Old Sep 20, 2012, 09:32 PM
falconjet50 is offline
Find More Posts by falconjet50
United States, FL, Coral Springs
Joined Jan 2007
I recieved my new Horizontal Stab for the Sniper today, Looks very nice. I was wondering how people are setting up the Elevator now that it is two piece. Will one servo still work or is this a two servo set up ?? Special Thanks to Matt Hague from Fan Jet USA for helping me get the Stab. You get a A++ for customer service. Thanks again!!
falconjet50 is offline Find More Posts by falconjet50
Old Sep 20, 2012, 11:11 PM
racer1 is offline
Find More Posts by racer1
5kW Club
racer1's Avatar
United States, AZ, Tucson
Joined Feb 2007
I made it for a two servo control system.
Look at CRCJA build
http://www.rcgroups.com/forums/showp...postcount=1748
There is probably no reason it could not be a single servo, but you would have to work the linkage out.
Clay
racer1 is offline Find More Posts by racer1
Old Sep 21, 2012, 09:42 AM
SCALEFAN is offline
Find More Posts by SCALEFAN
Done it all
United States, CA, Corona
Joined Feb 2006
The whole topic of the re-designed stab has been very interesting. However it also brings some new questions as to what effect it may have on performance. My questions.
1. Will having two servos, vrs one, in the thrust tube effect thrust performance?
2. The builder could actually have the ESC, along with two servos blocking the thrust tube, would this effect thrust performance?
Tam streamlined his setup by enclosing the ESC, but just think about the blockage in a thrust tube without Tam's setup, the ESC and the loose wires, two servos and the wires ect.
The streamlined thrust tube would be much less streamlined, just asking because I don't know the answer.
SCALEFAN is offline Find More Posts by SCALEFAN
Old Sep 21, 2012, 10:28 AM
corsair nut is online now
Find More Posts by corsair nut
fly like an EAGLE ;)
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
my servos dont bother my thrust tube at all. esc placement can be done in a number of differnt manners, a number of which dont place the esc in the pipe.
corsair nut is online now Find More Posts by corsair nut
Old Sep 21, 2012, 11:05 AM
SCALEFAN is offline
Done it all
Joined Feb 2006
I should amend my question.
If the ESC or the servos are in the way of the pipe, or cause the pipe to be deflected, would it cause a decrease in thrust performance?
I should note that my single servo causes a slight deflection in the pipe, a crease, and my ESC is in the tube, hanging loose. I don't care about speed and my flying would never cause flutter. But, for the guys that are worried and wanted the stab changed, this question is for you.
Would a clean and streamlined pipe be better for performance, or doesn't it matter?
Old Sep 21, 2012, 11:12 AM
kremecheze is offline
Find More Posts by kremecheze
kremecheze's Avatar
United States, NY, Queens County
Joined Jun 2007
did you buy your sniper from fanjetsusa? and how long did it take to get your new stab?
kremecheze is offline Find More Posts by kremecheze
Old Sep 21, 2012, 11:24 AM
CRCJA is online now
Find More Posts by CRCJA
wannabe Jet guy
CRCJA's Avatar
Green Valley, AZ
Joined Aug 2004
My Elevator Servo location
AL,
Here is a recap of my install, by placing the servos in front of the Horizontal stab, I accomplished two things:
1. Glue them to the bottom of the plane and also have them glued to the edge created for the stab, kind of like a corner there, so I have more grabbing power there.
2. The servos are actually lower than they would be in the stab. Plus with two servos, I am running the pushrods to the SIDES of the trust tube for the most part
As far as the ESC goes, mine is on the side of the fuselage where I put in the side scoop (NACA scoop) and does not interfere, while mine is an ICE100, I don’t see a problem with even a ICE 160 in the same location, of course some controllers are bigger than others, I can take some more specific pictures tonight if you like. Just a reminder, sand with 80 grit and clean it before you glue anything in, the inside of the entire plane is incredibly dirty and dusty. BTW, I still have not found off-the-shelf paint (Model Masters or equivalent rattle can) to match the Fuselage
Ralph
CRCJA is online now Find More Posts by CRCJA
Old Sep 21, 2012, 10:15 PM
Joined Jan 2007
Yes, I purchased the Sniper Green Lightening back in April. I have around 20 flights on it, the new stab took about two weeks to get from Matt at Fanjetusa. Matt had the Jet drop shipped to my house and then he work with me to get me the Free replacement stab when HEt announced the replacement was availible.
Old Sep 21, 2012, 11:17 PM
kremecheze's Avatar
Joined Jun 2007
does matt have any more in stock? i just ordered some fans from his site
Old Sep 22, 2012, 03:12 PM
foss1997 is offline
Find More Posts by foss1997
toledo, oh, usa
Joined Nov 1999
Ok, finally got it in the air. A couple of notes.
-This is my first, and last HET "kit"-nuff said. What a POS, thats an understatement.
-Thanks EJF for quick communication and A+ service.
-This model is the perfect size and flys, even after only one flight, pretty well.
I bought this model last spring. It was quickly shelved due to the constant issues people were having and my own experience in trying to get things together and reviewing the quality and amount of reworking it would take.
FWIW, I am an experienced modeler of 25+ years. I have built and flown all sorts of models including some of the highest end in model turbines. I have built 3 BVM bandits (Balsa, Composite, and the ARF) alone. I bought this plane given its Bandit like looks and all composite construction under the assumption that it would fly sorta kinda a little bit like one. Another reason was for its size as an after hours/evening sport e-jet.
Having had the maiden today I am happy to report that the worst build I have ever had to do was at least, so far, worth it. You can tell alot about a model even with one flight and this one flys decent enough. Im running a lighter 6s setup with an Ejet 90 fan, ARC 36651 and 5000's (2300 watts, 107 amps). Model weight is 8.2 lbs. Had to add 1.5 oz in the nose to balance at 4.25". Need 3/32 or so right trim despite building a fairly straight wing. Flys decently fast, probably 120-130 with good vertical. Slows down nicely. No bad tendency but had a good head wind and didnt slow it down too much. Rolls horribly but I assume thats the built in differential due to the preinstalled malpositioned control horn which I will later correct in the TX.
Time will tell more about secondary flight characteristics and durability but I am honestly not expecting much, anything beyond this is a bonus!
Only some of the issues:
No wood or any support in more than 50% of the precut hinge slots. Center hinged flaps, top hinged ailerons. All-ready mentioned issues on stab design. Garbage hardware. No glue at all nearly anywhere on any former, blind nut, or any other important structure. Suggested rudder geometry is all screwed up. Lack of former supporting tail.
Mod's:
Beyond correcting the above, dubro nylon pinned hinges. Pinned the front of the wing and the stab with 1/4 CF rod into former in fuse. Pinned front of canopy and canopy latch on the back. Shulman electric gear. Added larger/longer ply back plates under servo mounting surface in elevator and wing. Didnt cut stab former. Didnt have the energy to devise, cut, and install a former in the rudder. Hope it works ok stock...
In summary, its a perfect sized model with good enough flight characteristics but just absolutely horribly executed. I honestly took this model the field half expecting to crash it and really not caring if I did! On a final note, I would be very, very cautious at putting anymore than 2500 watts through this.
Will be at Super Jets South next week with it out likely in the evenings.
Good luck
foss1997 is offline Find More Posts by foss1997
Old Sep 23, 2012, 02:59 PM
alanjets is offline
Find More Posts by alanjets
alanjets's Avatar
Ripoff britain
Joined Jan 2011
Mod's:
Good luck
I do agree with u mine flu nice but after my experience with het I will not be buying any more off them either ,My problem was no wood in the elevator a manufacturing fault yet no joy from Het not very good service from them I think but that's only my point they won't have any more of my hard earned cash lol and I have had alot off them in the past .
alanjets is offline Find More Posts by alanjets
Old Sep 23, 2012, 08:16 PM
foss1997 is offline
toledo, oh, usa
Joined Nov 1999
5 more flights today. All remains well. Much better flyer than the Habu 32. Rolls improving with mechanical de-differential and prog mixing on rud ele, rud ail, and flap ele. Airframe holding up well.
Old Sep 24, 2012, 12:20 AM
pavcon is offline
Find More Posts by pavcon
Κύπρος, Λευκωσία, Πέρα Χωριό
Joined Jan 2010
many are better flyers than the habu 32.. That plane for me is overestimated
pavcon is offline Find More Posts by pavcon
Old Sep 24, 2012, 01:14 PM
CRCJA is online now
wannabe Jet guy
CRCJA's Avatar
Green Valley, AZ
Joined Aug 2004
Flights
I had three more flights on mine, I have the CG right at 4.25, slows down nice and I had to slow down the Ailerons since I had too much. I now have tripple rates on them. Love the sound of the JetFan. Since it has the looks, I am kinda wanting a little bit more speed.
Ralph
Old Oct 07, 2012, 07:39 PM
lashmett75 is offline
Find More Posts by lashmett75
Not a Drone pilot
lashmett75's Avatar
United States, CA, Sunnyvale
Joined Jul 2008
another one bites the dust
Maiden flight was ok..but he almost lost it on base turn, but powered out of the stall and 2nd landing attempt was perfect. The story i got was he was coming out of a dive for a high speed pass and was unable to pull up out of it. The attached photo shows the end result. This was a guy from the Arizona Model Aviators.
lashmett75 is offline Find More Posts by lashmett75
Cool New HET L-39 90mm by EJF.com AceMigKiller Electric Ducted Fan Jet Talk 706 Mar 09, 2015 07:37 PM
Sold Crazy Price Drop!! HET Super Sniper with 70mm Mega/HET power system and servos. airmcn_3 Aircraft - Electric - Jets (FS/W) 9 Nov 14, 2011 11:37 AM
Found HET Sniper 90mm, airframe and maybe servos Knife Liddle Aircraft - Electric - Jets (FS/W) 2 Oct 01, 2011 11:10 AM
Sold NIB HET Super Sniper 90 V3 with HET 90mm fan and HET 600-37 motor mcgoughman Aircraft - Electric - Jets (FS/W) 0 Aug 30, 2011 08:35 PM
Sold HET All Composite Super Sniper priscalex Aircraft - Electric - Jets (FS/W) 0 Jun 30, 2008 09:17 PM
