Old Jan 07, 2012, 12:06 AM
AIR SALLY is online now
Find More Posts by AIR SALLY
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
Originally Posted by AceMigKiller View Post
I'll be there walkin' around tomorrow!
No booth, Robert and I are both busy busy busy...
Vic
bummer i guess i'll have to pick up the F-86 molds at AEF ...thats a good reason to go
AIR SALLY is online now Find More Posts by AIR SALLY
Old Jan 07, 2012, 02:39 PM
Hossinarizona is offline
Find More Posts by Hossinarizona
More Speed Indeed!
Hossinarizona's Avatar
USA, AZ, Tucson
Joined Nov 2007
Mike!
I just re-discovered the envelope w/ Sniper decals I was supposed to send to you!!!
My apologies... can I hand-deliver them to you @ AZ E-Fest?
Hey Vic,
Not a problem, I am still doing a little tewaking on it. Thanks for taking the time to find them, see you at AZ E-Fest. Oh, enjoy yourself at the AMA expo, it should be fun, I will be in Boston the entire week, maybe next year for me.
See ya soon,
Hossinarizona is offline Find More Posts by Hossinarizona
Old Jan 08, 2012, 12:00 AM
Extreme_RC is offline
Find More Posts by Extreme_RC
Extreme CNC Alloy EDF
Extreme_RC's Avatar
Australia
Joined Mar 2006
They should do a green & gold all Aussie scheme too
I am thinking of doing a primer one next month and then doing it in grey and tiger scheme like an F16, should look quite nice. Am excited about the new Sniper, finally the right size 90mm!
Extreme_RC is offline Find More Posts by Extreme_RC
Old Jan 08, 2012, 04:23 AM
neversommer is offline
Find More Posts by neversommer
neversommer's Avatar
Luzern/Switzerland
Joined Aug 2008
I really dig the Green Lightning Scheme to be honest.
If these are the true color schemes.I am in for the Green Version
399 Bucks ain't expensive anyway.
I got the Power Drive System, ESC, Servos..
Now I just need new Batteries, Rx and I am good to go
Can't wait!
NS.
neversommer is offline Find More Posts by neversommer
Old Jan 08, 2012, 04:34 AM
Luzern/Switzerland
Joined Aug 2008
Vic
Would you do me a favor please?
I am buying 2x 4S Battery Packs and I wanna know if they may fit in there.
Dimensions are:
(H)41x(W)45x(L)154mm
Weight: 593Grams
Highly Appreciate it
NS.
Old Jan 08, 2012, 12:33 PM
AceMigKiller is online now
Find More Posts by AceMigKiller
Team EJF >>>WHOOSH>>>
AceMigKiller's Avatar
Joined Jul 2004
Those packs are a go! (with room to spare)
AceMigKiller is online now Find More Posts by AceMigKiller
Old Jan 08, 2012, 12:35 PM
Joined Jul 2004
My Aussie might have a bone to pick with you...
He says it should be Black/White/Copper!
Old Jan 08, 2012, 12:46 PM
Joined Jul 2004
Guys,
The AMA Expo was awesome. Not so much in the way of "deals" (unless you're looking for a junk throw-away cheapy heli) but lots of neat new products from our local favorite manufacturers/vendors.
Bumped elbows with alot of old and new friends and I'm totally motivated for the 2012 flying season! I hope to see many of you at the first big show of the year here in the Southwest: the Arizona Electric Festival
Vic
Old Jan 08, 2012, 02:17 PM
Luzern/Switzerland
Joined Aug 2008
Hi Vic
So you can confirm me the dimensions I provided?
If so then I am all over this Jet and I will commence and initialize the battery payment for 2x4S
Besides Vic..I think our Dog may have another bone to pick with yours
He says, it should be Black/Orange(gold)/White, lol!
NS.
Old Jan 08, 2012, 05:38 PM
Joined Jul 2004
Hi Vic
The battery dims you provided in your earlier post fit well in the XL90.
Height was not a factor, Width of 45mm gives you a few mm's per side to slip in/out, and Length is no factor... you'll be free to slide packs around no problem.
I guess my question to you would be; an 8s setup?
Just as a heads up, you will have to go higher than the 1485kv setup I'm currently running, and you'll be pulling some massive current (at least 100amps) on the HET 9305V2. I'm sure the bird would fly just fine on the 1485kv with 8s (I've flown the L-39 on 8s, which is draggier), but you will be much happier with the performance on 10s or 12s. Just my opinion.
Vic
Old Jan 08, 2012, 06:19 PM
Extreme_RC's Avatar
Australia
Joined Mar 2006
We'll have to agree to disagree there I dont think the 9305 has all that great performance, not when our 8s 3000w wemo setups do well over 150mph in the JTM hawk which is heavier, and draggier than the sniper.
Old Jan 08, 2012, 07:01 PM
Joined Jul 2004
If you can get the 9305V2 to pull 3kw on 8s, I'm sure it'd be a rocket ship!
All I'm saying is that to get 3kw (even on awesome packs) you'll have to draw upwards of 100+amps.
The HET L-39 (w/ 1485kv 700-series motor) was clocked at 112mph on 8s, but that was only 85 amps. Knowing this, I'm sure the XL90 on that setup would probably be in the range of 120-125mph.
Now if we bump the kv up a notch, which I would recommend for 8s, you'd get some higher RPM's for sure but at the cost of more amps.
Old Jan 08, 2012, 07:09 PM
More Speed Indeed!
USA, AZ, Tucson
Joined Nov 2007
Hey Vic,
I am updating the push rod set up on my old Sniper, in the picture below what type of rod and ball links did you use in the new Sniper?
Old Jan 08, 2012, 07:20 PM
Joined Jul 2004
That particular Ball Link came from a Hyperion kit.
However, I would (and will) use a Dubro 2-56 Swivel Ball Link (Part No. DUB367).
The control rod length is short enough to use 2-56, but a 4-40 may be substituded if desired.
Vic
Old Jan 08, 2012, 07:54 PM
Knife Liddle is online now
Find More Posts by Knife Liddle
Lee Liddle
Knife Liddle's Avatar
Carrollton, Tx
Joined Dec 2006
The ARC 36-75-1t (1680 kv) on 8s in the 9305 pulls about 110a at about 3.2kw. The fan/motor combo is great for 8s, but you are right, it`s a lot of amps. If I went with 8s on this jet, I`d go with larger packs than 5000mah. The weight would work out about the same.
Personally I`d go with a 12s system because it would match the lipos that I have.
Knife Liddle is online now Find More Posts by Knife Liddle
Cool New HET L-39 90mm by EJF.com AceMigKiller Electric Ducted Fan Jet Talk 706 Mar 09, 2015 07:37 PM
Sold Crazy Price Drop!! HET Super Sniper with 70mm Mega/HET power system and servos. airmcn_3 Aircraft - Electric - Jets (FS/W) 9 Nov 14, 2011 11:37 AM
Found HET Sniper 90mm, airframe and maybe servos Knife Liddle Aircraft - Electric - Jets (FS/W) 2 Oct 01, 2011 11:10 AM
Sold NIB HET Super Sniper 90 V3 with HET 90mm fan and HET 600-37 motor mcgoughman Aircraft - Electric - Jets (FS/W) 0 Aug 30, 2011 08:35 PM
Sold HET All Composite Super Sniper priscalex Aircraft - Electric - Jets (FS/W) 0 Jun 30, 2008 09:17 PM
