so I imagine it would work well.If you get around 3 - 3.5kw out of that setup you'll get similar performance to what you see in the videos ![]() Vic |
Other than the retract valve/servo and rx, what else could you move back? Looks like the Hyperion 5000's are about 12-13ozs heavier than the 4200's, That't a lot of weight that far ahead of the CG. I am just curious since I have run into the same issue even moving everything to the back. 10s 5000 or 12s 4000 is easy, but gets tricky with 12s 5000.
Looking at the Prototype, I could move the Retract Valve/Servo, RX, ESC, RX pack, not to mention slide the 5000's as aft as possible.
You're absolutely right though; 5000's do fit and will work great on lower cell counts, but I'm positive the sweet spot for 12s is going to be 4200's. Should get me 4 minutes of aggressive flying (the way I fly 90% of the time) or more with less time in "burner". Vic |
Here's our HET L-39 with a HET 700-83-1080 on 12s 5000's. The packs came down with 30% remaining, so 4200's would probably be fine.
| Thread Tools | |
| Cool New HET L-39 90mm by EJF.com | AceMigKiller | Electric Ducted Fan Jet Talk | 680 | Aug 28, 2012 11:02 AM |
| Sold Crazy Price Drop!! HET Super Sniper with 70mm Mega/HET power system and servos. | airmcn_3 | Aircraft - Electric - Jets (FS/W) | 9 | Nov 14, 2011 11:37 AM |
| Found HET Sniper 90mm, airframe and maybe servos | Knife Liddle | Aircraft - Electric - Jets (FS/W) | 2 | Oct 01, 2011 11:10 AM |
| Sold NIB HET Super Sniper 90 V3 with HET 90mm fan and HET 600-37 motor | mcgoughman | Aircraft - Electric - Jets (FS/W) | 0 | Aug 30, 2011 08:35 PM |
| Sold HET All Composite Super Sniper | priscalex | Aircraft - Electric - Jets (FS/W) | 0 | Jun 30, 2008 09:17 PM |
