Old Sep 06, 2012, 12:15 PM
AceMigKiller is offline
Find More Posts by AceMigKiller
Team EJF >>>WHOOSH>>>
AceMigKiller's Avatar
Joined Jul 2004
The seam on the rear Center Section Wing saddle of mine was split when it first arrived so I did something similar to mount the Wing... great minds think alike, eh Ralph?
AceMigKiller is offline Find More Posts by AceMigKiller
Old Sep 06, 2012, 02:45 PM
Hossinarizona is online now
Find More Posts by Hossinarizona
More Speed Indeed!
Hossinarizona's Avatar
USA, AZ, Tucson
Joined Nov 2007
[QUOTE=CRCJA;22654948]Mike, Here is the picture of the Wing mounts, I removed the ones in the front of the plane so I can put off the (local) shelf hardware.
Ralph,
Looks pretty strong to me, much better than it was when we received our kits. I like the bags on the F86, I did'nt know you were a seamstress as well
Looking forward to your maiden Sunday!
Hossinarizona is online now Find More Posts by Hossinarizona
Old Sep 09, 2012, 04:02 AM
CRCJA is online now
Find More Posts by CRCJA
wannabe Jet guy
CRCJA's Avatar
Green Valley, AZ
Joined Aug 2004
Retracts.
Well, here is the part where I say I am glad I made the retract mount removable, I had installed the air lines backwards. I always use clear line for Brakes, Fill valve and tanks. I followed the pictures from Vic's plane and the retracts would go up but never come back down I took out the valve and reversed the lines and they now magically work. Likewise, I always try to use the same air valve when possible, but I only had one spare sitting around for a couple years and it leaks, so tomorrow I will use the HET one.
Ralph
CRCJA is online now Find More Posts by CRCJA
Old Sep 09, 2012, 09:54 PM
CRCJA is online now
wannabe Jet guy
CRCJA's Avatar
Green Valley, AZ
Joined Aug 2004
It Flies!!!
Well, my Sniper XL has taken flight, need to check the steering and center the elevators more properly, I had to use all the left trim I could throw at it, plus a couple of clicks of up elevator. My CG for the test flight was right around the 4 inch mark, so I will shift the RX battery forward. YES, the elevator and the plane are still in one piece.
Ralph
Old Sep 10, 2012, 08:07 AM
GregG is offline
Find More Posts by GregG
Speed Demon
GregG's Avatar
Antioch,CA,USA
Joined Dec 1999
Originally Posted by CRCJA View Post
Well, my Sniper XL has taken flight, .......I had to use all the left trim I could throw at it, plus a couple of clicks of up elevator. My CG for the test flight was right around the 4 inch mark, so I will shift the RX battery forward. ........
Something about that statement makes me wonder, shouldn't the weight shift be aft to compensate for up elevator trim?
GregG is offline Find More Posts by GregG
Old Sep 10, 2012, 08:16 AM
Odysis is offline
Find More Posts by Odysis
Life begins at transition
Australia, VIC, Sale
Joined May 2007
Ah, aerodynamics
Good to hear the XL works! I still haven't bothered to get my old SS90 airborne...
Odysis is offline Find More Posts by Odysis
Old Sep 10, 2012, 10:14 AM
CRCJA is online now
wannabe Jet guy
CRCJA's Avatar
Green Valley, AZ
Joined Aug 2004
Nope
The manual says the CG should be 3 1/4 to 3 3/4 and my CG was very little past the 4 Inch mark. The Up elevator is related to the neutral point on the elevators or aileron/flap neutral point. One of the local guys took a video with an iPad, while not a great video, I will try to upload it. I was so busy flying I didn't set a timer and ran out of juice at the 3 minute mark but that was because of two power test and one aborted take off. With the 8S 4400 shifted as forward as possible and the RX battery moved from the intakes to under the canopy. Also you might recall, this is not a production stab, this one is heavier adding to my tail weight.
Ralph
Old Sep 10, 2012, 11:02 AM
CRCJA is online now
wannabe Jet guy
CRCJA's Avatar
Green Valley, AZ
Joined Aug 2004
Video
iPad video of the Sniper XL, maybe only one good video pass when I do a slow roll. HET 1500, Jet 90 Fan and 8S 4400.
http://www.youtube.com/watch?v=Fw5Lx2JQ-Go
Ralph
Old Sep 10, 2012, 12:10 PM
More Speed Indeed!
USA, AZ, Tucson
Joined Nov 2007
[QUOTE=CRCJA;22692378]iPad video of the Sniper XL, maybe only one good video pass when I do a slow roll. HET 1500, Jet 90 Fan and 8S 4400.
I am blaming it on the clouds, plus the Sniper is gray in color, that's the story and I am sticking with it . Ralph did a great job considering this was a maiden, the wind was gusting between 15 & 20 mph, and then he ran out of power on final!
Old Sep 10, 2012, 01:26 PM
CRCJA is online now
wannabe Jet guy
CRCJA's Avatar
Green Valley, AZ
Joined Aug 2004
Right Trim
Small Correction, I had to use all the RIGHT trim available, you can see the airplane Dip LEFT right at take off. Yeah, I too blame Mike for the Video, I will help out and say in his defense. I wanted to keep the airplane a little high while I played with the elevator and Aileron Trim. As far as the battery, there was two other run, ups plus a minute or two of Runway time before the flight, so with my 4400, three minutes is what I will set my timer to (which I forgot to set off for the maiden ) I was either busy with trim or too busy enjoying the flight, it felt like I was up there for 30 seconds
Ralph
Old Sep 10, 2012, 02:21 PM
corsair nut is online now
Find More Posts by corsair nut
fly like an EAGLE ;)
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
i run 5000's in my similar setup, i get 5 min with 20% left, but im very good at throttle control.
corsair nut is online now Find More Posts by corsair nut
Old Sep 10, 2012, 02:36 PM
CRCJA is online now
wannabe Jet guy
CRCJA's Avatar
Green Valley, AZ
Joined Aug 2004
Throttle
Hey Brent, Me too, I Jam the stick up and it stays there, I am in full control All kidding aside, I took off in full throttle, then came back to about 80% while adjusting the trim, you can hear the Trim cliks on the video since they are digital and loud for verification. I ran it fine at home, but when it came to this flight the throttle was set to soft start, man, can you say slow spool up!!!!!. I must have set it to soft start up with the throttle stick while I was playing with the settings on the table. I did not have a castle link at the field, so I was not going to let that stop me from flying.
Ralph
Old Sep 10, 2012, 04:25 PM
Joined Jul 2004
Ralph,
Feel free to move the CG a little further aft.
The absolute Aft Limit we've found is 4.5" back from LE. I like to fly it as far aft as possible.
Vic
Old Sep 10, 2012, 07:01 PM
CRCJA is online now
wannabe Jet guy
CRCJA's Avatar
Green Valley, AZ
Joined Aug 2004
Cg
VIC,
The problem is that IT IS already very close to or at 4.5
Ralph
Originally Posted by AceMigKiller View Post
Ralph,
Vic
Old Sep 12, 2012, 07:21 PM
evo101 is offline
Find More Posts by evo101
evo101's Avatar
Australia, QLD, Brisbane
Joined Jun 2009
good video and sounds nice
Ralph
evo101 is offline Find More Posts by evo101
Cool New HET L-39 90mm by EJF.com AceMigKiller Electric Ducted Fan Jet Talk 706 Mar 09, 2015 08:37 PM
Sold Crazy Price Drop!! HET Super Sniper with 70mm Mega/HET power system and servos. airmcn_3 Aircraft - Electric - Jets (FS/W) 9 Nov 14, 2011 12:37 PM
Found HET Sniper 90mm, airframe and maybe servos Knife Liddle Aircraft - Electric - Jets (FS/W) 2 Oct 01, 2011 12:10 PM
Sold NIB HET Super Sniper 90 V3 with HET 90mm fan and HET 600-37 motor mcgoughman Aircraft - Electric - Jets (FS/W) 0 Aug 30, 2011 09:35 PM
Sold HET All Composite Super Sniper priscalex Aircraft - Electric - Jets (FS/W) 0 Jun 30, 2008 10:17 PM
