Old Mar 03, 2012, 02:34 PM
Tumbler is offline
Find More Posts by Tumbler
Tumbler's Avatar
United States, NJ, Vineland
Joined Feb 2003
Thanks Vic!!
Originally Posted by AceMigKiller View Post
Nice work on the Blaze, BTW. Been keeping an eye on that one too!
Vic
Tumbler is offline Find More Posts by Tumbler
Old Mar 03, 2012, 10:33 PM
Hossinarizona is offline
Find More Posts by Hossinarizona
More Speed Indeed!
Hossinarizona's Avatar
USA, AZ, Tucson
Joined Nov 2007
I feel ya!
I'm using DS13-TMB's (same size as Hitech 82MG's), so I have to offset them from the stock servo bay just a few mm's. If you use a thinner Wing Servo, there would be plenty of room to drop a plywood floor and bolt them straight down, or even onto the servo cover (I do that on alot of big warbirds).
Vic
Hey Vic,
Are you using the DS13-TMB's for the ailerons, flaps and elevator, I just got back from a sneak peak at Roberts and I am pumped
Hossinarizona is offline Find More Posts by Hossinarizona
Old Mar 04, 2012, 12:30 PM
AceMigKiller is offline
Find More Posts by AceMigKiller
Team EJF >>>WHOOSH>>>
AceMigKiller's Avatar
Joined Jul 2004
DS13's for Ailerons/Flaps/Rudder/Steering.
I use a DS16FMD for Elevator.
Vic
AceMigKiller is offline Find More Posts by AceMigKiller
Old Mar 06, 2012, 12:07 AM
stevenfox905 is offline
Find More Posts by stevenfox905
Joined Jun 2010
Ok, so the servos are in, air lines ran, and the wing is joined. Already have the fuse sanded and smoothed out. She should be ready for paint in the next few days. Really taking the extra time on this bird to ensure a bullet proof build and a beautiful finish.
So it looks like were going to try something kind of different on this build, HET Air Mains and and Eflite 60-120 electric nose gear with gear doors.
Time to set up the paint booth! Enjoy
Description: Center section sanded for glassing Name: 20120303_163023.jpg
Description: Both wing halves ready to be joined Name: 20120304_144639.jpg
Description: Notched wing to clear aileron and flap servo leads
Air lines routed for HET air mains
Description: All this work is gonna pay off! Name: 20120304_144758.jpg
Description: Wing halves line up very well Name: 20120304_145143.jpg
Description: Masked off the servo leads and airlines, cleaned and prepped for epoxy
Description: Spar epoxied into one wing half
This 26 inch spar is huge! Name: 20120304_160634.jpg
Description: Come on, dry already! Name: 20120304_160747.jpg
Description: All thats left is to glass over the center section and were ready for primer
stevenfox905 is offline Find More Posts by stevenfox905
Old Mar 06, 2012, 07:24 AM
Brickyard is offline
Find More Posts by Brickyard
Callsign blocked
Brickyard's Avatar
United States, NY, New York
Joined Dec 2008
Looking good, thanks for the update!!!
Brickyard is offline Find More Posts by Brickyard
Old Mar 06, 2012, 08:29 AM
corsair nut is online now
Find More Posts by corsair nut
fly like an EAGLE ;)
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
sweet man.
vic....when do they start shippin! LOL
corsair nut is online now Find More Posts by corsair nut
Old Mar 06, 2012, 11:17 AM
Callsign blocked
Brickyard's Avatar
Joined Dec 2008
Are Hyperion servos more expensive that Hitec? Looks like DS13,s are a few bucks more than HS82mg's. Unless I'm looking in the wrong place
Old Mar 06, 2012, 11:29 AM
Joined Jun 2010
Yes, the tmb's are a few bucks more. They are a touch slower than the hitecs but have 20 percent more torque.. Always had great luck with my hyp servos..
Old Mar 06, 2012, 11:38 AM
Callsign blocked
Brickyard's Avatar
Joined Dec 2008
I've never heard of them before this thread.. But you guys seem to be having good experiences.. & stronger in the same case size seems great, Hmmm, maybe I'll try them.
Joined Jul 2004
Keep in mind the only thing comparable between an HS82MG and a DS13TMB are size.
On 6v, the HS82 has 47.22oz/in. holding power --- ($21.99)
On 6v, the DS13TMB has 117.6oz/in. holding power --- ($34.95)
When I'm flying something this big and fast, I don't mind spending a few extra dollars... especially considering the DS13's are two and a half times the holding power.
Vic
Old Mar 06, 2012, 12:00 PM
Tumbler is offline
Tumbler's Avatar
Joined Feb 2003
You sure about theose torque numbers? This is on rcdude.com's site for the 13TMB
Specifications:
Weight: 19.2
Dim (mm): 29.5 x 13 x 27.6
Speed sec/60 4.8/6.0v: 0.20/0.16
Gear Train Primary Material: Metal
Bearing: Top Ball
Torque oz/in 4.8/6.0v: 50.4/58.8
Vic
Old Mar 06, 2012, 12:17 PM
Joined Jun 2010
Tmb's are 58 oz in.. Thats where I got 20 percent..
Old Mar 06, 2012, 12:35 PM
Joined Jul 2004
Nah you're right... got my conversion factors mixed up.
That's what I get for being up at 3am and getting to bed at midnight last night!
Old Mar 06, 2012, 01:42 PM
Callsign blocked
Brickyard's Avatar
Joined Dec 2008
Do you think the HS82's will work? Do u think the extra 20% is needed on all those flying surfaces? I'll probably try the Ds's anyway though, just curious
Old Mar 06, 2012, 01:47 PM
Tumbler is offline
Tumbler's Avatar
Joined Feb 2003
I have been researching servos of this size and for what its worth i have found the HS 85MG to be the servos of choice for a lot of people if you are trying to save a little money but still get a quality servo. only saves about $5/servo over the 13 TMB though.
Cool New HET L-39 90mm by EJF.com AceMigKiller Electric Ducted Fan Jet Talk 706 Mar 09, 2015 07:37 PM
Sold Crazy Price Drop!! HET Super Sniper with 70mm Mega/HET power system and servos. airmcn_3 Aircraft - Electric - Jets (FS/W) 9 Nov 14, 2011 11:37 AM
Found HET Sniper 90mm, airframe and maybe servos Knife Liddle Aircraft - Electric - Jets (FS/W) 2 Oct 01, 2011 11:10 AM
Sold NIB HET Super Sniper 90 V3 with HET 90mm fan and HET 600-37 motor mcgoughman Aircraft - Electric - Jets (FS/W) 0 Aug 30, 2011 08:35 PM
Sold HET All Composite Super Sniper priscalex Aircraft - Electric - Jets (FS/W) 0 Jun 30, 2008 09:17 PM
