Old Mar 06, 2012, 04:31 PM
AceMigKiller is online now
Find More Posts by AceMigKiller
Team EJF >>>WHOOSH>>>
AceMigKiller's Avatar
Joined Jul 2004
Originally Posted by Brickyard View Post
Do you think the HS82's will work? Do u think the extra 20% is needed on all those flying surfaces? I'll probably try the Ds's anyway though, just curious
Both Hyperion and Hitech make excellent servos!
The difference between the 82/85 and the DS13 is almost to the point of splitting hairs... in my humble opinion, here's why I trust Hyperions over the 82/85's:
--- Performance is at least on par (if not exceeding) the comparable Hitech.
--- Cost is not much more, and they are true digital servos.
--- Centering is unrivaled, as is dynamic and holding torque.
--- They're completely programmable for direction, speed, neutral point, deadband, etc. either on your PC or E-Meter
I must say that I have a tendency to go overkill rather than wish I had an extra 20% on my control surfaces... they're kind of critical ya know...
Vic
AceMigKiller is online now Find More Posts by AceMigKiller
Old Mar 06, 2012, 04:47 PM
mce73 is offline
Find More Posts by mce73
Sweden, Stockholm County, Stockholm
Joined Jun 2005
You can also try the fully digital and programmable Hitec HS-5085MG.
60oz/in. holding power.
http://www.hitecrcd.com/products/dig...hs-5085mg.html
I am using them on my Jet Teng Viper that is on the build table right now.
mce73 is offline Find More Posts by mce73
Old Mar 06, 2012, 04:52 PM
Joined Jul 2004
Yes, that is more of a direct comparison to the DS13 than the HS82/85 series... however they also go for $41.99 here in the US.
At that rate, the Hyperions are a tried and true overkill solution for less.
Old Mar 06, 2012, 04:54 PM
Brickyard is online now
Find More Posts by Brickyard
Callsign blocked
Brickyard's Avatar
United States, NY, New York
Joined Dec 2008
Thanks Tumbler.. Hey have you tried Hyperion servos? The specs are amazing. It's smaller/lighter/stronger!
I have a general question also. Comming from a 40%, & turbine background, I am programmed to use best quality, heavy servo extensions, but on my 1st/last electric venture (Sapac L39), After finishing it, I realized how much weight I could have saved by going with lighter gauge wire & making my own exact length extensions.. Any thoughts?.. What do you electric guys do?
Brickyard is online now Find More Posts by Brickyard
Old Mar 06, 2012, 05:17 PM
Callsign blocked
Brickyard's Avatar
Joined Dec 2008
Thanks guys, missed the other servo comments.. I'm thinking Hyperion for me.. Had the 5085's, they are great
Old Mar 06, 2012, 09:47 PM
Joined Jul 2004
Center Sections Glassed!
Worked up the Center Sections today!
Although not *necessary*, I applied a layer of 2.5" fiberglass cloth to the Top/Bottom of our Wings... we don't plan on being too nice with our Snipers...
Taking your time is the key here; use good quality everything --- Glass, Epoxy, Sharp Scissors, etc. Just finished blending them after letting the epoxy fully cure. The result is a very-near seamless glass job and a super-strong Center Section! These are going to look way awesome after paint!
Vic
Old Mar 06, 2012, 09:57 PM
Tumbler is offline
Find More Posts by Tumbler
Tumbler's Avatar
New Jersey
Joined Feb 2003
I have not used them yet. I came from 33 and 35% 3d stuff and have had a turbine and now fly mostly 100mm+ EDF's stuff now. I now find there is really no need for going overkill like I did with 3D. The surfaces on these jets are a fraction of the size and move a fraction of the distance. Here is my 52" EDF doing 170+ weighing in at a porky14lbs with nothing but Futaba s 3102 mini servos....all analog...no digitals. Just shows you don't need the best of the best to fly well. Linkage geometry is what matters most.
101 0486 (5 min 10 sec)
Tumbler is offline Find More Posts by Tumbler
Old Mar 06, 2012, 10:00 PM
corsair nut is online now
Find More Posts by corsair nut
fly like an EAGLE ;)
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
cool mod on the wing tape. ill be doing the same...
corsair nut is online now Find More Posts by corsair nut
Old Mar 06, 2012, 10:02 PM
Joined Jul 2004
Not only does it provide some extra beef, but it'll help asthetically too... one piece wing!!!
Old Mar 06, 2012, 10:55 PM
Callsign blocked
Brickyard's Avatar
Joined Dec 2008
http://www.youtube.com/watch?v=GEok7hq4g1w
Ok cool, I seen you fly that at the "BigApple Ralley" (I was announcing it), Nice video!.. You can almost see the inertia behind that thing as it goes vertical. I pulled the trigger with this new Het. I'm expecting it to be a real WINNER
Old Mar 07, 2012, 06:32 PM
Extreme_RC is offline
Find More Posts by Extreme_RC
Extreme CNC Alloy EDF
Extreme_RC's Avatar
Australia
Joined Mar 2006
The Hyperion ATLAS are really nice servos, I use them in a lot of the bigger jets, but I did have an issue with the pair of DS13 TMB's on the flaps of my JTM Hawk, the gear trains went all sloppy and had about 5mm play at the flap, dunno why as all the others I have used were ok and have not had one back from a customer yet.
Extreme_RC is offline Find More Posts by Extreme_RC
Old Mar 07, 2012, 07:40 PM
Tumbler is offline
Tumbler's Avatar
New Jersey
Joined Feb 2003
LOL Great I was just about to order them for ailerons to replace JR 168's that have developed slop in the gear train.
Old Mar 07, 2012, 08:13 PM
Extreme_RC's Avatar
Australia
Joined Mar 2006
I cant explain it, I got gearsets ready to put in but they are glued into the frames, not easy to remove. The aileron ones are fine, there is a tiny bit a lash in all these MG servos, and I did notice when they changed box style the later productions were tighter again, might have been an issue with the early versions.
Old Mar 07, 2012, 08:21 PM
Tumbler is offline
Tumbler's Avatar
New Jersey
Joined Feb 2003
Yeah seems like a lot of MG servos are like that. Just a little play develops and then it translates into huge play at the surface. A lot of times with flaps I can deal with it because you can position the arm so that it is inline with the linkage in the neutral position. For everything else they become useless.
Old Mar 07, 2012, 10:16 PM
Robert Wagoner is offline
Find More Posts by Robert Wagoner
Robert Wagoner's Avatar
Tucson, Arizona, USA
Joined Dec 1999
Enough space for a gas burner.
To help answer the questions coming in on the space for the small Turbines, here is a few pictures.
--RW
Robert Wagoner is offline Find More Posts by Robert Wagoner
Site Sponsor
Cool New HET L-39 90mm by EJF.com AceMigKiller Electric Ducted Fan Jet Talk 706 Mar 09, 2015 08:37 PM
Sold Crazy Price Drop!! HET Super Sniper with 70mm Mega/HET power system and servos. airmcn_3 Aircraft - Electric - Jets (FS/W) 9 Nov 14, 2011 12:37 PM
Found HET Sniper 90mm, airframe and maybe servos Knife Liddle Aircraft - Electric - Jets (FS/W) 2 Oct 01, 2011 12:10 PM
Sold NIB HET Super Sniper 90 V3 with HET 90mm fan and HET 600-37 motor mcgoughman Aircraft - Electric - Jets (FS/W) 0 Aug 30, 2011 09:35 PM
Sold HET All Composite Super Sniper priscalex Aircraft - Electric - Jets (FS/W) 0 Jun 30, 2008 10:17 PM
