Old Oct 22, 2012, 08:14 PM
AceMigKiller is online now
Find More Posts by AceMigKiller
Team EJF >>>WHOOSH>>>
AceMigKiller's Avatar
Joined Jul 2004
Post pics!
I'll be doing the same as soon as I get building.
AceMigKiller is online now Find More Posts by AceMigKiller
Old Oct 22, 2012, 08:16 PM
pulsar110 is offline
Find More Posts by pulsar110
USA, UT, Provo
Joined Apr 2003
Ill do that. Have you used the HET 002 servos?
pulsar110 is offline Find More Posts by pulsar110
Old Oct 22, 2012, 08:20 PM
Joined Jul 2004
Have not; I'll be using Hyperion digital servos.
Old Oct 22, 2012, 09:08 PM
Tumbler is online now
Find More Posts by Tumbler
Tumbler's Avatar
United States, NJ, Vineland
Joined Feb 2003
will hs82mg's work for this plane. they are 50ozs of torque on 6v so I am assuming they will. i am thinking about this fan. trying to find out if it is truly ready to run. dont feel like messing around with balancing. been down that road with these 12 blade fans....it sucks. haha
http://www.hobbyking.com/hobbyking/s...watt_10s_.html
Tumbler is online now Find More Posts by Tumbler
Old Oct 22, 2012, 09:51 PM
Joined Jul 2004
Hitech makes good stuff and 82MG's are good economical servos.
They would work well on the Ailerons, Flaps, Rudder and Steering, but I would definitely stick something a little beefier on the Elevator regardless of what Stab. version you're building.
Vic
Old Oct 22, 2012, 10:14 PM
gbmoore is online now
Find More Posts by gbmoore
Colorado Springs, Co
Joined May 2002
[QUOTE=Tumbler;23074456]will hs82mg's work for this plane. they are 50ozs of torque on 6v so I am assuming they will. i am thinking about this fan. trying to find out if it is truly ready to run. dont feel like messing around with balancing. been down that road with these 12 blade fans....it sucks. haha
I'm using 5085's all round.
Greg
gbmoore is online now Find More Posts by gbmoore
Old Oct 22, 2012, 11:24 PM
USA, UT, Provo
Joined Apr 2003
Vic what sort of torque are you thinking on the elevator?
Old Oct 23, 2012, 12:07 AM
CRCJA is offline
Find More Posts by CRCJA
wannabe Jet guy
CRCJA's Avatar
Green Valley, AZ
Joined Aug 2004
Bad Combo
I guess I will say it again;
Do NOT even think about using them if you have a Futaba Radio and plan on running 6V. I tested them and they worked fine with JR, Spektrum, Airtronics BUT with a Futaba RX and TX The servos will go crazy after little use and when you least expect them. I learned the hard way after they destroyed my MIG-15
Ralph
CRCJA is offline Find More Posts by CRCJA
Old Oct 23, 2012, 12:11 AM
USA, UT, Provo
Joined Apr 2003
Ralph,
Thats interesting, wonder why that is exactly. I use JR systems but still thats a bit unsettling.
Old Oct 23, 2012, 12:12 AM
CRCJA is offline
wannabe Jet guy
CRCJA's Avatar
Green Valley, AZ
Joined Aug 2004
Servos
Brian,
I used HS65MG on Aileron and Rudder. Futaba 3102 on each elevator half and flap with my XL, I am also running 6V for RX. Now I have been using the 82MG for most of my applications on EDF and would of used them here too, but since I was using a Futaba RX and I had plenty of 3102's I used those.
Ralph
Old Oct 23, 2012, 06:20 AM
GregG is online now
Find More Posts by GregG
Speed Demon
GregG's Avatar
Antioch,CA,USA
Joined Dec 1999
Originally Posted by Michael Paxton View Post
Done with intake splitter for now......
Some pics. Best I could do.
Inside wall is now just 3/8 white foam and lots of heavily "ballooned" epoxy.
diverter wall is 1/64 ply to make it flat and as smooth as possible.
To the best of my calculations, intake is still 100% FSA
Came out well I think. We'll see when it flys.
Your splitters look pretty cool!
Why can't the manufacturers figure out that all they do by using too big an intake is slow the plane down by adding drag?
GregG is online now Find More Posts by GregG
Old Oct 23, 2012, 07:21 AM
Tumbler's Avatar
Joined Feb 2003
Cool, thanks. I used 3102's on all surfaces of my Blaze which is heavier and faster than the Sniper. They work great. They have a little more torque than an 82 or 85, but I find the 3102 to have a ton of play in the gears and unless I use the inner most hole on the servo arm it translates to a lot of play at the control horn.
Originally Posted by CRCJA View Post
Brian,
Ralph
Old Oct 23, 2012, 10:45 AM
CRCJA is offline
wannabe Jet guy
CRCJA's Avatar
Green Valley, AZ
Joined Aug 2004
Yep
I had to borrow a couple of TX to test it out and to be clear, the servos seem to work FINE in 4.8V but can't stand 6.0V with a Futuba RX
Ralph,
HET Servo Failure Test#2 (1 min 21 sec)
HET Servo Failure (3 min 7 sec)
Old Oct 23, 2012, 11:35 AM
Hossinarizona is offline
Find More Posts by Hossinarizona
More Speed Indeed!
Hossinarizona's Avatar
USA, AZ, Tucson
Joined Nov 2007
http://www.youtube.com/watch?v=lkIv1blJGSg
http://www.youtube.com/watch?v=G__m5yVndqk
Ralph,
Now I see what you mean about that F100 glass job, it's a mess!
Hossinarizona is offline Find More Posts by Hossinarizona
Old Oct 23, 2012, 03:56 PM
Joined Jul 2004
I'll be using a Hyperion DS16FMD (Digital/Metal Gear) for Elevator.
It's overkill, with 152.8oz/in. on 6v.
http://www.servodatabase.com/servo/hyperion/ds16-fmd
Vic
Cool New HET L-39 90mm by EJF.com AceMigKiller Electric Ducted Fan Jet Talk 706 Mar 09, 2015 07:37 PM
Sold Crazy Price Drop!! HET Super Sniper with 70mm Mega/HET power system and servos. airmcn_3 Aircraft - Electric - Jets (FS/W) 9 Nov 14, 2011 11:37 AM
Found HET Sniper 90mm, airframe and maybe servos Knife Liddle Aircraft - Electric - Jets (FS/W) 2 Oct 01, 2011 11:10 AM
Sold NIB HET Super Sniper 90 V3 with HET 90mm fan and HET 600-37 motor mcgoughman Aircraft - Electric - Jets (FS/W) 0 Aug 30, 2011 08:35 PM
Sold HET All Composite Super Sniper priscalex Aircraft - Electric - Jets (FS/W) 0 Jun 30, 2008 09:17 PM
