Old Nov 10, 2012, 12:57 PM
EDForever is offline
Find More Posts by EDForever
Joined Nov 2012
Originally Posted by corsair nut View Post
140~145ish
Originally Posted by AceMigKiller View Post
Ehhhh... I got a shade more on my 12s bird... 145-150ish on 4kw.
It will easily push through 160-165mph out of a dive.
thanks.. that could be good..
EDForever is offline Find More Posts by EDForever
Reply With Quote  (Disabled)
Old Nov 13, 2012, 01:18 PM
corsair nut is online now
Find More Posts by corsair nut
fly like an EAGLE ;)
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
video of my sniper!!!!
thanks SWAT!!!!
http://www.rcgroups.com/forums/showthread.php?t=1769120
corsair nut is online now Find More Posts by corsair nut
Old Nov 13, 2012, 01:25 PM
AceMigKiller is offline
Find More Posts by AceMigKiller
Team EJF >>>WHOOSH>>>
AceMigKiller's Avatar
Joined Jul 2004
Nyce
AceMigKiller is offline Find More Posts by AceMigKiller
Old Nov 13, 2012, 01:33 PM
gbmoore is offline
Find More Posts by gbmoore
Colorado Springs, Co
Joined May 2002
thanks SWAT!!!!
What are you using for your CG?
Greg
gbmoore is offline Find More Posts by gbmoore
Old Nov 13, 2012, 02:15 PM
Joined Nov 2012
Guys.. anyone's interested in a 90mm EDF unit?
had it in my L-59 but I'm going High voltage..
it's a 3000watts 8s setup
Lander DPS multi-stator shroud
HET 700-68-1400kv motor 8MM shaft
CS12 good stiff blades
had around 20 flights so far
willing to separate motor if anyone wants that only..
already got someone who wants the shroud only but I prefer to give it as a whole thing
motor is 100 usd shipped
whole thing 145usd shipped WW and will also receive a set of extra blades.. of the good batch those too.. and adapter for 5mm
note that the shroud only coster 47+shipping from rclander directly..
motor is 129 +shipping
blades came from a complete edf unit soit's 45+shipping..
so I think 145 is a very good price.
Old Nov 15, 2012, 02:28 PM
outkast1779 is offline
Find More Posts by outkast1779
Fret for your pilot...
outkast1779's Avatar
Phoenix
Joined Apr 2006
Trying to finish up my Sniper
Are you guys using Hysol to attach the horizontal stab?
Its a little disconcerting knowing that I will have to cut into this airplane when a servo goes bad..
outkast1779 is offline Find More Posts by outkast1779
Old Nov 15, 2012, 03:58 PM
Joined Jul 2004
Maybe I've been lucky, maybe I use good servos, but I've never had a servo go bad when used under normal operating conditions.
Hysol would work, or just use Epoxy. Either way, make sure to sand away the paint on your glue joint areas. I also poke some small holes in each surface to give the glue a little more *grab* power.
Old Nov 15, 2012, 10:52 PM
CRCJA is offline
Find More Posts by CRCJA
wannabe Jet guy
CRCJA's Avatar
Green Valley, AZ
Joined Aug 2004
rUDDER sERVO
OR go back and modify it to your liking. I changed mine twice, so that means you should have a prettry good idea, on how to do it once, if you look at my pictures.
http://www.rcgroups.com/forums/showp...postcount=1563
Ralph
BTW, Mine is getting a New Paint Job.
CRCJA is offline Find More Posts by CRCJA
Old Nov 16, 2012, 08:16 PM
pulsar110 is offline
Find More Posts by pulsar110
USA, UT, Provo
Joined Apr 2003
What are you guys using for white paint to touch up after glassing the wing joint?
pulsar110 is offline Find More Posts by pulsar110
Old Nov 17, 2012, 03:03 PM
USA, UT, Provo
Joined Apr 2003
So answering my own question. I went and got a couple rattle cans at the LHS to try. From my heli canopy painting days I knew that Pactra in Sprint White might be close so I tried it. I havent pulled the masking off yet but did hold the cutout from the nose gear close and its close enough for me. I take a pic later after pulling the masking off. I painted the wheel wells and center where I put the glass to join the panels. Reason for wheel wells is that I had to do some sculpting in there to get my struts to fit. Im using the RCL struts, slightly modified.
Old Nov 17, 2012, 03:55 PM
Knife Liddle is offline
Find More Posts by Knife Liddle
Lee Liddle
Knife Liddle's Avatar
Carrollton, Tx
Joined Dec 2006
When I start doing that, I'm going to get a dog.
Knife Liddle is offline Find More Posts by Knife Liddle
Old Nov 17, 2012, 04:23 PM
USA, UT, Provo
Joined Apr 2003
LOL. I have one of those and he knows everything I talk about too.
Before I went to the LHS I tried a couple cans that I have of white from Lowes/ Home Depot one of those being Rustoleum. Those colors looked more like cream compared to the white that was on my plane.
The Sprint White is looking pretty good. Will need a gloss clear over the top but looks pretty close.
Old Nov 18, 2012, 11:06 PM
Phoenix
Joined Apr 2006
Ranting
Awesome HET. No wood blocks behind the flap hinge holes in the wing. This is the "NEW" kit. VERY agitating!
EJF, you guys have been great. But this HET product is really B.S. They are forgetting about some of the most crucial building points. Stuff that should be double checked before it leaves the factory. Really wanted to fly this in the rally.
OK, I feel better now.
Old Nov 22, 2012, 08:42 PM
DontTMACajun is offline
Find More Posts by DontTMACajun
DontTMACajun's Avatar
United States, LA, Gray
Joined Jul 2011
Hi all
I've bounced through the majority of this thread, and would like to ask....did the fluttering elevator issue get fixed with the V2?
Curious....I've got my mind set on an XL in the near-future.
Thanks in advance
DontTMACajun is offline Find More Posts by DontTMACajun
Old Nov 22, 2012, 08:49 PM
USA, UT, Provo
Joined Apr 2003
Im putting a new version together and several others are flying both versions with no trouble. I havent heard of any flutter with the new tail feathers. Somewhere back a few pages it was brought to light that MAYBE part of that problem was some guys flying way faster than it was really designed to do. Bottom line if your not a total speed demon Id say get it and have fun.
Cool New HET L-39 90mm by EJF.com AceMigKiller Electric Ducted Fan Jet Talk 706 Mar 09, 2015 07:37 PM
Sold Crazy Price Drop!! HET Super Sniper with 70mm Mega/HET power system and servos. airmcn_3 Aircraft - Electric - Jets (FS/W) 9 Nov 14, 2011 11:37 AM
Found HET Sniper 90mm, airframe and maybe servos Knife Liddle Aircraft - Electric - Jets (FS/W) 2 Oct 01, 2011 11:10 AM
Sold NIB HET Super Sniper 90 V3 with HET 90mm fan and HET 600-37 motor mcgoughman Aircraft - Electric - Jets (FS/W) 0 Aug 30, 2011 08:35 PM
Sold HET All Composite Super Sniper priscalex Aircraft - Electric - Jets (FS/W) 0 Jun 30, 2008 09:17 PM
