Old Nov 10, 2011, 11:08 AM
Tumbler is offline
Find More Posts by Tumbler
Tumbler's Avatar
United States, NJ, Vineland
Joined Feb 2003
I am sure the biggest questions people have are how much will it cost and when will it be available? I am just hoping they put the mains farther apart than the Sniper 90. On a grass runway, the narrow gear made it very hard to keep straight.
Originally Posted by AceMigKiller View Post
Well now that the secret's out...
A.) Yes, the intakes are a little large for a 90mm, but I'm still aiming realistically for about 150+mph on the stock HET 9305V2 fan and Typhoon 700 series motors.
B.) Yes it is sweet! Sorry for keeping it on the DL... but sometimes we have to wait for the *OK* from the factory before letting these puppies off the chain!
Sniper is complete, just waiting for a good day to maiden. Then I'll start posting a build thread here! Any more questions, please feel free to ask!
Vic
Tumbler is offline Find More Posts by Tumbler
Old Nov 10, 2011, 11:20 AM
Knife Liddle is online now
Find More Posts by Knife Liddle
Lee Liddle
Knife Liddle's Avatar
Carrollton, Tx
Joined Dec 2006
Also, the mains on theSniper 90 are too far forward. It`s hard to keep the nose wheel down on the takeoff roll. And if you move the cg forward, then it`s noseheavy. That`s a pretty simple thing to get right. Figure out where it needs to ballance, then put the mains an inch or so behind that point.
That may have been some of your tracking issues too Brian. I couldn`t keep mine straight on a smooth runway.
Knife Liddle is online now Find More Posts by Knife Liddle
Old Nov 10, 2011, 02:16 PM
egall232 is offline
Find More Posts by egall232
England/uk
Joined Oct 2007
W sniper ???
Well,
I hope its better thought out than the last Sniper 90 mm and stays together ?? we have been missing a decent reasonably priced 90 mm sports jet .
Can i ask compared to the old one is it bigger ?? more space for batts and made out of epoxy not crappy polyester ,
cheers Euan.
egall232 is offline Find More Posts by egall232
Old Nov 10, 2011, 02:29 PM
Tumbler is offline
Tumbler's Avatar
Joined Feb 2003
We probabaly shouldn't let this turn into one of those threads where we bash the plane before it's even out. Let's just hope they learned from the Sniper 90's weak points and improved them.
Based on the issues I had with my Sniper 90 I hope they:
1. Make the fuse wide enough between the intakes for large packs.
2. Make it possible to CG without having to move the fan back or use small 3000mah packs. I see they are calling for 4200 packs, but as you know the high powered setups need 5000 packs.
3. Make the gear stance wider and as LEE mentioned, move the gear farther behind the CG
4. Make sure the tail is up to 150+mph speeds and high G turns.
Brian
Old Nov 10, 2011, 04:12 PM
lightningmcnul is offline
Find More Posts by lightningmcnul
USA, CA, Marina del Rey
Joined Jul 2010
Looks great, can't wait! and screw the HK viper now!!!!
lightningmcnul is offline Find More Posts by lightningmcnul
Old Nov 10, 2011, 04:18 PM
kevin is offline
Find More Posts by kevin
kevin's Avatar
United States, OH, Grove City
Joined Aug 1999
This plane is soooo close to looking real good. Too bad they didn't integrate the wing and especially the horizontal stab into the fuse better on this version. The stab still looks like they ran out of time so just stuck it on the bottom of the fuse.
kevin is offline Find More Posts by kevin
Latest blog entry: Video of my Freewing Yak-130
Old Nov 10, 2011, 06:34 PM
Joined Jul 2010
Whats the chance of fitting larger than a 90mm in this plane?
Old Nov 10, 2011, 09:08 PM
AceMigKiller is online now
Find More Posts by AceMigKiller
Team EJF >>>WHOOSH>>>
AceMigKiller's Avatar
Joined Jul 2004
Sneak Peak Pics for fellow RCG'ers
Here's some more sneak peak pics for you guys!
I'm really liking the way this thing went together. Lots of room to work in/around it, and the fit of these parts is probably the best I've seen yet.
Fitting a 100mm fan in this thing could definitely be possible (of course you'd have to re-work the intake a little); the only setback I see on this one is fitting enough packs to feed a 100mm fan. The biggest faux-pas on this bird is room for packs. I can barely squeeze 12s 5000's in the nose...
However, the stock setup on 10s 4200's fits fine, and so do 12s 4200's.
I'll be using the same setup I'm running in my HET 90mm L-39; 10s 4200mah. This gives me about 3.5kw and ~10lbs. thrust --- The L-39 is clocked consistently at 130+mph, so I'm betting this MUCH cleaner airframe will yield about 150mph! We'll just have to wait to see how she does on the maiden.
Vic
AceMigKiller is online now Find More Posts by AceMigKiller
Old Nov 11, 2011, 02:20 AM
Joined Jul 2010
I'm thinking 110mm maybe a stumax!! where is the fan is it under the wing or way in the back like the L39?
Old Nov 11, 2011, 06:37 AM
scatsob is offline
Find More Posts by scatsob
Bypass Ratio = Infinity
scatsob's Avatar
United States, NC, Jacksonville
Joined Apr 2006
I think this is a great improvement to the origional. However it would have been fun to have some imput to the changes, like the inlets and the battery compartment. Waiting on price.
scatsob is offline Find More Posts by scatsob
Old Nov 11, 2011, 07:22 AM
Lee Liddle
Carrollton, Tx
Joined Dec 2006
Not only fun but it would have been a smart business move on HETs part to get some input from their customers. They could always choose not to follow the advice, but it would have been productive to at least ask.
Old Nov 11, 2011, 09:13 AM
therealhiphop is offline
Find More Posts by therealhiphop
therealhiphop's Avatar
USA, UT, Springville
Joined Dec 2005
Would be nice to see what other color schemes will be available.
therealhiphop is offline Find More Posts by therealhiphop
Old Nov 11, 2011, 09:18 AM
scatsob is offline
scatsob's Avatar
Joined Apr 2006
What's the wing area?
Old Nov 11, 2011, 12:15 PM
Tumbler is offline
Tumbler's Avatar
Joined Feb 2003
Just remember the opening in the back can only be opened up so much regardless of how big of a fan that can fit in the fuse. The exhaust cone is very short so it will start to look goofy trimmed all the way to the rudder. the way the intake is set up, they didn;t make it easy to use a larger fan either. You would have to move the fan back so you have room to make an inlet adapter to step uo from a 90 to 100mm+.
It's "ok" looking in my opinion. If it's priced where the L-39 is, then its a good deal. As someone said the stab and even the wing look like they are just sort of slapped on the bottom which I don;t like. I wish they took the time to mold them into the fuse better.
Old Nov 11, 2011, 01:26 PM
scatsob is offline
scatsob's Avatar
Joined Apr 2006
I'm hoping that because they didn't really do much development compared to a whole new model that it will be less than the L-39. It looks like they simply scaled up the old sniper and made it a composite wing with flaps. I'm thinking $250-$300.
Cool New HET L-39 90mm by EJF.com AceMigKiller Electric Ducted Fan Jet Talk 706 Mar 09, 2015 07:37 PM
Sold Crazy Price Drop!! HET Super Sniper with 70mm Mega/HET power system and servos. airmcn_3 Aircraft - Electric - Jets (FS/W) 9 Nov 14, 2011 11:37 AM
Found HET Sniper 90mm, airframe and maybe servos Knife Liddle Aircraft - Electric - Jets (FS/W) 2 Oct 01, 2011 11:10 AM
Sold NIB HET Super Sniper 90 V3 with HET 90mm fan and HET 600-37 motor mcgoughman Aircraft - Electric - Jets (FS/W) 0 Aug 30, 2011 08:35 PM
Sold HET All Composite Super Sniper priscalex Aircraft - Electric - Jets (FS/W) 0 Jun 30, 2008 09:17 PM
