Old Feb 05, 2013, 05:05 PM
CRCJA is online now
Find More Posts by CRCJA
wannabe Jet guy
CRCJA's Avatar
Green Valley, AZ
Joined Aug 2004
Yes, he first glued the servos then used the servo mounting screws. Now in my case it was alsmost the same, but I used some servo mounting hardware I bought from Tam at Tamjets.com a while back. I can take out the servo and replace them if I have a problem. I just takes a while to put the screws in there by FEEL only since your hand has to be inside the fuselage.
Ralph
Originally Posted by heliclown View Post
Hi Ace
Not sure of the term "potted", on your servo mounting, do you mean the servos are wrapped on masking tape and epoxied to base as well as scewed?
Steve
CRCJA is online now Find More Posts by CRCJA
Old Feb 05, 2013, 05:17 PM
Hossinarizona is offline
Find More Posts by Hossinarizona
More Speed Indeed!
Hossinarizona's Avatar
USA, AZ, Tucson
Joined Nov 2007
Ralph
Ralph,
Looks like an exam I got a few weeks ago
Hossinarizona is offline Find More Posts by Hossinarizona
Old Feb 05, 2013, 07:15 PM
keithtsr is offline
Find More Posts by keithtsr
Keith Thomas
keithtsr's Avatar
United States, NM, Portales
Joined Feb 2010
Brings back some bad memories Worst Dentist I've ever been to
keithtsr is offline Find More Posts by keithtsr
Old Feb 06, 2013, 05:34 AM
GregG is online now
Find More Posts by GregG
Speed Demon
GregG's Avatar
Antioch,CA,USA
Joined Dec 1999
Just an idea .......
On my F5D models, because of thier tiny fuselage cross section behind the wing saddle where the elevator servo goes, I also screw the servo to a plywood plate.
The servo/plate is then inserted back into the fuse with the linkage already installed. I then use a few screws run through holes on the bottom of the fuse to mount said servo plate.
This allows easy servo replacement, adjustment if need be, and a solid mounting.
GregG is online now Find More Posts by GregG
Old Feb 07, 2013, 08:48 PM
AceMigKiller is online now
Find More Posts by AceMigKiller
Team EJF >>>WHOOSH>>>
AceMigKiller's Avatar
Joined Jul 2004
Finally Done!
Alright!
Just one last little touch and she's ready to rock! Of course it's the one part I don't have any left of and all hobby shops are closed for today...
Oh well, don't even know when I'm going to have time to maiden her yet anyways!
Vic
AceMigKiller is online now Find More Posts by AceMigKiller
Old Feb 07, 2013, 09:04 PM
Jim Varley is offline
Find More Posts by Jim Varley
Glitch Master
Jim Varley's Avatar
USA, AZ, Mesa
Joined Apr 2007
Originally Posted by AceMigKiller View Post
Alright!
Vic
Have your dad bring it with him to the field on Saturday, I am very busy, but will maiden it for you and report back with handling characteristics. It's the least I can do.
Jim Varley is offline Find More Posts by Jim Varley
Old Feb 07, 2013, 11:23 PM
Joined Jul 2004
Jim, you're KrAzY!!!
That made me laugh, you may have just earned yourself a buddy box flight!
Old Feb 12, 2013, 09:30 PM
Jayray123 is offline
Find More Posts by Jayray123
OUCH!!!
Jayray123's Avatar
United States, PA, Erie
Joined Sep 2008
Got mine in today, started with replacing the wing mounts with plates spanning the width of the fuse. Stab mounts will get attention after I get the servo and pushrod location sorted. Working on the wing servos, getting HS-65hb's to fit flush. I really don't want to pot them, but coming up with a viable mounting solution is going to take a beer or two.
Jay
Jayray123 is offline Find More Posts by Jayray123
Old Feb 12, 2013, 09:41 PM
keithtsr is offline
Keith Thomas
keithtsr's Avatar
Joined Feb 2010
I got mine a week or so ago and really haven't had time to look at it, well look at it that close. Have I missed something, I don't understand, is the wing mounts not good?
Old Feb 12, 2013, 09:46 PM
OUCH!!!
Jayray123's Avatar
Joined Sep 2008
They are blind nuts fitted to 1/2" round plywood dots. There is no load bearing area at all. It's actually an easy fix, the plywood pops right off the fuse. Just a bit of fitting of the new plates. I used 1/16" as a base and then a 1/8" plate with the blind nut attached to the base. Spreads everything out nicely. I'll put the pics up in the morning when I get home.
Jay
Old Feb 12, 2013, 09:50 PM
keithtsr is offline
Keith Thomas
keithtsr's Avatar
Joined Feb 2010
That makes sense, thanks for the heads up. I've got to get a couple little projects off the bench.
I think I need another bench! 16' of bench just ain't enough!
Old Feb 12, 2013, 09:52 PM
OUCH!!!
Jayray123's Avatar
Joined Sep 2008
I just moved into a new house and took over the basement. Now I have 5 benches and managed to fill them all...........
Old Feb 12, 2013, 10:04 PM
keithtsr is offline
Keith Thomas
keithtsr's Avatar
Joined Feb 2010
I know....I have a 30X36 shop that is just to small, and it's just for my planes.
Old Feb 13, 2013, 01:18 AM
dbgood is offline
Find More Posts by dbgood
Fly Fast!
dbgood's Avatar
scotia ,NY
Joined Jul 2008
Hs-85 for Sniper XL
Hi guys,
Anyone know if the Hi-Tec, Hs-85 fit in the Super Sniper XL,
with out any mods or cutting,to small or to big?
Anyone using these servos for it? I have 7 of them and need a home
for them?
Maybe might be my next jet!!
Thanks everyone,
DB
dbgood is offline Find More Posts by dbgood
Old Feb 13, 2013, 02:16 AM
OUCH!!!
Jayray123's Avatar
Joined Sep 2008
Someone in here is using 82's all the way around, and IIRC the 82 and 85 aren't much different from each other.
Cool New HET L-39 90mm by EJF.com AceMigKiller Electric Ducted Fan Jet Talk 706 Mar 09, 2015 07:37 PM
Sold Crazy Price Drop!! HET Super Sniper with 70mm Mega/HET power system and servos. airmcn_3 Aircraft - Electric - Jets (FS/W) 9 Nov 14, 2011 11:37 AM
Found HET Sniper 90mm, airframe and maybe servos Knife Liddle Aircraft - Electric - Jets (FS/W) 2 Oct 01, 2011 11:10 AM
Sold NIB HET Super Sniper 90 V3 with HET 90mm fan and HET 600-37 motor mcgoughman Aircraft - Electric - Jets (FS/W) 0 Aug 30, 2011 08:35 PM
Sold HET All Composite Super Sniper priscalex Aircraft - Electric - Jets (FS/W) 0 Jun 30, 2008 09:17 PM
