ones and a bit worried at the lack of support in the mechanism around the piston end, there is no shaft or bolt system holding that end together...
Extreme_RC is offline Find More Posts by Extreme_RC
Old Mar 30, 2012, 11:53 PM
sykotic is offline
200mph +
sykotic's Avatar
Joined Sep 2010
Err... They came direct from HET 2 days ago in the same box as the sniper?
I hope they are HET!
Old Mar 30, 2012, 11:56 PM
sykotic is offline
200mph +
sykotic's Avatar
Joined Sep 2010
looking here: http://static.rcgroups.net/forums/at...7-IMG_0349.jpg
Those were linked on the first pages... And is EXACTLY the same as what i have. The HET page has then here: http://www.highendrc.com/index_eprod...roducts_id=270
But they are different that what Vic has in here: http://static.rcgroups.net/forums/at...2-DSCN5170.jpg Although I thought I read that they do use the same as the L39?
These ones look like what Vic has (based on the colours of the cylinder) but it has one air tank and mine has two? http://www.highendrc.com/index_eprod...roducts_id=233
Old Mar 31, 2012, 12:12 AM
Extreme_RC's Avatar
Australia
Joined Mar 2006
Here is the one I am playing with on my desk, with the leg that came in the sniper box. Air up spring down, not sure what those other ones are for...
Old Mar 31, 2012, 12:15 AM
sykotic is offline
200mph +
sykotic's Avatar
Joined Sep 2010
Do you have a L39 set? I think that's what I have.
The set I have is this (exactly the same, same parts, two cylinders etc):
http://www.highendrc.com/index_eprod...roducts_id=270 I believe. My package of struts was labelled sniper xl, so I assume they screwed up.
I'll have to send them an email
Old Mar 31, 2012, 12:20 AM
Robert Wagoner is offline
Find More Posts by Robert Wagoner
Robert Wagoner's Avatar
Tucson, Arizona, USA
Joined Dec 1999
Originally Posted by sykotic View Post
Help please...
Oh drats! wrong set... email me robert@ejf.com and we will get you fixed up.
--RW
Robert Wagoner is offline Find More Posts by Robert Wagoner
Site Sponsor
Old Mar 31, 2012, 12:23 AM
sykotic is offline
200mph +
sykotic's Avatar
Joined Sep 2010
--RW
Thanks... But I didn't buy it from you (wishing I had now of course..)
Shipping from the USA to me is crazy expensive normally so I didn't even think of getting a quote from you guys.
Cool New HET L-39 90mm by EJF.com AceMigKiller Electric Ducted Fan Jet Talk 706 Mar 09, 2015 07:37 PM
Sold Crazy Price Drop!! HET Super Sniper with 70mm Mega/HET power system and servos. airmcn_3 Aircraft - Electric - Jets (FS/W) 9 Nov 14, 2011 11:37 AM
Found HET Sniper 90mm, airframe and maybe servos Knife Liddle Aircraft - Electric - Jets (FS/W) 2 Oct 01, 2011 11:10 AM
Sold NIB HET Super Sniper 90 V3 with HET 90mm fan and HET 600-37 motor mcgoughman Aircraft - Electric - Jets (FS/W) 0 Aug 30, 2011 08:35 PM
Sold HET All Composite Super Sniper priscalex Aircraft - Electric - Jets (FS/W) 0 Jun 30, 2008 09:17 PM
